Reverse engineering of 18650 4-channel tester
  • spleenharvester
    • Mar 2010
    • 921
    Hi friends
    I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board instead of the cell holders (e.g. to test 21700 cells) you can do so. You can set the discharge voltage cut-off between 2.5V and 3.5V in increments of 0.1V.
    Here is a backside pic of the board with the base removed:
    Here's some info on how it works:
    Power: Two USB-C ports at 5V. Only VBUS and GND are electrically connected so USB-PD chargers will not work. The device can run from either port and is protected from reverse current by a schottky on each VBUS, but if you only plug in one cable then charging will not work on the opposite side (i.e. if you only plug in the left side USB-C port then the right two channels will not charge, and vice versa).
    Charging and discharging: Each channel has a PW4056HH battery charge controller; a 3R9 10W bleed resistor; a pair of 8025A dual N-channel MOSFETs; and other associated components. The first 8025A is on the negative end of the bleed resistor and is gated by the MCU to begin discharging. The second 8025A is on the positive end of the bleed resistor and serves as reverse polarity protection. The bleed current is maintained at a continuous 1 amp.
    Cooling: The bleed resistors are actively cooled by a 5V 4010 fan. This is temperature controlled by the MCU based on a thermistor on the rear of the board between the bleed resistors.
    Logic: A CD4051B analog multiplexer is used to sense voltage and current. IR is sensed a moment after a cell is inserted, probably by taking measurements either side of a load pulse. A 74HC595 8-bit shifter is used to control each charge enable pin, and to drive the status LED for each channel. The MCU has no inscription whatsoever but based on its pinout appears to be an 8-bit Nuvoton N76E003AT20 or a clone of it.
    Regarding reliability, it has performed well - I have 3 of these devices, and have tested about 200 cells across them over a combined 300 hours or so runtime. Two faults have occurred during this, one being a noisy fan bearing and the other being a worn out tactile switch.
    Regarding accuracy, it does a much better job than my XTAR VC4, which I returned because it was wildly overestimating capacity. For brand new cells it gives capacity values within defined ratings. Out of 100 salvage cells from 19 packs there were 15 identified as deviating in capacity (relative to the rest of the pack) - when retested only 3 of these 15 cells differed significantly from their first test (100mAh or more). I have compared the results of a single cell multiple times in the same channel; a single cell in multiple channels within the same system; and a single cell across the three I own and the results are reproduceable. I'm unsure how accurate IR is, it varies a bit if you re-insert the same cell multiple times, but it is good enough to discriminate a good cell from a bad cell. For voltage, it does vary +/-0.03V from my Klein MM450 multimeter sometimes but it is generally fine.
    Hope this helps someone
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
    • Jul 2011
    • 6069
    I have seen these on eBay and wondered if they were any good or not
    From what you have here it seems to be decent I like the fact that you can adjust the voltage value in discharge mode
    What about charging mode what is the voltage range on this setting
    Is there any thing that functions flake on this device locking up and refusing to do anything or freezing up while testing mode or anything else that you should be aware of
    • spleenharvester
      • Mar 2010
      • 921
      Charging mode doesn't give you a cut off unfortunately, it will either go to 4.2V or it will cut off lower than that if the battery is refusing to take further charge.
      I haven't had any issues software wise they've been perfect
      Just noticed I didn't actually upload the schematic, here it is
        • Jul 2011
        • 6069
        If this the case then this battery charger can not handle Lipo 4 battery cells interesting enough this is not for me unfortunately but thank for your review unless I need a fast charging battery charger
          EBC-X 8-Channels 18650 Battery Capacity Tester Charge & Discharge 10A Aging Test Modificatio
          This is another battery testing machine that needs to be modified for the cooling fans because these are noisy but not as bad as one of the other battery testing machines that I had modified recently because of it being too noisy
          The battery testing machine is going to get two temperatures controlled cooling fans like one I put in the other battery testing machine I just have to remove the temperature sensor and relocate the temperature sensor to one of the heat sinks and put one on the other heat sink so the fan speed can be controlled by temperature
          https://www.eb...
          05-05-2024, 06:07 PM
          This is the new EBC-X 8-Channels 18650 lithium Battery Capacity Tester that I bought
          I had the battery testing machine for about month or so and finally found a home for all of it to be together in one place
          The battery testing machine is on the top the thing is the self for the batteries testing
          The computer is on the very bottom of the cart with a power strip in the back/side of the cart
          I also have another battery testing machine that is very big as well and I going to buy another cart for this one as well but I have to make a face plate for that one because it is not like this one where it is setup to be put on a cart...
          09-02-2022, 01:16 PM
        • Dev Goose
          Help Needed: Reverse Polarity Issue on HP EliteBook 840 G4 – Where Do I Begin?
          by Dev Goose
          Hi everyone, I recently acquired an HP EliteBook 840 G4 (6050A2854301-MB-A01) that I'm hoping to bring back to life. I'm fairly new to laptop repairs but eager to learn and willing to put in the effort to understand and fix this. Any advice or guidance would mean a lot!
          What Happened
          The issue started when the laptop was accidentally plugged in with reverse polarity. Before this incident, the laptop would show a power/charging light whenever it was plugged in. However, now it's completely unresponsive—no lights, no power, nothing. I've been doing some research and understand
          12-13-2024, 03:13 AM
        • howardc64
          Don't probe Samsung LED conector with LED tester, connect may not make contact afterwards
          by howardc64
          Samsung have been using this style LED connector for few years now
          Usually good idea to test the LEDs before opening the panel to change them. I do this without the PSU stil connected. With this connector (white one) have to jam the LED tester probes in the very narrow thin slot where the PSU blade style male prong inserts into. I've done this on many Samsungs without problem until today...
          The female terminal inside the white connector has fragile fingers that grabs onto the male blades on the PSU's black connector. If the LED tester probe spreads open...
          Today, 08:13 PM
        • Lifeisfun
          Trying to troubleshoot DDR4 SODIMM slot with slot tester
          by Lifeisfun
          Hi folks!
          I have some kind of memory problem on Lenovo laptop. I was initially able to install windows after several tries since the laptop did freeze in middle of those attempts.
          Eventually I discovered that it was related to moving the laptop.
          Later on it even stopped booting unless I pressed around the memory slot. (no keyboard LEDs only power button responds)
          If I remove the RAM I get the beeps that RAM is missing. Inserting the RAM there is silence and it will not boot most of the time. No picture.
          I removed the board got one of those memory slot testers...
          06-04-2025, 02:26 PM
