Brother DCP-L2500D - completely dead
  • spleenharvester
    • Mar 2010
    • 913
    Hi everyone
    I have quite a bit of experience with low voltage circuits but basically none with high voltage circuits outside of recapping. So if anyone could point me in the right direction I would appreciate it very much!
    This printer, history unknown, has no signs of life when plugged into 240VAC. It has the LT2988-001 board common to many Brother HL-2XXX series printers. The only physical abnormality observed is a green tint to the positive leg on the main 400V filter capacitor. This model is prone to shorts across the four Schottky diodes but all are testing OK by diode check on a multimeter. The two main fuses and one thermal fuse all have continuity. The inductors all have continuity. NTC1 measures about 8ohm to neutral when unplugged. Z1 measures no continuity when unplugged.
    Pics attached. Thanks everyone
    Edit - nvm I'm being an idiot there is 330V DC across the large cap, 16V and 3V at the output pins as expected so edited the above. There's a video of an identical case and someone says it's the MIP005 IC so I may try that
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
  • spleenharvester
    • Mar 2010
    • 913
    Found a shorted resistor during testing, replacing it had no effect however. After that I accidentally damaged the board irreparably during testing so I have abandoned this.
      • 31158
      lol
      unless you fucked a transformer anything is repairable
      if you had low voltages but it was running then optocouplers and any 431 voltage reference would be suspect.
      • spleenharvester
        • Mar 2010
        • 913
        I didn't quite clean off the 99% IPA enough before plugging it back in to take more readings and the entire board caught fire momentarily and melted all the connectors haha. Between that and getting several zaps I think I'll stick to repairing lower voltage circuitry for now, clearly it's not for me! Before that happened the FET neighbouring the resistor was looking very suspicious though
        I managed to get a new PS off aliexpress for £22 so hopefully that fixes it
          • 31158
          connectors are cheap and easy to get from junk,
          how much ipa did you use exactly??
          • spleenharvester
            • Mar 2010
            • 913
            Apparently far too much haha
            Replaced the PS with the AliExpress unit today and it fired straight up - for anyone stumbling across this in the future it appears LT3251-001 and LT2884-001 are both crosscompatible with LT2988-001. Unfortunately I can't document what was wrong with the old board as the whole thing started reading short to ground after it caught fire, but I believe it was the large resistor + the FET next to it that were at fault.
            • max-power
              Dell E6540 laptop completely dead after dssasembly
              by max-power
              Hi, I disassemble my laptop to replace the speakers, to access them, you have to remove everything including the heat sink and fan, unscrew the motherboard, lift it up a bit to access the speaker wire.
              that was not the first time I dissasemble it, i did replace the same speaker a few year ago and I repaste it last year, so I had nothing to worry about. but when I put everything back together, its completely dead.
              After a bit of investigating, i found one pin of the status led ribbon cable that was unglued from the cable and bend touching another pin, I bend it back at his place...
              03-24-2025, 08:49 AM
            • wangbreeze
              T480s random shutoff and then completely dead
              by wangbreeze
              Hello Gurus,
              I got a ThinkPad T480s. It was running fine but suddenly started random shut down. When it turned off, I had to push the reset pin to bring it back to life. But it got aggressively worse and became completely dead. No charging light, no life.
              I did some initial diagnostics with just the board (no battery, nothing attached, and no CMOS battery as well)
              Initial testing of the coil resistance seems to indicate no dead short. The only low resistance I measured was at PL701. It reads 38 ohms.
              charger gave - 20V - ok
              U101B
              02-03-2024, 04:57 PM
            • pavski
              Completely dead MSI z490 tomahawk
              by pavski
              Trying to troubleshoot MSI z490 tomahawk board and would appreciate your help. The board is completely dead and shows no activity when the power button is pressed.
              I have tried to look at the Superio, the PSIN signal seems to be correct (goes from 3.3V to 0 on button press) but the voltage on PSOUT pin is quite low. I
              t is only 0.8V which seems to be incorrect but goes to 0 when the button is pressed.
              Can you please let me know if this is indeed incorrect and what else should I look at next?
              Thanks!
              06-02-2024, 02:42 PM
            • Andreasbest
              Lenovo Thinkpad T14s completely dead.
              by Andreasbest
              Hello.
              I received a T14s Gen1 ( NM-C891 motherboard ) that is completely dead, no indication of life at all.
              I tried hard reset without RTC battery and short both pins of it for 1 minute but no luck.
              Since it's type C connector i have no idea what to measure or where to inject voltage, so any advice are welcomed
              Thank you in advance!
              Schematic & boardview -> https://www.badcaps.net/forum/troubl...cfc-nm-c891-sc...
              03-19-2024, 03:18 AM
            • armini
              18VDC PSU completely dead - ZD-915 desoldering station
              by armini
              Hi everyone!
              Three years ago I got a ZD-915 desoldering station which failed just after a few months of light use. During a short desoldering session, the station simply shut down, and since then it has been completely dead and unresponsive. The failure was silent, without any pops.
              Due to a lack of time, I set it aside and didn't look at it.
              Yesterday, I took it apart and did some basic measurements. The 18v terminal shows 0v. In addition, there is no visible damage to the board itself.
              According to replies in 18VDC PSU has dropped to...
              04-25-2023, 07:49 AM
