Macintosh Quadra 840AV PSU
  • nicktasios
    • Sep 2023
    • 13
    • Netherlands
    I had my Quadra 840AV (which I recapped and had working) plugged in for some time without using it and randomly decided to turn it on today. Unfortunately it did not turn on. After checking the PSU, I found out I was not getting anything from 12V, only from the 5V rail. After a few minutes, I removed the PSU and plugged it back in the electrical outlet and it suddenly started making a weird sound and soon after smoke started coming out. I quickly unplugged it. I opened it up but on first instance I didn't see anything out of the ordinary really. I later turned it back on and one of the MOVs blew up.
    I had no experience with PSU repairs whatsoever so I was stupid enough to just replace the varistor that blew up and a couple of suspect capacitors and turn it on! Sparks again, a bang, and the mains tripped. The second varistor blew up as well as the fuse. I later learned that to work more safely with PSUs, I should have made a series bulb tester/current limiter. I then started learning more about PSU repairs and did some more troubleshooting on the PSU. I found at least one TRIAC that had shorted, and after removing both main caps so that I could get access to the blown varistor, I found out one of them, the one close to the blown varistor, was showing capacitance in the nF instead of the rated 1200uF.
    After ordering some more components and waiting patiently, I replaced the TRIAC, replaced the main capacitors, replaced the MOVs, jumpered the fuse temporarily as I didn't have a replacement at hand, and I also created a light bulb current limiter. Note that I couldn't read the MOV markings anymore, so I ordered these https://nl.mouser.com/ProductDetail/...r983RJeg%3D%3D, but now I'm wondering if they are the correct ones. Unlike the usual case where they are placed before the bridge rectifier, these are placed next to each of the two main capacitors.​ I plugged the PSU in the current limiter and turned on the current limiter switch. Nothing blew! The light bulb was dim. I checked the voltage on the main capacitors and it read about 200V. Then I decided to attach the fan, and after turning on, I saw sparks and smoke somewhere in the area of the main capacitors (top left corner in the picture), but I couldn't tell which component got burned! After that, the light bulb was full on...I'm not sure if the fan caused the issue or it was just a coincidence. Also, I would expect some short, but measuring the resistance between the AC leads show something like 200k Ohm, so now I'm not sure what is wrong. I checked all diodes on the main side and they all seem to give correct values. The bridge rectifier also does not seem to be bad. Does anyone have any tips? The only thing I can think of now is to start removing components and measure them off circuit. As a last resort I'm thinking of buying one that is working and cross reference the circuits.
    I uploaded an image of the PSU. I annotated the TRIAC with green, the bridge rectifier with red, the MOVs with blue. Also note: I found solder on windings of the component in yellow (is this a transformer?). Not sure if that came from me, but I was able to remove most of it with a solder wick. Not sure if this could be a potential issue.
  • chth96
    How can I identify varistor which have been blew up?
    by chth96
    I mistakely pluged 100v japanese retro game console to 220v outlet.
    So It seems that glass fuse and varistor have been blew up.
    I can identify that voltage and ampere value of glass fuse(250V LF 1.6A),but It is impossible to identify varistor type in my sega saturn PSU(YAMAHA 35M07U XR258)
    Is there any way to identify varistor type in my sega saturn PSU?
    Any reply would be appreciated.
    EDIT:
    It seems that I finally found out what type this black varistor is. It is Panasonic ERZV05D221 “ZNR” Transient/Surge Absorbers (Type D) Varistor Voltage...
    11-26-2023, 08:52 AM
  • прямо
    TRIAC circuit
    by прямо
    Anyone is familiar with a TRIAC circuit?
    I came across this schematic, and I built it, but I can't seem to figure it out why I'm getting a low AC voltage output at the TRIAC terminals.
    With 230V AC hot side at the TRIAC MT2, I measured 60V AC between MT1 and neutral side when the comparator output LED indicator is on, and 20V AC when it is off.
    Same result if 230V AC hot side is at MT1, and I measured between MT2 and neutral side.
    My heating element doesn't work with 60V AC. It's not even getting hot and the thermocouple amplifier output is a...
    04-27-2024, 02:12 AM
  • harp
    triac phase control 0-100%
    by harp
    Trying to understand which properties of circuit affect triac phase range, is it possible to control near whole period, or it have some limitations - on net found a couple circuit, that claims almost full control, but in the past I build some simple circuit and remember that it do only half of control over triac?...
    06-02-2024, 09:00 AM
  • Nevillet
    Triac alternatives
    by Nevillet
    Hi All,
    I'm trying to repair a coffee machine where the triac that controls the 240VAC water pump has failed and is latched on.
    The water pump is controlled either on or off.
    The triac is a surface mount BTA204S-800E. (datasheet attached)
    I have a selection of other non surface mount triacs and need advise on selecting a substitute.
    The triacs include BTA16, BT131, BTA208, BTA12, BT138, BTA06
    Any help would be great.
    Many thanks.
    02-17-2024, 11:30 AM
  • honeybadger0
    Yamaha EMX 512SC - Bad Limiter?
    by honeybadger0
    I have a Yamaha EMX 512sc powered mixer that gets heavy use. Recently a new problem has arisen ... it seems like the L output is way more sensitive than the R and the limiter light for main L is flashing even at very low (below the 2 setting on the knob) levels.
    It seems to be across all channels and with different inputs. The speakers have been recently tested as well and do not seem to have any of their own issues.
    Has anyone else encountered this problem and could help me out?​
    11-03-2024, 07:38 PM
