Lowest possible resistance on laptop motherboard rail - Guide Table request
  • Nagy Daniel
    • Oct 2024
    • 7
    • SLOVAKIA
    Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
    I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
    I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
    So, I generated a table with AI so I can use it as a guide when repairing, and I would like to ask you if you can correct this table. I need ranges that can be correct, but under the specified resistance it's almost 100% sure that there is a shorted rail.
    You can even add some important rails, so I can learn from that, or modify the values to change the table to be more accurate.​
    Power Rail Voltage (V) Expected Resistance (Ω) Below this = Possible Short Notes
    Main Power Rails
    19V (Adapter Input) 19V 3kΩ – 20kΩ Below 500Ω Main power input (from DC jack).
    CPU Core (VCore) ~0.8V – 1.4V 0.2Ω – 5Ω Below 0.1Ω Core voltage for the CPU.
    GPU Core (VGPU) ~0.8V – 1.3V 0.3Ω – 2Ω Below 0.2Ω Core voltage for the GPU.
    GPU VRAM (MVDD/VDDQ) 1.35V – 1.8V 3Ω – 50Ω Below 2Ω Power for GPU memory (VRAM).
    PCH/Chipset Power 0.9V – 1.8V 10Ω – 100Ω Below 5Ω Power for Intel/AMD chipset.
    RAM Power (VDDR, VPP, VTT) 0.6V – 1.5V 3Ω – 50Ω Below 2Ω Power for system RAM (DDR4, DDR5, etc.).
    PCIe Power (VDDCIO, VDDP) 0.8V – 1.2V 10Ω – 100Ω Below 5Ω Power for PCIe lanes (important for GPUs).
    3.3V Rail (Always ON, LDO, I/O) 3.3V 200Ω – 10kΩ Below 50Ω Powers logic circuits, BIOS, etc.
    5V Rail (USB, Other Peripherals) 5V 500Ω – 50kΩ Below 100Ω Powers USB, some sensors, LCD backlight circuits.
    1.8V Rail (BIOS, Logic, eMMC) 1.8V 200Ω – 5kΩ Below 50Ω Used for BIOS flash, embedded memory, and some CPUs.
    RTC/CMOS Battery Rail 3V 10kΩ – 500kΩ Below 1kΩ Powers real-time clock & BIOS settings when off.
    LDO 3.3V & LDO 5V (Low Dropout Regulators) 3.3V – 5V 500Ω – 10kΩ Below 100Ω Powers small internal circuits & sensors.
    Thank you in advance.
  • guyandpit
    • Oct 2021
    • 82
    • Philippines
    thank you the information. subscribe for any updates.
    • 580shahzad
      • Jan 2012
      • 63
      • PAKISTAN
      thanks
      • cind12
        GTX 1080 TI Gigabyte Aorus low resistance on vmem
        by cind12
        Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
        Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
        The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
        Resistance on 12V 4K ohms (Power present when on)
        Resistance on 12V PEX 4K ohms...
        12-08-2023, 09:09 AM
      • Victor Moreira Silva
        Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
        by Victor Moreira Silva
        I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
        Well, my decice specs are the following:
        Model: Acer Nitro 5 AN517-54-55T5
        CPU: Intel Core i5-11400H
        GPU: NVIDIA GeForce GTX 1650
        Motherboard: GH51G LA-L181P Rev:1c
        The symptom:
        When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
        05-26-2025, 10:49 AM
      • lefetylorant
        Lenovo Thinkcentre tiny M90Q gen 1 - no 12V rail
        by lefetylorant
        Hello Everyone,
        Long story short, I got this unit for very cheap.
        I've started to experiment with it's BIOS, as I did before successfully with an M900. However my very bad quality SOIC clip broken while dumping of the biosof and it must have damaged something on the panel, because it does not turn on, and does exactly nothing when powered. The maximum voltage that could have affected something is the 3.3 or 5v from the IC clip, because the unit was not powered while the bios dumping was in progress.
        I've performed some measurements:
        - 20V rail perfectly...
        09-14-2023, 05:05 AM
      • bimole
        Weird behavior on 3.3V rail of a CORSAIR CX600
        by bimole
        A colleague gave me an apparently ill CORSAIR CX600.
        He told me that he heard a banging noise, and smelt the magic smoke.
        After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
        I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
        It's another story on the 3.3V rail...
        I have some devices to test deeply PSUs (scope, AC source, electronic load)...
        02-13-2025, 04:49 AM
      • bpjl
        Dell E7450 LA -A961P - diagnostics after flooding and damaged PD817, PD5 diodes
        by bpjl
        I have La-A961P Rev: 1.0 (A00) from a flooded laptop on the table. The computer was flooded with tea and at the same time the power supply was disconnected, the battery was removed immediately and the laptop was turned upside down.
        I looked at the mainboard, but I don't see any marks of water damage. Maybe the liquid did not reach MB, or maybe I just don't see it.
        During the inspection, I noticed a burned (charred on one side) double diode PD817.
        Voltage drops during PD817 measurements:
        - PIN1-PIN3 forward biased = 0.137V...
        01-27-2025, 03:01 PM
