Lowest possible resistance on laptop motherboard rail - Guide Table request
  • Nagy Daniel
    • Oct 2024
    • 7
    • SLOVAKIA
    Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
    I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
    I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
    So, I generated a table with AI so I can use it as a guide when repairing, and I would like to ask you if you can correct this table. I need ranges that can be correct, but under the specified resistance it's almost 100% sure that there is a shorted rail.
    You can even add some important rails, so I can learn from that, or modify the values to change the table to be more accurate.​
    Power Rail Voltage (V) Expected Resistance (Ω) Below this = Possible Short Notes
    Main Power Rails
    19V (Adapter Input) 19V 3kΩ – 20kΩ Below 500Ω Main power input (from DC jack).
    CPU Core (VCore) ~0.8V – 1.4V 0.2Ω – 5Ω Below 0.1Ω Core voltage for the CPU.
    GPU Core (VGPU) ~0.8V – 1.3V 0.3Ω – 2Ω Below 0.2Ω Core voltage for the GPU.
    GPU VRAM (MVDD/VDDQ) 1.35V – 1.8V 3Ω – 50Ω Below 2Ω Power for GPU memory (VRAM).
    PCH/Chipset Power 0.9V – 1.8V 10Ω – 100Ω Below 5Ω Power for Intel/AMD chipset.
    RAM Power (VDDR, VPP, VTT) 0.6V – 1.5V 3Ω – 50Ω Below 2Ω Power for system RAM (DDR4, DDR5, etc.).
    PCIe Power (VDDCIO, VDDP) 0.8V – 1.2V 10Ω – 100Ω Below 5Ω Power for PCIe lanes (important for GPUs).
    3.3V Rail (Always ON, LDO, I/O) 3.3V 200Ω – 10kΩ Below 50Ω Powers logic circuits, BIOS, etc.
    5V Rail (USB, Other Peripherals) 5V 500Ω – 50kΩ Below 100Ω Powers USB, some sensors, LCD backlight circuits.
    1.8V Rail (BIOS, Logic, eMMC) 1.8V 200Ω – 5kΩ Below 50Ω Used for BIOS flash, embedded memory, and some CPUs.
    RTC/CMOS Battery Rail 3V 10kΩ – 500kΩ Below 1kΩ Powers real-time clock & BIOS settings when off.
    LDO 3.3V & LDO 5V (Low Dropout Regulators) 3.3V – 5V 500Ω – 10kΩ Below 100Ω Powers small internal circuits & sensors.
    Thank you in advance.
  • guyandpit
    • Oct 2021
    • 103
    • Philippines
    thank you the information. subscribe for any updates.
    • 580shahzad
      • Jan 2012
      • 65
      • PAKISTAN
      thanks
      • CharlesBHaskins
        RTX 2060 Laptop VRAM Rail Resistance
        by CharlesBHaskins
        I'm checking the VRAM power rail on an RTX 2060 laptop GPU and I'm not sure whether the resistance I'm measuring is within the normal range.
        Has anyone measured the VRAM rail resistance on a similar board? What values did you get, and how can you tell if there's a short?
        Thank you so much!
        06-18-2026, 01:11 AM
      • User 4574
        Asus , board 532lws R1..3 Power rail 5v , 3v dsw
        by User 4574
        Hi everyone .
        I have model g712l And In stuck.
        Originally this laptop has a short on main Power rail . Thé main short is gone, i have found 2 pea16b mosfets Next to the SN51285ARUKR shorted , and the Chip Intself was Also shorted , i have removed them and main Power rail IS not shorted anymore , but right Now im still eating for this parts And in checking rest of the board . But pin 14 od the SN51285ARUKR when this chip od removed is shorted to ground Its +5VSUS has 6ohms , And that can not be , i have check mosfets All over the board And i have found ONLY one tahat ís shorted its...
        Bad cap
        0%
        0
        Shorted internal layer in thé motherboard
        0%
        0
        06-21-2026, 07:50 AM
      • Elementallion
        Acer Nitro 5 N20C2 – No Power, Low CPU Rail Resistance (Possible Shorted CPU)
        by Elementallion
        Board: FH51M LA-J871P Rev 1A
        Got this laptop from a coworker with a completely dead issue. No LEDs, no charging light, no response at all. He said it suddenly shut down and never powered back on.
        With the original adapter connected, I have 0V on all the main inductors.
        When I connect it to my bench PSU, the board briefly tries to start but immediately shuts off (current spikes and then drops).
        Resistance to ground on the main coils:
        • GPU core — 0.5 Ω
        • CPU core — 0.2 Ω
        • Other rails — 75 Ω to OL
        0.5...
        03-04-2026, 10:27 PM
      • TheNewGP
        EVGA RTX 3090 FTW3 Rev 0.1 Partially Repaired, Unsure How to Proceed
        by TheNewGP
        TL;DR: Bought this card dead. Reflowed a cracked 330 inductor near the PCIe edge which brought it from completely invisible on PCIe to fully enumerating. NVVDD confirmed working at 0.796V, all phases balanced. All measurable external rails are present. But driver initialization fails (RmInitAdapter) across two systems, three slots, six driver versions, and two operating systems. BAR0 register probe shows GFW firmware stalls at phase 3.3 with two distinct groups of internal registers unreachable (all PLLs, all FBPA partitions, FBHUB, SPI flash, fuses, display, several Falcons). Looking for guidance...
        03-29-2026, 01:28 PM
      • cind12
        GTX 1080 TI Gigabyte Aorus low resistance on vmem
        by cind12
        Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
        Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
        The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
        Resistance on 12V 4K ohms (Power present when on)
        Resistance on 12V PEX 4K ohms...
        12-08-2023, 09:09 AM
