Bridge rectifier identification part number KPB305G
  • Steph.hen
    • Aug 2024
    • 3
    • Scotland
    Hi all, a newby question about a bridge rectifier I'm trying to identify.
    I'm in the midst of reparing a battery charger in work which went pop, The bridge rectifier has shorted and took out a couple of other components. The rectifier in question has a part number KPB305G, and it looks like it's obsolete. Does any one know what I could replace it with?
  • truclacicr
    • Apr 2019
    • 356
    • australia
    https://www.mouser.com/catalog/specs...scs01692-1.pdf
    • redwire
      • 3912
      KBP bridge rectifiers are 3A and I find not so popular outside of Asia.
      The "305" is 3A and oddball numbering for a 600V part, other manufacturers use "306". You can use a higher voltage part like KBP306, 308, 310 etc. much easier to find.
      The fuse should have protected it, and there may be an overload or short on the primary like a blown mosfet.
      • Steph.hen
        • Aug 2024
        • 3
        • Scotland
        Thank you, I have a look for one of those.
        The fuse and mosfet were blown, also a exploded resistor which were replaced. But I still had a short, which I traced to the rectifier.
        • esinior
          Smd code to part number
          by esinior
          Hi i have a smd part with probably mark "QO 11" or "Q0(zero) 11" on it, and its package is SOT89, i doubt its KTB1260 PNP transistor, but in measuring with diode mode of multimeter it shows number 1.4 between emitter and collector pins and its not open circuit, and .59 from collector to base and .8 from emitter to base , and these numbers doesn't match a pnp transistor, i couldn't find any part number and datasheet for it, does anybody have information for that part number?
          I've attached pics of this part
          Thanks...
          08-20-2024, 02:50 AM
        • Yanleb
          Panasonic part number in service manuals
          by Yanleb
          In the Panasonic service manuals, both in the board schematics and in the part listing, the part numbers that are given are Panasonic part numbers instead of the actual part numbers.
          This is especially annoying for small SMD components like diodes and transistors when you only have 1-3 digits printed on the component body.
          For an example, look at the attached PDF.
          Do you have a way to cross reference the Panasonic part number with the actual part number?
          Thanks....
          07-03-2023, 08:16 PM
        • saghi88
          looking for part number (Marking code 46BF) Case DFN8 3x3
          by saghi88
          I am looking for the part number of this component so I can order it. I cannot identify it based on the marking code; I think it is an LDO IC. Can anyone determine the manufacturer's part number from the marking code?
          I have uploaded images showing the dimensions and the marking code of the IC. I believe the package is a DFN-8 with dimensions of 3 mm × 3 mm × 0.9 mm.
          Thank you in advance for your support
          11-21-2025, 03:38 AM
        • SilverbackITGuy
          Asus ROG Strix G17 , Identifying a part number from the boardview diagram ID
          by SilverbackITGuy
          First of all, I hope I got this into the right section. Apologies if I did not.
          I was working on my Asus ROG Strix G17 (2021) G713QM-RS96, and I guess I pre-heated the board too much replacing the DC Jack and one of the small parts came off. I looked for it on my soldering mat, and it was nowhere to be found. So now, the laptop is powered from the new DC Jack I installed, but it will not charge the battery from that jack. Only powers the hardware.
          I looked at the boardview diagram in another post for the G713QM, and it looks like the diagram displays it as X450, a 4 contact...
          11-18-2025, 07:23 PM
        • Baludoki80
          MSI B460M-A Pro motherboard part identification
          by Baludoki80
          I have a wrong motherboard,does not switch on,no power.the framed part heats up,and the smd market is RUA3 but I couldn't find this part.I search schematic thank you...
          09-22-2025, 01:36 AM
