What is this that has blown?
    Re: What is this that has blown?
    Originally posted by mikay786
    Yes.
    • mikay786
      • Aug 2014
      • 765
      Thanks, I feel bad just ordering those with free delivery. Must cost them 5 x as much just to deliver them
        • 31017
        the ones i linked are cheaper!
        • fzabkar
          • Mar 2009
          • 772
          Originally posted by budm
          If you look at the board, there are two 470 Ohms 1W resistors, each one for feeding the Collectors of the Transistors, the Zeners are probably 12V, so they are not feeding the transistors directly with 39V.
          Thanks. My eyesight isn't young anymore and I have bad colour vision.
          Still, that is a horrible design.
          A 1W, 470 ohm resistor would be able to handle 46mA at most.
          The power dissipation in the transistor would be ...
          P = Vce x Ic = ((Vin - Vout) - IR) x Ic
          = [(39V - 11V) - (Ic x 470 ohms)] x Ic
          So ...
          I = 46mA -> P = 293mW
          I = 40mA -> P = 368mW
          I = 30mA -> P = 417mW
          I = 20mA -> P = 372mW
          I = 15mA -> P = 314mW
          I = 10mA -> P = 233mW
          AISI, that is pushing the limits of the spec for those transistors, unless the load is drawing some miniscule current. However, if the load current were indeed insignificant, then the designer could have chosen a higher resistance value.
          Looking at it another way, let's assume that the designer chose a 1W resistor because it needs to dissipate 0.5W. Therefore the current draw would be ...
          Ic = sqrt(0.5W / 470 ohms) = 33mA
          At 33mA, the dissipation in the transistor would be 412mW.
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            #65
            Originally posted by stj
            they didnt know the colours actually meant anything!!!!!!!!
            Yep, them colors are just for decoration and stuff. To make the circuit board look all pretty and colorful.
            • mikay786
              • Aug 2014
              • 765
              On a more pleasant note ive finished with the technic units I scored a few weeks ago. Have come out great and really happy with them. Love the looks and the sound, powering some big old Jamo speakers which I though it might struggle with but has been fine.
              Just took new AC cables and some of the pots needed cleaning out and working great.
              Will be a keeper unless I find something better
                So ...
                Easy way to find out is to measure the Vdrop on the resistor, and since current draws in the preamp section depends on the audio level it may not draw much at standby mode.
                Typical Dual OP-AMP such as 4558 does not draw that much at all: They may have a couple of them for Low pass EQ.
                https://cdn.badcaps-static.com/pdfs/...e2ada35a2a.pdf
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  #68
                  Wow, they look beautiful indeed. Kind of hurts me when I see the dinged-up knob on the turner. I just can't imagine how anyone could mishandle/abuse old classic gear like this. To me, those old units are a piece of art.
                  I'm glad to hear you got them working and are using them . Feel free to post your setup in either of these threads:
                  https://www.badcaps.net/forum/showth...326#post586326
                  https://www.badcaps.net/forum/showth...047#post581047
                  • mikay786
                    • Aug 2014
                    • 765
                    Indeed, and its more than likely given the clean condition of the amp it was probably the sellers (not original owner) who caused it.
                    Got my eyes on the matching cassette deck online which I will bid on and I'm thinking of buying the technics SB-F1 / SB-F2 or SB-F3 speakers. Perhaps going down the middle of the road with the F2s is the best compromise. Theres a MK2 version of the speakers, which probably sound better but not too keen on the looks. Think the MK1s fit more aesthetically, that's probably kind of silly as it should be about the sound!
                      • 31017
                      if you do a farnell order, why not replace the crap fuseholders you mentioned?
                      • mikay786
                        • Aug 2014
                        • 765
                        I have, got them from maplins whilst I bought the wrong caps. Got two plastic type ones with covers on them.
                          • 31017
                          the cream coloured 20mm ones?
                          i love those - got myself a bag of about 20 from rapid a while back.
                          probably cost the same as your 2
                          • mikay786
                            • Aug 2014
                            • 765
                            Browny cream, that's Maplins tax for you. I think they were 56p each so can't complain given the convenience.
                              • 31017
                              these 14pence ones!
                              http://www.rapidonline.com/Electrica...er-CFH02-64583
                              • mikay786
                                • Aug 2014
                                • 765
                                Big thanks to everybody, this thing is freaking awesome. So much bass its literally sliding around on my floor!! Think I need to put it on some rubber or something.
                                So happy, my first proper sub. Thanks STJ, budm, momaka, fzabkar, ReeceyBurger123 and SteveNielsen.
                                  master hoarder
                                  • May 2008
                                  • 12175
                                  • Bulgaria
                                  #76
                                  Most certainly welcome!
                                  Nice!
                                  Here, try this then:
                                  https://www.youtube.com/watch?v=VzmbR-E6XYc
                                  ... and I'm thinking of buying the technics SB-F1 / SB-F2 or SB-F3 speakers. Perhaps going down the middle of the road with the F2s is the best compromise. Theres a MK2 version of the speakers, which probably sound better but not too keen on the looks. Think the MK1s fit more aesthetically, that's probably kind of silly as it should be about the sound!
                                  Lol, yeah. You don't want to be embarrassed in front of people when you show that beautiful tuner/amp playing, only to make some tiny sound from those speakers.
                                  I mean, don't get me wrong. Technics is a decent brand. But I would just avoid small speakers like that. They just can't match the performance of proper bigger speakers.
                                  • Steph.hen
                                    Bridge rectifier identification part number KPB305G
                                    by Steph.hen
                                    Hi all, a newby question about a bridge rectifier I'm trying to identify.
                                    I'm in the midst of reparing a battery charger in work which went pop, The bridge rectifier has shorted and took out a couple of other components. The rectifier in question has a part number KPB305G, and it looks like it's obsolete. Does any one know what I could replace it with?...
                                    08-29-2024, 09:52 AM
                                  • mpn78
                                    Fujitsu Q556, What capacitor for bridge rectifier?
                                    by mpn78
                                    Hello
                                    My Fujitsu Esprimo Q556 motherboards blew up. At least fuse, bridge rectifier and capacitor got damaged. I have changed fuse and bridge rectifier (DF1508S), but I don't know what capacitor it is (picture). I know that capacitors size is 47nF, but I don't know other specs for it. Can you help me to choose right capacitor for my motherboard?
                                    There is 240V AC on input side of bridge rectifier and 340V DC as output on capasitors side.
                                    Thanks....
                                    04-05-2022, 12:31 PM
                                  • leotron
                                    XFX 850w blown bridge rectifier.
                                    by leotron
                                    Hi, a friend of mine gave me this broken power supply, aparently it's the rectifier bridge that was damaged months ago. He took it to a technician and they didn't have the repair tools necesary but they remove the original bridge rectifier since it was damaged(burned). I have some of this rectifiers laying around, but they are not the same. The original its a pair of GBJ1506
                                    And I have KBL06 , KBL406 , RVB406, D5SBA20, D3SBA60, GBU608. Most of them have similar values to the original, but I'm not planning to use the PSU at full load (ie: SLI, an I7 processor, etc).
                                    TomsHardware...
                                    02-05-2020, 07:59 AM
                                  • EasyGoing1
                                    Reading input and output of bridge rectifier on the same scope?
                                    by EasyGoing1
                                    I have a 40 volt AC transformer that I put a bridge rectifier on, and I wanted to see the input signal and the output signal on the same screen on my scope, so I set one channel up with the test lead on one side of the input and the ground lead on the other side of the input, then I used another channel on the scope and clipped the test lead on the positive side of the output then the ground on the negative side of the output.
                                    When I connected the transformer to power, the wire that was connected between the ground lead on the second channel and the negative side of the bridge rectifier...
                                    06-26-2022, 12:52 AM
                                  • nicktasios
                                    Macintosh Quadra 840AV PSU
                                    by nicktasios
                                    I had my Quadra 840AV (which I recapped and had working) plugged in for some time without using it and randomly decided to turn it on today. Unfortunately it did not turn on. After checking the PSU, I found out I was not getting anything from 12V, only from the 5V rail. After a few minutes, I removed the PSU and plugged it back in the electrical outlet and it suddenly started making a weird sound and soon after smoke started coming out. I quickly unplugged it. I opened it up but on first instance I didn't see anything out of the ordinary really. I later turned it back on and one of the MOVs blew...
                                    12-22-2024, 05:07 AM
