Channel Well CWT-450BDP
  • JEWilson
    • Sep 2007
    • 369
    • Scotland, United Kingdom
    Hi
    This PSU had the ATX 2x10 pin replaced
    Have tested it with two types of PSU tester (for what that's worth) and
    everything appears to be ok.
    I did open it up to see if ok. Seems no problems apparent.
    What are the views of forum members - are these any good?
  • linuxguru
    • Apr 2005
    • 1564
    Re: Channel Well CWT-450BDP
    Channel-Well usually has Fuhjyyu caps, and they're among the bad brands. If it hasn't already failed, it will fail, usually sooner than later. However, they should be OK if you replace the caps with the recommended Japanese replacements.
    • Spacedye69
      • Nov 2005
      • 698
      • US
      Why was the ATX connector replaced? If it was burned or melted, I would check/replace the caps before plugging it in to anything too important.
      • Oklahoma Wolf
        • Dec 2005
        • 353
        This unit is pretty much the same as the Antec SL450, though if memory serves the P indicates it has active PFC. Eventually, it will have problems with those Fuhjyyu caps - CWT builds of this era rarely escape the issue.
        • JEWilson
          • Sep 2007
          • 369
          Y - twas burnt on two pins on the ATX 2x10 plug
          I will be replacing the output filter caps as a matter of course
          Thanks for the input.
          My enquries were simply to establish whether (not) it would be useful
          to keep or put in a box for my bothers kids
          Err.... will be opting for the latter option
          • JEWilson
            • Sep 2007
            • 369
            Ok, after a further inspection, I have found;
            Electrolytics Only
            In the primary;
            2 of Black 470 uF 200 V CapXon 85 deg C - H 25.4 mm x Dia 25.4 mm
            1 of Black 10 uF 50 V Unknown KM 85 deg C - H 10 mm x Dia 8 mm
            In the switcher;
            1 of Black 22 uF 50 V Fuhjyyu TNR 105 deg C - H 10 mm x Dia 5 mm
            1 of Black 17 uF 25 V Fuhjyyu TNR 105 deg C - H 10 mm x Dia 5 mm
            In the output filter;
            2 of Black 1 uF 50 V Fuhjyyu TNR 105 deg C - H 8 mm x Dia 3 mm
            2 of Black 10 uF 50 V Fuhjyyu TNR 105 deg C - H 10 mm x Dia 5 mm
            1 of Black 820 uF 16 V Fuhjyyu TNR 105 deg C - H 20 mm x Dia 8 mm
            1 of Black 3300 uF 6.3 V Fuhjyyu TNR 105 deg C - H 33 mm x Dia 8 mm
            1 of Black 3300 uF 10 V Fuhjyyu TNR 105 deg C - H 25.4 mm x Dia 8 mm
            1 of Black 3300 uF 16 V Fuhjyyu TNR 105 deg C - H 30 mm x Dia 8 mm
            2 of Blue/Purple 1000 uF 10 V Fuhjyyu TMR 105 deg C - H 20 mm x Dia 8 mm
            1 of Blue/Purple 2200 uF 16 V Fuhjyyu TMR 105 deg C - H 30 mm x Dia 8 mm
            1 of Blue/Purple 4700 uF 10 V Fuhjyyu TMR 105 deg C - H 38 mm x Dia 10 mm
            1 of Black 330 uF 16 V CapXon deg C - H 20 mm x Dia 5 mm
            1 of Green 1 uF 50 V CapXon deg C - H 8 mm x Dia 3 mm
            The rest as far as can I determine, are bead type caps
            What are the recommendations for replacements excepting
            obviously they require to be 105 deg C and the same can sizes (where or if possible)?
            Thanks for your consideration
            • Super Nade
              • Jun 2006
              • 294
              Holy hell man, replace everything! That is a time bomb waiting to explode.
              My choices would be:
              Nippon Chemicon KMQ on the Primary.
              United Chemicon KY, LXY and KMG everywhere else.
              I'm recapping a similar unit. A small, quick and dirty blurb I wrote for overclockers.com should be up by the end of the week.
              Q6700 @ 3.6 GHz
              Zippy GSM-6600P
              Curcial Ballistix PC6400 (4 x 1Gb) Micron D9GMH
              Abit IP35Pro
              ATi HD4870
              • linuxguru
                • Apr 2005
                • 1564
                It's sufficient to replace everything over 470uF - the smaller caps usually don't fail or aren't critical. The one exception to this rule could be the 47uF/25v or the 22uF/50v on the primary side, depending on the topology/location. If it's right next to the auxiliary transformer and is being directly charged by a fat (1A to 3A) fast-recovery rectifier from the auxiliary flyback transformer, that cap needs to be replaced too - it can't handle high flyback ripple currents for too long. Something like a 100uF,35v NCC LXA/LXF/LXJ/LXV/LXY/LXZ should be OK there.
                • JEWilson
                  • Sep 2007
                  • 369
                  Got round to replacing the caps in the O/P filter of this PSU.
                  I have been able to squeeze in the new Panasonic FCs with the
                  exception of the 4700uF 10V which I seem able to get only in 12.5mm dia.
                  I have had a look around for a cap of this value with a 10mm dia., can't
                  seem to source any.
                  What do members recommend?
                  There is no way the 12.5mm dia. FC will squeeze in there... argh!
                  • gonzo0815
                    • Feb 2006
                    • 1600
                    Replace with a 4700uf 6.3v or 3300uF 6.3v. May be Big Pope can supply you that a large cap in 10mm.
                    4700uf 10mm is simply not a standard value and you probably won`t get it from any other source in small quantity.
                    • Big Pope
                      Approved Vendor
                      • Dec 2005
                      • 426
                      Agree, i haven't seen any 4700uF 6.3V/10V in diameter 10mm for reputation brands. There is also very rare for 3300uF 10V/16V in diamter 10mm, we can't source it from the market, except custom made.
                      Recently, i have ordered some custom made 3300uF 10V/16V in D10 x 30mm (Samxon RS Series) for power supplys. Please contact me if anyone want to try outside US/Canada. If you are in US/Canada, please contact Top Cat (owner of this forum) directly.
                      My SAMXON Capacitors Database HERE!!
                      X-CON is a new brand for SAMXON's Polymer Capacitors.
                      • JEWilson
                        • Sep 2007
                        • 369
                        Ok
                        I do have a Panasonic FC 3300uF 10V in 10mm
                        I will try that first
                        • JEWilson
                          • Sep 2007
                          • 369
                          OK
                          Recap done and tests with the go/no-go tester appear ok
                          Next thing to do is to repair the 20-pin ATX connector
                          What tools do I need?
                          Simple thing to do would be get a new ATX connector and
                          crimp tool.
                          Where could I get these?
                          Would anything else be required?
                          Please advise
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            I'm working on a different PSU but it also has the 4700uF 10v TMR Fuhjyyu craps.
                            They are rated (supposedly) for 1580 ripple and .038 ESR.
                            I'm replacing with 3300uF 6.3v MBZ at 10mm
                            The MBZ's ripple is 2800 and ESR is .012
                            They should more than handle it even with the reduced uF.
                            [And they fit.]
                            Mann-Made Global Warming.
                            - Dr Seuss
                            • starfury1
                              • May 2006
                              • 1256
                              Just stating the obvious here really I suppose
                              Humm well from posts I read PCBONEZ I suppose its possible the FU's are @ those values used, to compensate for being crap.
                              As you well know the cap uf is nominal anyway by 10's of %
                              So yeah using somewhat near the same but better quality caps should equate to around the same (if not in some respects better) operation.
                              (although that little extra capacitance doesn't go astray)
                              sure there might be slight degradation but doubt it would be much to worry about unless you are possibly driving it really hard
                              Are you intending to do some load testing measurements on it?
                              keep us posted on how it goes anyway PCBONEZ
                              Cheers
                              You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
                              • PCBONEZ
                                Grumpy Old Fart
                                • Aug 2005
                                • 10661
                                Oh come on.
                                The 4700uF is a bogus value.
                                Even 3300uF is over-kill.
                                Someone in here recently pulled some 4700uF Fuhjyyu and measured them at something like 1300uF.
                                In most PSUs you see 1000uF to 2200uF caps in those positions on those rails and a lot of the time they are single caps not two in parallel.
                                If you borrow the formula from the AMD and Intel design guides for bulk capacitance and ESR, use the typical 2 usec, the full amps on the rail, and .050v for the transient, and the supposed ESR for the Fuhjyyus then it comes out to anything more than 1625uF on the 5v and more than 1296uF on the 3.3v is adequate. With the lower ESR of the Rubycons it needs even less capacitance. - I know that's not what that formula is in the guide for but in this situation it's calculating the same thing so it works.
                                - Dr Seuss
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  That's for the PSU I am working on which is 40 amps on the 5v and 32 amps on the 3.3v.
                                  It will be a while to get results. Still have to order some of the caps for it (them) and they aren't not on the hot projects list just yet.
                                  - Dr Seuss
                                  • JEWilson
                                    • Sep 2007
                                    • 369
                                    Whereas PCBonez has made a vaild point, the matter of cap replacement
                                    (for me) is simply attemting to accomodate the requirements of end users.
                                    So far as a user may opt for a recap;
                                    As rule of thumb, try to replace badcaps with better at an equivalent
                                    value. There are, of course, problems here so far as acommodating
                                    the can size of better caps at the same value is not problem free.
                                    Yes, I have been advised given such circumstances as above, to
                                    use a preferred brand at a smaller rating. Even so, end users
                                    tend to figure for the money they are paying - it's like for
                                    like in the capacitor stakes and do not immediately grasp (even
                                    when shown) the difference between a Panasonic FC 4700uF 10V
                                    and a 4700 uF 10 V Fuhjyyu TMR.
                                    But fora such as these do definetly help in that regard
                                    • PCBONEZ
                                      Grumpy Old Fart
                                      • Aug 2005
                                      • 10661
                                      JEWilson
                                      Exactly.
                                      When ever possible use the same specs or better as the original:
                                      Same uF or a bit higher if you must.
                                      Same volts or a bit higher if you must.
                                      At least as much ripple capacity.
                                      Same ESR or lower.
                                      I stick to that when ever possible but there are times that won't work.
                                      - No data for the old caps.
                                      - No replacement caps exist from a reliable manufacturer.
                                      - The existing caps are not original and are wrong.
                                      In these cases you have to look at what is typically found in that application in other similar equipment and maybe do a little math.
                                      The PCB I'm working on has 2 x 10mm in parallel on each the 5v and 3.3v outputs with zero room for larger diameter caps. [I could probably FORCE 12.5mm in there but there would be zero airflow around the caps, crimped wires, and a good possibility of creating a ground.]
                                      Unfortunately good brands in 10mm over 3300uF do not exist.
                                      The options are:
                                      - Mount larger caps remotely and run wires to the PCB. (Not likely.)
                                      - Use the best 3300uF 10mm caps I can find. <- chosen path.
                                      - Use a single cap in place of the pair (they are in parallel) that matches the combined ratings of the pair. (I looked.) To get there at 2x4700uF(min) and the combined Ripple capacity and ESR I'd have to go to a 16mm 10,000uF cap in HE or better. One 16mm -might- fit but I can't be sure.
                                      - Use a 12.5mm and an 8mm in parallel. Might work but I'm concerned the mismatch will cause the bulk of the load to shift to one cap an overheat it.
                                      - Dr Seuss
                                      • spleenharvester
                                        Reverse engineering of 18650 4-channel tester
                                        by spleenharvester
                                        Hi friends
                                        I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                                        05-04-2025, 02:43 AM
                                      • eccerr0r
                                        old X58 triple channel board... memtest86 memory speed?
                                        by eccerr0r
                                        Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                                        Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                                        Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                                        06-28-2025, 09:06 AM
                                      • dicky96
                                        American Audio VLP1500 Distorting on one channel
                                        by dicky96
                                        Hi guys I have a VLP1500 amplifier here - one channels works fine and the other channel distorts even at low volume settings
                                        Protection and Clip LED are off
                                        There is something wrong with the BIAS voltages around T16 and T18 (in particular) on the bad channel
                                        I tested all diodes and transistors in this area in circuit with diode mode - both channels seem identical. Same in resistance mode across all the resistors here.
                                        The output DC voltages on pin1 and pin8 of the 5532D dual op amp at the input of each amplifier module are the same, and the audio...
                                        07-13-2022, 05:25 AM
                                      • dicky96
                                        Hitachi V19B01922 Channel Tune problem
                                        by dicky96
                                        Hi Guys
                                        I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
                                        He also has an LG TV, so three screens in the bar
                                        I installed three Satlink ST-6503 DVB-T Modulators
                                        This model https://www.aliexpress.com/item/32916553905.html
                                        These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
                                        02-09-2023, 09:20 AM
                                      • sima112
                                        Marantz pm 6005 right channel not worknig
                                        by sima112
                                        Hi guys,
                                        I need a help with my Marantz pm6005. It started to have weaker the right channel a few months ago, than it got back to normal and now it has lost sound completely on the right channel. At the final stage it was loosing the channel for a while and than it returned. After it has disappeared completely I could forced it back by unplugging the source form CD (which I normally use) to phone and back. It would then work for a few minutes and died again. Now it is possible power up and all function works normally (apart the right channel ) on all inputs, except the phone both channel...
                                        01-30-2023, 12:11 PM
