Hard Drive Power Supplies
    Re: Hard Drive Power Supplies
    jameco.com:
    http://www.jameco.com/webapp/wcs/sto...0001_323505_-1
    http://www.jameco.com/webapp/wcs/sto...0001_323425_-1
    http://www.jameco.com/webapp/wcs/sto...0001_323362_-1
    • mariushm
      • May 2011
      • 3799
      Can't really compare a TDK power supply with a Meanwell. Yeah, meanwell will work, but with a lousy efficiency and potentially high ripple on outputs.
      If you go that route, you could just as well pick the 14$ special on newegg, a shitty logisys : http://www.newegg.com/Product/Produc...16&ignorebbr=1
        Meanwell spec
        • mockingbird
          • Dec 2008
          • 5484
          Sorry to bump an old thread, but I came across another variant of the Yu Feng, and it is almost completely identical to it except that this one has a brown PCB and all Capxon caps (KM and KF).
          The soldering of the underside of this one is a lot cleaner, and this one has "23-11056-00 REV. A" written on it.
          The datecodes on the caps indicate this was made in the beginning of 2005.
          • kaboom
            "Oh, Grouchy!"
            • Jan 2011
            • 2507
            Originally posted by goontron
            mine developed a primary to secondary short and zapped the living shit out of me today. found carbon traces on the underside of the board.
            Interesting. This confirms there is no secondary-to-EGC bonding. Which means when they fault while connected to the computer, the USB cable does fault duty. If the EGC were connected to the secondary common, [i]as it is in every by-code power supply," all that would've happened is either the carbon traces burn clear, or the fuse blows. And that assumes the fuse in in the hot wire.
            Who wants to guess that the induced voltages on the USB pair don't kill the host controller?
            I actually borrowed one of those SATA/IDE->USB things after I couldn't use the SD card reader on a semi-trashed shitsta system. Someone working at the same place also does networking. I told him about those power supplies, but all I got was "It's fine for backups."
            I go back there this weekend and will have to print this thread and leave it. It confirms my suspicions that the "three-wire" AC cord is only for "show."
            They're as bad as the fake apple chargers as far as shock hazard...
            "pokemon go... to hell!"
            EOL it...
            All style and no substance.
            guilty,guilty,guilty,guilty!
            guilty of being cheap-made!
            • goontron
              5000!
              • Dec 2011
              • 4108
              • US
              #26
              well, since the thread was dug up...
              This is the Unit i use now to power drives externally. It came out of a well built HP tape drive.
              Notice the proper isolation and air-gaps, duely optocouplers, thick secondary traces, and good filtering all around. It doesn't disconnect the primary to shut off, it just kills the primary switchers, so that heatsink on the primary switcher is always live. (i learned that the hard way) No brown gorilla snot here! Only issue i have with it is crap caps, but its not enclosed and doesnt run hot, so im not too worried..... HP drove the tape motor from 5V, can you tell?
              Follow the white rabbit.
              • kaboom
                "Oh, Grouchy!"
                • Jan 2011
                • 2507
                Betcha won't do that again...
                5.5A on +5, maybe...
                EOL it...
                • goontron
                  5000!
                  • Dec 2011
                  • 4108
                  • US
                  #28
                  ahh, better for running laptop drives!
                  • mockingbird
                    • Dec 2008
                    • 5484
                    #29
                    Just a heads up, there have been HDDs spotted in the wild that require 3.3V.
                    So the ideal HDD adapter would have 12v, 5v, and 3.3v, and two connectors, one SATA power, one molex.
                    • goontron
                      5000!
                      • Dec 2011
                      • 4108
                      • US
                      #30
                      sigh, i will rig something up.
                      • kaboom
                        "Oh, Grouchy!"
                        • Jan 2011
                        • 2507
                        Severe RFI from one of these turds:
                        http://www.eham.net/articles/34513
                        As soon as I saw them on ebay and newegg a few years ago, it was obvious they'd be causing trouble.
                        The missing filter sections, on the line side, are important.
                        So in addition to shock hazards from carbon tracking/untrimmed leads and no EGC bonding to the secondary common, they also function as "RFI generators," disguised as power supplies...
                        Or, cow pies, disguised as power supplies.
                        FWIW, a few days ago, I crushed a Raidmax under my foot- output leads all labeled #20AWG, but probably were ~#21AWG. +3.3 had no magamp and shared the common inductor with +/- 5/12. No pi-sections on the outputs. Ceramic y caps instead of proper ones, missing line-side filter sections. AC rectifiers were two 4005s and two of something between those, and 2A05s. Bigger than a 400x, but not quite a 2A device.
                        And, by the way, it also needed caps. To coin a phrase, "Jee Saturn, Fuhjyi-yoo!"
                        That junk was gone. It'll never have the potential (!) to stress (kill?) another system... At least it was now "ultra-small form factor."
                        EOL it...
                        • goontron
                          5000!
                          • Dec 2011
                          • 4108
                          • US
                          #32
                          ok, mine developed an issue. it pulses on switch one then eventually starts. Thats a startup cap issue right?
                          • kaboom
                            "Oh, Grouchy!"
                            • Jan 2011
                            • 2507
                            10-22u, 50V, near the SMPS IC, likely a cheep submini electro. Probably right by the transformer. You can use anything from 10-47u, 50V. It's quite possible that the aux voltage is nowhere near that; a 25 or 35V cap could work, but either measure it or find out what voltage the SMPS IC clamps it at. Some have an interal shunt reg, that limits the voltage across that cap- it's fed thru a resistor after the aux rectifier/winding.
                            And if you're going to change the O/P caps, why not do a before-and-after scope 'n load test?
                            If you have a scope, that is...
                            I'm betting you've got well over a volt of ripple on +12, even at 1A. More if there's no pi-filter.
                            Don't forget to bond common to the EGC and rewire the AC input, putting the fuse in the hot, where it belongs.
                            EOL it...
                              • 31066
                              maybe.
                              or bad solder joints.
                              • CapLeaker
                                Leaking Member
                                • 8195
                                either a bad starting cap or bad solder joints. Some are really hard to find. Read this thread:https://www.badcaps.net/forum/showthread.php?t=47479
                                I finally found it with my hot air soldering station.
                                Norstar: 0
                                CapLeaker: 1
                                • goontron
                                  5000!
                                  • Dec 2011
                                  • 4108
                                  • US
                                  #36
                                  remember, this isnt one of those cheap units. Its an HP tape drives internal PSU. EGC is already bonded, has fuse, pi-filter, etc. i will look for bad soldering and replace that cap.
                                  I have tested the output caps. one was bad, and i replaced it.
                                  • kaboom
                                    "Oh, Grouchy!"
                                    • Jan 2011
                                    • 2507
                                    That's what I get for ass-u-me-ing..
                                    EOL it...
                                    • goontron
                                      5000!
                                      • Dec 2011
                                      • 4108
                                      • US
                                      #38
                                      that light green one has a black marking on the top. i put that there because it wasn't out of tolerance, but it was high, its graphite. It looks like its just doing filtering and with a rating of 1500uF i'm going to replace it with a 2200uF anyway. Lets see how it does with new low value caps!
                                      • goontron
                                        5000!
                                        • Dec 2011
                                        • 4108
                                        • US
                                        #39
                                        No dice. still does it.
                                        • kaboom
                                          "Oh, Grouchy!"
                                          • Jan 2011
                                          • 2507
                                          Resolder the pins on the TX primary side, and also replace the diode feeding the cap for the PWM IC.
                                          Don't check and assume it's good- they can get fussy til they warm up.
                                          Back in the late 90's, I fixed two of those "Packard Bell" Pixie monitors.
                                          +12 was missing for about 20 minutes after a cold start and supply was cycling. Degauss relay was powered by that same +12, so it would click too.
                                          I fed +12 in from a seperate supply and it came to life. First I changed the cap- no change. Then I isolated that feed and checked for shorts. No shorts.
                                          For testing, I replaced the schottkey with two 1N4004s. They got warm (hot?), but unit now worked.
                                          All was well after a new TO-220 schottkey; cap was still OK.
                                          EOL it...
                                          • federalhouse
                                            **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                                            by federalhouse
                                            I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                                            **Background:**
                                            I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                                            **What I've Tried So Far:**
                                            1. I accessed
                                            08-01-2024, 07:03 PM
                                          • ash91
                                            Hp pavilion 15 not detect hard drive
                                            by ash91
                                            Hello gentelmen .... this is my first post and sorry for my bad english,
                                            so my proplem is my laptop keep losing hard drive even if i but the
                                            hard disk in the cady (the box that can replace the dvd rom with hard disk)
                                            when i turn the laptop on the massage that said no boot media found pop on
                                            the hard disk is fine and to be sure i try another hard
                                            i also update my bios to the last update
                                            the 5 volt is present on the hard connector on the motherboard
                                            the dvd rom work fine when i but a windows dvd in it
                                            also when i boot from flash...
                                            06-07-2023, 01:45 PM
                                          • madura2010
                                            DAY11AM6E0 hard disk drive and optical disk drive not detected
                                            by madura2010
                                            Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
                                            i checked the connectivity of ribbon=good communication with hard and motherboard
                                            changed hard disk and checked=3f0 error persist
                                            sata power=+5v available
                                            Then checked data capacitors=all good
                                            Then checked data lines path connectivity to pch=all good
                                            reflashed...
                                            03-12-2023, 09:09 AM
                                          • odie34
                                            Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
                                            by odie34
                                            I am a hobbyist (not a professional) so please be gentle...
                                            I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
                                            I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
                                            02-18-2024, 09:11 AM
                                          • tmcw
                                            PC case - Hard drive rails
                                            by tmcw
                                            A friend gave me his old PC case (with MB, and PSU), but no hard drive rails, he said he only used the 2.5" SSD spot inside, and used an external hard drive for data. He said that he'd have a look for the supplied rails, but I doubt he'll find them.
                                            So I was wondering if case manufacturers used any type of standard 3.5" hard drive rail?
                                            I'm used to the various Dell hard drive caddies or rails (and HP and Lenovo to a lesser extent), or el cheapo cases where you screw through the frame to fix the drive.
                                            Now, the case is a CiT Gaming Case, and...
                                            05-22-2022, 12:04 PM
