Bad PSU Thermistors blowing, no multimeter
  • AlwaysCheap
    • Oct 2015
    • 23
    • Hungary
    #41
    Re: Bad PSU Thermistors blowing, no multimeter
    Considering it's a brand new psu it is pretty disappointing . Those caps don't look like they can hold much. Was considering recapping it.
      • 31247
      it should still have some warranty on it.
      • AlwaysCheap
        • Oct 2015
        • 23
        • Hungary
        #43
        Originally posted by eccerr0r
        Generally you might be able to just get another 13N50 clone to see if it works.
        Rohm R5016FNX, ZDX130N50; NTE2939 might work. But I didn't really look at the spec sheets that carefully...
        Yep thanks, searched but they are not available in our stores but I think I found a winner. The volts are a little high at 600V vs 500V and amp value is lower at 12A vs 13A. Gate voltage to source max is +30V which is the same as the 13N50.
        Gate Threshold Voltage - Min: 2V Max: 4V vs 13N50 -Min: 3V Max: 5V
        Here are the specs
        FQP12N60C
        N-Channel QFET®MOSFET 600 V, 12A, 650 mΩ
        https://cdn.badcaps-static.com/pdfs/...943adceeef.pdf
        vs
        13N50 .
        What do you guys think?
        • dj8452000
          How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
          by dj8452000
          I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
          02-18-2025, 08:28 AM
        • BigTroll
          help with home a/c and circuit breaker
          by BigTroll
          while I was gone today the women called me and said the a/c isn't working and the breaker is buzzing so she turned off the breaker. The a/c is a old 1993 model York so its nearing the end of its days, on really hot days the a/c will trip the breaker.
          I visually checked the cap and contactor and they looked okay, I also pulled the 250v ac fuses and switched the main ac breaker on and got no buzz. I did get buzz when I put the ac 250v fuses back in and flipped on the breaker nothing but buzzing. could it be a shorted wire or did the circuit breaker just finally give up the ghost?...
          09-05-2020, 07:53 PM
          Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
          12-14-2023, 07:45 PM
        • davidebaldini
          ATX power supply keeps blowing PFC mosfets — Cooler Master RS-550-ACAA-E3
          by davidebaldini
          This is an ATX PSU rated for 550W powering 24/7 a computer load of about 200W, fed by a line-interactive 1500VA UPS. Mains is 230V.
          1. First issue: the PSU blew a mosfet on what I think is the active PFC boost converter, shorting its G D S pins together causing a short across the + and - lines produced by the rectifier on the 230V mains. The surge protector of the house tripped. When this happened I found that the UPS was unexpectedly disconnected from the wires of its battery. The UPS wasn't damaged, but I suspect this spontaneous detachment of a battery wire caused a condition that blew
          01-25-2023, 02:23 PM
        • trex66
          Craftsman 82345 Multimeter broke!
          by trex66
          My daily carry just stopped working only me. Started last week with the voltage flickering. Found one lead was broken and I ordered new ones. New leads didn't change anything, it displays “-1” on all settings but on continuity will give the tone when touching. Checked battery and found the fuse blown. Replaced fuse but same results. Cleaned the dial and led display and its parts. Board looks nice and clean no burned or broken components. Nothing traumatic happened to this multimeter I put it aside when I found the lead broken and didn't touch it until I got the neAnyone have any ideas what's...
          03-04-2025, 04:26 PM
