Should a transformer live/neutral pins have continuity?
  • mikay786
    • Aug 2014
    • 765
    Re: Should a transformer live/neutral pins have continuity?
    Yea one side has been cut off
      Lots of bad solder joints with crack ring on the solder around the components'legs.
      • mikay786
        • Aug 2014
        • 765
        That is pretty shocking soldering, whwere do you see the ring fracture?
          If you look at STK-XXX IC legs, you will probably see some there too.
          When I work on these I always look through all the boards and redo the joints, and make sure all the board mounting screws are tight because the boards are GND to the chassis with mounting screws.
          • mikay786
            • Aug 2014
            • 765
            measured the two rubycons. One is measuring 48uF and the other 98uF so one deffo dead
            Found one joint on the speaker terminals completely removed from pad taking pad with it looks to be either a grounding or just a support pin perhaps.
            Not impressed with the assembly of the unit, way too much flex in the board and nothing really secure.
              • 31028
              i cant imagine cutting the side off a relay like that just to save a few coins!
              some people are too cheap for their own good!
              • mikay786
                • Aug 2014
                • 765
                Alright changed the capacitors and that relay but still no luck.
                Although I am getting some playback through the headphones but is very low volume and crackly.
                Also when a speaker is wired in to the unit and I plug in the mains power cable the speakers makes a popping noise. Which is more than it was doing before.
                Where should I explore next?
                • SteveNielsen
                  Retired Tech
                  • 2327
                  I'd start with the power amp finals circuit, check caps, resistors and fuses there.
                  Audio boards in general aren't made that well in my experience. Crappy solder joints and weak bond between traces and board are pretty common. Too easy to lift pads and traces with a little too much heat. They often aren't laminated and multi-layered like computer boards are so they flex more too.
                    master hoarder
                    • May 2008
                    • 12175
                    • Bulgaria
                    #29
                    Re-solder all of those joints budm pointed to, and possibly any others you find suspect. Generally, that would be all of the larger components or components mounted on a heatsink.
                    And wow! Who worked on that unit?! Did they by any chance use a hot chisel or something along those lines to solder? Amusingly terrible job at best!
                    • modemhead
                      Lurking
                      • 52
                      For testing, don't use speakers that you care a lot about. Normally a quiet amp will have near zero DC voltage output. A malfunction can cause it to output a significant amount of DC, which can destroy a speaker by heating up the voice coil.
                      • mikay786
                        • Aug 2014
                        • 765
                        Found 5 dead caps so far at the rear of the unit by the terminals
                        FRONT LEFT
                        jamicon 1 - 100v4.7uf @ 5.25uf
                        jamicon 2 - 100v4.7uf @ 5.33uf
                        nichicon 1 - 50v10uf @ 11.3uf
                        elna 1 - 50v0.47uf @ 468nf
                        rubycon 1 - 10v100uf @ 116uf
                        rubycon 2 - 10v100uf @ 113uf
                        jamicon 3 - 50v2.2uf @ 2.5uf
                        MID BOARD
                        elna 10v47uf @ 30uf
                        jamicon 10v47uf @ 15.5uf
                        nichicon 50v4.7uf @ 4.8uh
                        nichicon 50v4.7uf @ 4.9uf
                        rubycon 10v100uf @ 96uf
                        EXPANSION BOARD
                        not checked yet
                        REAR
                        jamicon 4 - 25v330uf @ 281.3nf
                        jamicon 5 - 16v470uf @ 23nf
                        rubycon 3 - 10v100uf @ 113uf
                        rubycon 4 - 10v220uf @ ...nf
                        rubycon 5 - 50v1uf@ 1uf
                        rubycon 6 - 50v10uf@ 11uf
                        jamicon 16v100uf @ 113uf
                        nichicon 50v47uf @ 53uf
                        rubycon 50v4.7uf @ 4.9uf
                        making some headway. Ive tried photographing where everything was and have kept caps separate in sections they were removed from but a bit worried I may misplace them when putting them back in. Does the service manual tell you locations of caps just in case?
                        • mikay786
                          • Aug 2014
                          • 765
                          So in total found a further 5 dead caps (along with 1 earlier), the rest seem ok. I'm using my multimeter which has capacitance tester built in so wont be the most accurate but should be fine to determine if bad or not. 2 in mid board and 3 at rear of board.
                          jamicon 25v330uf - Panasonic FR Series 330uF 25V - http://uk.farnell.com/webapp/wcs/sto...&storeId=10151
                          jamicon 16v470uf - Panasonic FR Series 470uF 16V - http://uk.farnell.com/webapp/wcs/sto...&storeId=10151
                          rubycon 10v220uf - Panasonic FR Series 220uF 10V - http://uk.farnell.com/webapp/wcs/sto...&storeId=10151
                          elna 10v47uf - RUBYCON ML Series 47uF 10V - http://uk.farnell.com/webapp/wcs/sto...&storeId=10151
                          jamicon 10v47uf - RUBYCON ML Series 47uF 10V - http://uk.farnell.com/webapp/wcs/sto...&storeId=10151
                          Are these replacements ok, chose Panasonic FR where I could but they didn't have much selection for the 10v47uf so had to choose rubycon ML Series. Will these do?
                          • SteveNielsen
                            Retired Tech
                            • 2327
                            Usually general purpose caps are used for audio but those should all be fine.
                            When changing multiple caps I write down the circuit designation (ex. c1, c2, c3, etc.) which is printed on the board and the value and voltage of each cap as a guide.
                              • 31028
                              use 16v 47uf then
                              • mikay786
                                • Aug 2014
                                • 765
                                They (Farnel) having no FR FC FM in 16v either. They have 1 FC but not in stock
                                  • 31028
                                  so use 25v
                                  • mikay786
                                    • Aug 2014
                                    • 765
                                    Didn't realise you could go that high so is it safe to go as high as you want on V?
                                    Anyhow replacement caps turned up nice and early, wish me luck
                                    • mikay786
                                      • Aug 2014
                                      • 765
                                      I give up, still no joy. That's about as much time and money I want to spend on this thing.
                                      • cathoderay
                                        Miele cat and dog hs05 vacuum power supply
                                        by cathoderay
                                        Bear with me as this is getting interesting.
                                        Not a lot as the saying goes but it may help someone to decide on throwing it in the landfill or rescuing it.
                                        Symptom no go.
                                        WARNING THIS STUFF CAN BE FATAL IF WORKED ON LIVE. PLEASE DO NOT WORK ON THIS LIVE UNLESS YOU KNOW WHAT YOU ARE DOING
                                        YOU NEED A GOOD VARIAC AND AN ISOLATING TRANSFORMER AND SKILLS. IF YOU DO NOT HAVE DONT TOUCH.
                                        A LOT OF THIS CAN BE FAULT TRACED USING CONTINUITY METER ONLY.USE A 12V CAR BATTERY FOR THE MOTOR TEST WITH AN IN LINE FUSE. 10A.
                                        I'LL RUN THROUGH THE CONTROL BOARD TEST...
                                        05-05-2022, 04:11 PM
                                      • Tarot Superstars
                                        trying to fix a 6V 0.5A T1 (Transformer) AD050120T2 power supply
                                        by Tarot Superstars
                                        Hi. I am trying to fix a 6V 5A power supply that would was used a lot.
                                        I want to fix it partly for learning, and part because I don't want to buy a new one.
                                        It has distinctive smell of burning but not seen obvious burned components yet. I'm not sure where the fuse is.
                                        I tested the only slightly bulged capactitor (out of circuit) and it measured normal capacitance and ESR.
                                        Everything else was tested in circuit with a multimeter.
                                        In circuit tests
                                        I tested the large diodes underside and they seem fine.
                                        I tested...
                                        08-14-2023, 12:45 PM
                                      • mikey5791
                                        Is it possible for transformer substitution?
                                        by mikey5791
                                        Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                                        Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                                        My questions are
                                        1. How do i test to see if the transformer is in good working condition?
                                        2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                                        Hope you guys understand what i was asking. My intention is...
                                        11-03-2022, 02:11 AM
                                      • pandrew
                                        Thinkpad T490 doesn't detect NVME
                                        by pandrew
                                        I have a Thinkpad T490 (NM-B901 Rev 1.0) that cannot detect an NVME M.2 SSD,
                                        but it works fine with a SATA M.2 SSD.
                                        When connecting an NVME M.2 SSD I get while booting:
                                        "2101: Detection error on HDD0 (Main HDD)"
                                        I can continue and boot a live linux distro from a USB stick, but it doesn't show up in lspci,
                                        and I don't notice any relevant error messages in dmesg.
                                        I have tried two different M.2 NVME SSDs (both working fine on a different machine),
                                        and the behavior is the same.
                                        I am pretty sure that all the important...
                                        11-13-2023, 03:04 PM
                                      • spleenharvester
                                        Brother DCP-L2500D - completely dead
                                        by spleenharvester
                                        Hi everyone
                                        I have quite a bit of experience with low voltage circuits but basically none with high voltage circuits outside of recapping. So if anyone could point me in the right direction I would appreciate it very much!
                                        This printer, history unknown, has no signs of life when plugged into 240VAC. It has the LT2988-001 board common to many Brother HL-2XXX series printers. The only physical abnormality observed is a green tint to the positive leg on the main 400V filter capacitor. This model is prone to shorts across the four Schottky diodes but all are testing OK by...
                                        03-01-2025, 08:58 AM
