Antec 350 Recap Epic Fail
  • bigbeark
    • Jan 2010
    • 661
    Re: Antec 350 Recap Epic Fail
    Originally posted by larrymoencurly
    I did the exact same thing with an original version 300W or 350W Antec SmartPower, which also used high voltage MOSFETs, but after I unplugged the AC and plugged it back in (after installing the case top), the PSU worked normally. Neither fuse blew (this design had 2).
    I haven't had too many MOSFETs fail on me, but every one that did had a short between the gate pin and the other pins, regardless of which direction the meter leads were connected.
    I've read that the heatsink is connected to 170VDC in order to provide shielding from RF and to make it safer than connecting it directly to ground because sometimes there's no earth ground. The only grounded heatsinks I've seen were in the low voltage section of the PSU, namely in FSP (Fortron-Source Power) brand products.
    Thanks for this reply, I think I can safely assume that the primary heatsinks on this PSU are "live" when the PSU is plugged in, courtesy of the bridge rectifier, which allows current to flow between legs of the rectifier. Since the negative leg of the rectifier is connected to the same line as the heatsink ( visible on the back of the PCB), current will flow to the heatsink whenever the PSU is plugged in.
    Or, to simplify, never plug the PSU in with the top off!
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      Originally posted by ben7
      Because the switch is off, that does NOT mean there is no voltage in the circuits. It likely was a N-GND short, or possibly they messed up big time and put the switch on the neutral, so the components are always live (on hot wire)
      Originally posted by goodpsusearch
      Imagine your finger conducting the primary heatsink and the case... Yeah that happened to me... It was an Antec Smartpower 450 and the switch was at the off position but it was connected to neutral..
      Isn't the switch mandated to cut both Live and Neutral?
      Here in Sweden and the majority of Europe the Schuko plug is used which is not polarized, meaning our AC plugs go in both ways, so we can flip the live and neutral in any equipment.
      • goodpsusearch
        • Oct 2009
        • 2850
        • Greece
        Same here. The problem is that the switch most psus have only cuts 1 of the 2 lines.
        • Behemot
          • 4845
          • CZ
          I also worked as conductor once, between two heatsinks of one Enhance made Chieftec. BOTH, primary AND secondary are live, so fortunatelly there has been just like 160 V between them. Strange is, SP and my Chieftec are made by different manufacturers (CWT vs. Enhance) and yet they both use the same stupid topology?
          As for grounding, on every other PSU I have seen so far I am almost sure the heatsinks were grounded. If rubber pads break, it shorts the PSU and it does not power on. Not that I have ever seen damaged pads between package and heatsink…
          • Pentium4
            CapXon Be Gone
            • Sep 2011
            • 3741
            I'm recapping a similar SmartPower and want to replace the Fuhjyyu input caps, which I'm not as knowledgeable on. I have some Elite caps (which I consider better than Fuhjyyu) that are 820uf 220V. I forgot if increasing the voltage on input caps causes issues or improves it.
            • goodpsusearch
              • Oct 2009
              • 2850
              • Greece
              #26
              Elite are crap.
              Increasing the input caps voltage doesn't hurt. It could help their endurance.
              • Pentium4
                CapXon Be Gone
                • Sep 2011
                • 3741
                Elite are crap.
                Thanks for the reply yeah I know they're crap, but wouldn't you trust higher rated Elite over Fuhjyyu?
                • goodpsusearch
                  • Oct 2009
                  • 2850
                  • Greece
                  #28
                  You can try
                  • lti
                    • May 2011
                    • 2557
                    Why would increasing the voltage rating of a cap hurt anything?
                    • c_hegge
                      • Sep 2009
                      • 5219
                      It won't
                      • Pentium4
                        CapXon Be Gone
                        • Sep 2011
                        • 3741
                        I don't think it's even worth trying, this thing looks to be in bad shape...It looks a lot darker in person (my phone doesn't take the best pictures) But on the soldering side it looks like a bunch of joints went cold.
                        • goodpsusearch
                          • Oct 2009
                          • 2850
                          • Greece
                          #32
                          I always try to fix them to the point that I find there are many parts damaged (transistors, optocouplers, ICs), then I quit.
                          • everell
                            • Jan 2009
                            • 1514
                            The dark area looks like it is in the 5VSB area. Hang on to it for just a little longer. I am getting ready to do a post on converting 2 transistor 5VSB to VIPer 22A pwm chip. The conversion is much easier than the DM311 mod. You can use your Antec SP-350 to try this conversion. Here is what the add on board looks like.
                            Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
                            • Pentium4
                              CapXon Be Gone
                              • Sep 2011
                              • 3741
                              Sweet! Thanks everell. I'll hang on to it. The darkest spot on the entire PCB is on 2 of the PWM controller pins. When it's plugged in it won't boot up but it'll give a high pitched whine. Does that mean there is still life in the 5VSB circuit?
                              • nickBcap
                                • Jan 2012
                                • 114
                                • New Zealand
                                #35
                                Hi, I have a died Antec Sp-350 that had two swollen capacitors which I removed and bought smaller same value capacitors for. The original swollen capacitors are 8mm x 16mm and the replacements I bought, without thinking about the size are 8mm x 12mm.
                                Should I buy the correct sizes?
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  #36
                                  As long as the replacement caps' ESR and ripple are near equivalent to the originals, size won't matter.
                                  --- begin sig file ---
                                  --- end sig file ---
                                  • Behemot
                                    • 4845
                                    • CZ
                                    #37
                                    But usually smaller size means lower capacitance.
                                    • ben7
                                      Capaholic
                                      • Jan 2011
                                      • 4059
                                      Not quite always.
                                      Some capacitor series are made to be smaller and have the same capacitance.
                                      But yes, generally, smaller size capacitors have a lower capacitance and/or voltage rating.
                                      Muh-soggy-knee
                                      • nickBcap
                                        • Jan 2012
                                        • 114
                                        • New Zealand
                                        #39
                                        Here is the two capacitors for comparison.
                                        I want to replace the larger capacitor with the smaller capacitor if I can. From what I have learned the Nichinon cap will be a better quality cap then the Capxon capacitor, but I did not have this in mind when I bought them, I bought the smaller capacitors without reading the auction properly.
                                        • Shocker
                                          Banned
                                          • Dec 2011
                                          • 635
                                          #40
                                          What series are the caps???
                                          • Sus256
                                            HISENSE 65E7KQ PRO - no boot
                                            by Sus256
                                            Hi all!
                                            HISENSE 65E7KQ PRO
                                            RSAG7.820.13512 - chassis
                                            MT9618BAATAB - cpu
                                            RSAG7.820.12059 - power
                                            HD650Y3U77 - panel
                                            KLM8G1GETF - emmc
                                            The TV does not turn on, the standby indicator is on. All voltages are present.
                                            Emms is dead. Not readable, not detected.
                                            Replaced emmc.
                                            But with another dump there is no launch
                                            Terminal log
                                            UART
                                            AC_ON
                                            RPMB key is not yet programmed
                                            HASH1_VERSION=0x00000000 64bit
                                            E-B
                                            FDE enabled
                                            layout pattern onebin by SAR7,0...
                                            06-01-2025, 02:11 AM
                                          • harp
                                            Metod for removing glued heatsink from fragile component
                                            by harp
                                            I have peltir element glued to heatsink with something thick and sticky like putty... it cant be separate with force or heat without risk of breaking ceramic or damaged semiconductor layers due to force (eg if try twisted, pulled, lifted)... method that I am using is a single thread for needle (thin and firm thread of pure polyester that cant break with bare hands without glowes), and using it like a saw between heatsink and peltir. I holding a heatsink with knee against table. It slowly cut throug putty and release glued parts. It is slow proces, but preserve undamaged component and heatsink....
                                            06-23-2025, 02:01 PM
                                          • Ven
                                            Seeking Advice on Enhancing Heatsink for Main Processor on SAMSUNG TV Motherboard
                                            by Ven
                                            I'm looking to upgrade the heatsink on the main processor of my TV's motherboard for better cooling performance.
                                            The current heatsink is a square-shaped one (2.8cm x 2.8cn) with a basic design, and I believe a more efficient heatsink could help with thermal management and potentially extend the life of the TV.
                                            I'd appreciate any advice on the best type of heatsink to use, specific product recommendations, and tips for installation.
                                            If you've done a similar upgrade, I'd love to hear about your experience and any challenges you...
                                            07-08-2024, 09:32 AM
                                          • piernov
                                            Core 2 "gaming" build with SLI
                                            by piernov
                                            My turn to post a build I guess, wasted way too much time on this one…
                                            First proper SLI board I get so wanted to play around a little bit since I got a couple 8800 GTS.
                                            Everything done with random parts I had lying around.
                                            Specs :
                                            • CPU: Core 2 Quad Q9450
                                            • RAM: 2x2GB KHX6400D2K2
                                            • GPUs: 2x Nvidia GeForce 8800 GTS G80 320MB
                                            • MB: P5N-E SLI
                                            • PSU: Antec Basiq Power 550 Plus
                                            • HDD: Hitachi Ultrastar A7K2000 1TB
                                            • ODDs: DVD ROM, DVD RW
                                            • Case: not sure
                                            Cooling:
                                            • 92mm rear fan
                                            • 120mm front fan
                                            • Additional heatsink on southbridge
                                            05-20-2023, 11:38 AM
                                          • harp
                                            can fanless heatsink replace poor original on RX26PG2
                                            by harp
                                            I have RX26PG2 graphic card with incomplete original heatsink, only aluminium plate... but in original solution it look like such bad termal design that I asking if is proper fanless heatsink be adequate replacement ot better... what you think? Till powering on, it is propper hot......
                                            06-25-2025, 10:56 AM
