Bad PSU Thermistors blowing, no multimeter
  • AlwaysCheap
    • Oct 2015
    • 23
    • Hungary
    Hi guys, I am experiencing the same weird problems too with my thermistors what gives?
    Here is how it all started: I got the brand new PSU(Approx 650W "App650PS") about 3 weeks ago without guarantee because it's a replacement for another malfunctioning psu(Cooler Master 600W) that lasted for about 2 years.
    A few nights back I was gaming, enjoying my new PSU and "BAM" the PC turns off without any warning. I try to turn it on and it won't start but the Mobo light is lit "green". Decided to pull the plug and let everything cool for an hour or so.
    After the 1hr wait I plugged the extension cord back in the wall socket and tried to turn on my PC. At this point all I heard was a pop in the PSU and the lights in the whole house went. It tripped the breaker for the whole house.
    After opening the PSU it up(no warranty so why not ) I noticed the fuse(5x20mm 6.3A) inside had blown,went quickly to the store and got 3 replacements just in-case. Put in the replacement and "BAM" it blows the second fuse together tripping the breaker for the whole house
    Googled around and found some usual culprits that might be causing the issue. Since i'm kinda cash strapped and don't want to wait for a cheap multimeter from AliBaba(which could take weeks) I decided to replace some parts for the PSU which I thought may be defective. (All this without using a multimeter).
    I first started by replacing the crappy Chinese bridge rectifier(KBP 307 3A) https://cdn.badcaps-static.com/pdfs/...ce07994762.pdf
    to a better Diotec brand with higher ratings(KBU8K 8A)
    Soldered it on and "BAM" still the same problem, blown fuse + tripped house breaker circuit.
    Next I decided to change the filter cap from a cheap (HQX 334 250V - 275V X2)275VAC0.33UF 275V334K X2 to (.47uF 275V X2)
    Soldered it on and "BAM" still the same problem, blown fuse but this time it blew out an NTC thermistor too (MF72-5D11 5 Ohms 4A)(Blew it to pieces) with a loud bang + tripped house breaker circuit.
    Went to the store again(became a regular idiot by now) and got a replacement with higher ratings (4.7 Ohms 5.1A)
    Soldered it on and "BAM" still the same problem, blown fuse but this time it blew out the other NTC thermistor next to the one I replaced, it is also a (MF72-5D11 5 Ohms 4A)(Blew it to pieces too) with a loud bang + tripped house breaker circuit.
    What could be the cause of this ? I would appreciate any help you guys could provide to guide me in the right direction, I still can't test any component because I don't have a multimeter or anything similar.
    So far I have not been able to find the psu's schematic anywhere, I have a few diodes(higher ratings) and resistors that I can replace, is it worth a try to replace the one's on the pcb?
    Re: PSU just "exploded" what's the cause?
    "What could be the cause of this ? I would appreciate any help you guys could provide to guide me in the right direction, I still can't test any component because I don't have a multimeter or anything similar. " Not until you have test equipment to look for shorted circuit. I hope the circuit does not have further damage when new parts are installed and blew up again.
    • CapLeaker
      Leaking Member
      • 8196
      kinda pointless without a DMM.
        • 31067
        a meter will be cheaper at this rate than constantly blowing stuff up!
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          Re: Bad PSU Thermistors blowing, no multimeter
          I created a new thread for you, no need to resurrect the other one
          I would suggest that you make a bulb tester so you don't have to blow your PSU into a thousand pieces each time you try it:
          https://www.badcaps.net/forum/showpo...4&postcount=70
          More threads I found while looking for the one linked above
          https://www.badcaps.net/forum/showth...054#post335054
          https://www.badcaps.net/forum/showth...424#post184424
          https://www.badcaps.net/forum/showth...149#post261149
          https://www.badcaps.net/forum/showthread.php?t=32748
          https://www.badcaps.net/forum/showth...045#post279045
          https://www.badcaps.net/forum/showthread.php?t=30986
          • AlwaysCheap
            • Oct 2015
            • 23
            • Hungary
            Thanks for creating a new thread and for all the helpful info to point me in the right direction. I'll try it and see how it goes before my Multimeter gets here, I agree it's way better than blowing new stuff up
            • Joe Black
              eager to learn
              • Sep 2015
              • 173
              • southeastern europe
              Someone near you HAS to have a multimeter you can borrow.
              Maybe one of switching transistors is shorted, but still cant verify without DMM.
              Also, plus 1 for the bulb…
              stay classy
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                Yeah, very likely the input primary switching transistors shorted out but there may be something else that caused the transistor to short... Multimeter is mandatory. Even an analog one will help. Or even getting a PP3 battery, LED, and resistor may be helpful to see if something's shorted (though you will have to test both ways because this will forward bias semiconductors...)
                The fuse in these switching psus are there for protecting your house, not the PSU. When it blows, the PSU is guaranteed to need repair... and usually it's a semiconductor.
                • AlwaysCheap
                  • Oct 2015
                  • 23
                  • Hungary
                  Great !! They will be the first I will check once I get my hands on a DMM. You are referring to these transistors right? If one is faulty I can change both to a higher rating ?
                  Currently the stock ones are and from the looks of it they look pretty weak.
                  What is the criteria for choosing a good transistor, do we consider the volts or watts? e.g Drain-Source Breakdown Voltage V(BR)DSS 500V or the Total Power Dissipation in Watts?
                  Too bad I don't know how much juice the transformer can produce.
                  Could this be a good replacement?
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    What you can do now is make the dim-bulb tester, use a 40W bulb, and start pulling parts out of the power supply and then test if the PSU input is still shorted. If the bulb still glows brightly, then pull out another part after turning it off, and retest. The last part you pulled before it stops glowing brightly is a suspect part. Be careful of the MOSFETs, static can destroy them, but likely they are already fried.
                    Of course, there are parts that will obviously turn out the light like pulling the fuse, the inline noise filters(s), the bridge rectifier, so don't pull those ... You really need the multimeter to really see what's bad.
                    I'd try not to swap the parts too much from stock, you may get strange operation if you choose mosfets that have higher gate cap than what it was designed for...
                    • TELVM
                      • Oct 2012
                      • 547
                      • Spain
                      Our American friends are giving great advice suggesting the dim-bulb tester, which is a simple and useful tool.
                      How to build a dim-bulb tester
                      But on their side of the pond they enjoy sockets with unambiguous polarity.
                      On Hungarian Schuko sockets with ambiguous polarity, and without a DMM to clear the ambiguity up, there is a 50% chance of reversed polarity and placing the bulb on the wrong (neutral) wire.
                      • goodpsusearch
                        • Oct 2009
                        • 2850
                        • Greece
                        So? The result will be the same. The bulb will limit the current and keep the psu from blowing.
                        • AlwaysCheap
                          • Oct 2015
                          • 23
                          • Hungary
                          Thanks for the heads up, I was going to use just two wires without ground/earth since the wall socket only has two holes. As for which is the neutral and which is the live is a little confusing right now.
                          I am in the process of putting one together now with some old parts lying around(it's not finished yet still have to connect the bulb to the circuit).
                          Bad idea?
                          • AlwaysCheap
                            • Oct 2015
                            • 23
                            • Hungary
                            Contraption Complete !!
                            Thanks guys for all the feedback about the dim-bulb tester, finally got it up and running. I tried connecting a DC 5V clock to it and the clock worked but the bulb didn't light up. When I tried unscrewing the bulb the connection was lost once the bulb was loose, if screwed back in, the clock works again.
                            Does it light up always or only when on load? I thought it should be dim, right?
                            I'm using a 40W bulb at the moment for testing, any input is much appreciated.
                              Plug in a working PC power supply by itself without forcing it on so that it will be just the standby power supply section is running then observe the brightness of the lamp.
                                • 31067
                                connect the earth.
                                use the screw on the wall socket if you have to.
                                • AlwaysCheap
                                  • Oct 2015
                                  • 23
                                  • Hungary
                                  Thanks STJ, there is a screw for the earth terminal in the socket used for the Dim-Bulb tester. It's on the bottom of the socket, I could connect a wire to it, but where can I connect it from there?
                                  Forgive my weak physics application of theory
                                    • 31067
                                    the screws holding the 2pin socket on your wall are probably earthed through the back-box.
                                    show a foto of the 2pin socket.
                                    • AlwaysCheap
                                      • Oct 2015
                                      • 23
                                      • Hungary
                                      I forgot to mention that I will connect the DB-Tester to an extension cord and not direct to the wall. The extension cord is earthed and fused. any ideas?
                                      Edit* : Is there any risk if I connect it to extension cord the way it is?
                                      • AlwaysCheap
                                        • Oct 2015
                                        • 23
                                        • Hungary
                                        Thanks for the tips and helping troubleshoot my PSU , I managed to test my PSU without it behaving like a "Flashbang".
                                        Here are my results so far:
                                        Removed blown NTC = "Bright Bulb/ still shorted"
                                        Removed both MOFETS and of the big 200V Capacitors = "No bulb light at all"
                                        Is it because of the removed cap? or did removing the MOFETS also play a part in this.
                                        Hope my Multimeter gets here soon
                                        • dj8452000
                                          How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
                                          by dj8452000
                                          I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
                                          02-18-2025, 08:28 AM
                                        • BigTroll
                                          help with home a/c and circuit breaker
                                          by BigTroll
                                          while I was gone today the women called me and said the a/c isn't working and the breaker is buzzing so she turned off the breaker. The a/c is a old 1993 model York so its nearing the end of its days, on really hot days the a/c will trip the breaker.
                                          I visually checked the cap and contactor and they looked okay, I also pulled the 250v ac fuses and switched the main ac breaker on and got no buzz. I did get buzz when I put the ac 250v fuses back in and flipped on the breaker nothing but buzzing. could it be a shorted wire or did the circuit breaker just finally give up the ghost?...
                                          09-05-2020, 07:53 PM
                                          How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                                          by sam_sam_sam
                                          About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                                          Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                                          Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                          12-14-2023, 07:45 PM
                                        • davidebaldini
                                          ATX power supply keeps blowing PFC mosfets — Cooler Master RS-550-ACAA-E3
                                          by davidebaldini
                                          This is an ATX PSU rated for 550W powering 24/7 a computer load of about 200W, fed by a line-interactive 1500VA UPS. Mains is 230V.
                                          1. First issue: the PSU blew a mosfet on what I think is the active PFC boost converter, shorting its G D S pins together causing a short across the + and - lines produced by the rectifier on the 230V mains. The surge protector of the house tripped. When this happened I found that the UPS was unexpectedly disconnected from the wires of its battery. The UPS wasn't damaged, but I suspect this spontaneous detachment of a battery wire caused a condition that blew
                                          01-25-2023, 02:23 PM
                                        • trex66
                                          Craftsman 82345 Multimeter broke!
                                          by trex66
                                          My daily carry just stopped working only me. Started last week with the voltage flickering. Found one lead was broken and I ordered new ones. New leads didn't change anything, it displays “-1” on all settings but on continuity will give the tone when touching. Checked battery and found the fuse blown. Replaced fuse but same results. Cleaned the dial and led display and its parts. Board looks nice and clean no burned or broken components. Nothing traumatic happened to this multimeter I put it aside when I found the lead broken and didn't touch it until I got the neAnyone have any ideas what's...
                                          03-04-2025, 04:26 PM
