Hitachi V19B01922 Channel Tune problem
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Hi Guys
    I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
    He also has an LG TV, so three screens in the bar
    I installed three Satlink ST-6503 DVB-T Modulators
    This model https://www.aliexpress.com/item/32916553905.html
    These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to different names for each channel, and of course on different frequencies.
    When I select a digital auto-scan on the LG, it finds all three channels and they work very well.
    When I select an digital auto-scan on the Hitachi, they also both find three channels with the correct channel ID but then you only get one channel in the channels list (channel 800) from the first modulator that if found, the lowest frequency one, and there are no other channels 801, 802 etc so you can't change to the other channels.
    If I do a manual digital scan, whichever UHF channel I select scans in OK and I get that one channel - so all the signals are OK
    The same thing happens on both Hitachi, slightly different models/screen size
    I must be doing something wrong because both TVs can't have the same fault, surely. When I do an auto-scan I select the option to clear the existing channels list so it can't be some old channels data messing it up, or so I would think
    Any suggestions?
    Rich
    Follow me on YouTube
    Learn Electronics Repair
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Re: Hitachi V19B01922 Channel Tune problem
    Nobody~??
    • rustinjust
      Advice needed-Technika 32-207 works but sticks on channel,won’t change channels ok
      by rustinjust
      My tv will work for a while and change channels with the remote as it should but then it will stick on one channel only and work ok but it won't change channels. I have tried unplugging it for hours and whilst unplugged pressing the power button on the tv to reset it.
      The volume button on the remote still works but it just won't change channels once it decides to stick on one channel
      It has built in basic freeview tv here in the uk, I've tried doing an automatic search to reset the tv but nothing works.
      I have to turn the tv off and then on again with...
      09-28-2023, 12:23 PM
    • dicky96
      I need to block a UHF channel but not sure how to do it
      by dicky96
      Hi guys
      I couldn't really find a section on the forum for this question so I guess I will put it here
      I do a lot of work in one of the local apartment hotels (an apart-hotel they call them here)
      Mostly I am maintaining the equipment in the 'TV' room or at the pool bar
      Anyway, I have a problem with the system in the TV room - most of this was a system I 'inherited' off the previous technician who no longer lives on the island
      Basically they have (see pic it probably explains it better) the following system. The UHF cabling is daisy chained...
      01-31-2022, 05:24 AM
    • sima112
      Marantz pm 6005 right channel not worknig
      by sima112
      Hi guys,
      I need a help with my Marantz pm6005. It started to have weaker the right channel a few months ago, than it got back to normal and now it has lost sound completely on the right channel. At the final stage it was loosing the channel for a while and than it returned. After it has disappeared completely I could forced it back by unplugging the source form CD (which I normally use) to phone and back. It would then work for a few minutes and died again. Now it is possible power up and all function works normally (apart the right channel ) on all inputs, except the phone both channel...
      01-30-2023, 12:11 PM
    • Logistics
      Supermicro X10DAX and Quad Channel
      by Logistics
      So my dilemma is that I can't seem to get my board to run in Quad Channel. I have an X10DAX with Dual E5 2690 v3's and originally it had four 16GB sticks of Samsung ECC. Figuring I needed to have a stick for each DIMM1 slot I purchased four more identical sticks of Samsung M393A2G40DB0-CPB. So, now I have eight 16GB sticks for a total of 128GB of RAM. When I install the ram so that Each DIMM1 slots is populated the system will not post even if I clear the CMOS, remove the battery, what-have-you. But according to what I'm reading in the Manual, which is admittedly not very clear, populating each...
      09-10-2023, 05:12 PM
    • CDNBrewer
      Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
      by CDNBrewer
      Hello Everyone,
      I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
      Symptoms:
      • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
      • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
      • I swapped the Left and Right surround
      08-05-2025, 09:29 PM
