Antec 350 Recap Epic Fail
  • bigbeark
    • Jan 2010
    • 661
    This 350-watt Antec was non-working. Three fuyuhu caps in the secondary were vented, so I recapped this PSU, removing every blasted fuyuhu cap and replacing with quality caps.
    I had securely reassembled the PSU, but the top was off, and as I attemped to push the power cord in (switch was off) there was a loud pop and some sparks. The primary side heatsink was apparently live and touched the case.
    Visual inspection confirmed this, slight heatsink melt and blackened area on inside of steel case.
    So I'm guessing one of the components on the primary heatsink was shorting directly to ground. However, I repeat, the rocker switch was in the OFF position.
    What happened to cause this? I went over all the caps I replaced and everything was done properly. There is no burning on any components that I can see.
    I have now removed the wires so I could remove the heatsink, but the wiring was untouched when the short happened.
    How do I test the Mosfets for short to ground? There is no continuity between any of the pins on the big MOSFETS and no continuity to the heatsink except at the mounting screws The smaller one has continuity between pins 2 & 3, but none to the heatsink except at the mounting screw.
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Antec 350 Recap Epic Fail
    Because the switch is off, that does NOT mean there is no voltage in the circuits. It likely was a N-GND short, or possibly they messed up big time and put the switch on the neutral, so the components are always live (on hot wire)
    Is the fuse measuring good?
    Check the bridge rectifier to see if it is shorted.
    I would think the MOSFETs would be OK. (usually the heatsink is connected to the positive DC rail. but I may be wrong)
    Muh-soggy-knee
    • goodpsusearch
      • Oct 2009
      • 2848
      • Greece
      Imagine your finger conducting the primary heatsink and the case... Yeah that happened to me... It was an Antec Smartpower 450 and the switch was at the off position but it was connected to neutral..
      • bigbeark
        • Jan 2010
        • 661
        Just after it happened, I said to myself, lucky I didn't touch that heatsink...
        That must be frightening and painful at the same time. OUCH!
        • goodpsusearch
          • Oct 2009
          • 2848
          • Greece
          This saved me: http://www.conrad.com/Siemens-RCD-Fa...-int&pi=628032
          • c_hegge
            • Sep 2009
            • 5219
            I've done a similar thing, to a similar PSU (an Antec SL350) and was saved by a similar device.
            • bigbeark
              • Jan 2010
              • 661
              Did you find the shorted part?
              I have some other PSUs where a screw is threaded from the case into the Primary heatsink, obviously this is intended as a safety feature.
              If the heatsink can "go live" why is the heatsink not directly grounded to he case, which of course is grounded to the power cord?
              • bigbeark
                • Jan 2010
                • 661
                This PSU uses an IC instead of a fuse. I used the Ohms setting on my multimeter, but did not detect a short to ground on the bridge rectifier.
                I did see a slight deflection of the needle between the negative and positive legs but that
                was not a repeatable reading. I assume the rectifier became charged and would discharge over time.
                • ben7
                  Capaholic
                  • Jan 2011
                  • 4059
                  On the left side of the picture, there is a fuse, it is standing upright, in some plastic shrink-wrap tubing.
                  Muh-soggy-knee
                  • delaware74b
                    • Apr 2009
                    • 628
                    I see carbon tracking around the small transformer in the lower left corner of your first photo, reattached and circled in yellow.
                    Also, removed -any- and -all- of that brown glue on that board. I had a power supply in an HP DC5100 small oven short out because of the glue.
                    Was there a plastic shield installed under the circuit board?
                    Stupidity should be a crime, especially for drivers. I have NO patience for them.
                    • bigbeark
                      • Jan 2010
                      • 661
                      Thanks everyone, really appreciate the help.
                      I repeated my testing of the bridge rectifier with a better ohm meter with better probes. I placed one probe on the solder spot where the heatsink was attached to the PCB and the other probe on each of the legs of the bridge rectifier in turn. This time every leg showed almost no resistance between the leg and the heatsink anchor point. Can I conclude that bridge rectifier KBU8J is internally shorted?
                      The fuse (beside the green disk) shows no continuity - it is blown. That rubber sleeve will be destroyed getting it off to see what the rating is. Thanks Ben7. I totally missed seeing it.
                      What appears to be carbon tracking is not. There is some sort of clear plastic lacquer which ends right above the duller black plastic of that coil.
                      I will indeed remove the big caps and clean that gunk off.
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        Probably, but desolder to verify just in case something else in circuit is affecting the readings.
                        --- begin sig file ---
                        --- end sig file ---
                        • Shocker
                          Banned
                          • Dec 2011
                          • 635
                          To prevent a shock if:
                          1. The ground is missing
                          2. The silicone pads break down
                          They figure that they'd prefer live heatsinks to a ground-fault.
                          • bigbeark
                            • Jan 2010
                            • 661
                            So I removed the bridge rectifier and if the positive probe of the ohmmeter is conected to the positive leg of the rectifier and the negative to each leg in succession, there is continuity. if the negative probe is connected to the positive leg of the rectifier and the positive to each leg of the rectifier in succession there is no continuity. So the brdge rectifier only allows currrent to flow in one direction.
                            I checked another working PSU and connecting the negative probe to the heatsink and the positive to each leg of the rectifier shows continuity on every leg between the rectifier and the heatsink.
                            I must assume that I blew the fuse when the heatsink contacted the case, and that the heatsink is supposed to be live!
                            • ben7
                              Capaholic
                              • Jan 2011
                              • 4059
                              So, you will need a new fuse, and possibly a new NTC (the green thing - check if it is open circuit)
                              Muh-soggy-knee
                              • bigbeark
                                • Jan 2010
                                • 661
                                Thanks for pointing this out. If someone plugs in a bad power cable and the heatsink is grounded to the PSU case, the whole computer is "live".
                                Yikes! So whoever takes the lid off a PSU should be **very** careful about plugging it in, or better, avoid doing so.
                                • bigbeark
                                  • Jan 2010
                                  • 661
                                  Thanks Ben7! The NTC is good! I have learned a valuable lesson about working "under the hood":
                                  Never plug the PSU in with the lid off!
                                    • Jul 2011
                                    • 6024
                                    I am glad that you shared this I was working on a Dell Switching power supply and thought about not putting the top on it because of a fan problem
                                    After thinking about this for a few minutes I though this might not be a good idea because it might go
                                    I have another Dell Computer that I will be recapping all of the cap in the power supply and mother board
                                      • Jul 2011
                                      • 6024
                                      I agree with this
                                      • larrymoencurly
                                        • Oct 2004
                                        • 960
                                        I did the exact same thing with an original version 300W or 350W Antec SmartPower, which also used high voltage MOSFETs, but after I unplugged the AC and plugged it back in (after installing the case top), the PSU worked normally. Neither fuse blew (this design had 2).
                                        I haven't had too many MOSFETs fail on me, but every one that did had a short between the gate pin and the other pins, regardless of which direction the meter leads were connected.
                                        I've read that the heatsink is connected to 170VDC in order to provide shielding from RF and to make it safer than connecting it directly to ground because sometimes there's no earth ground. The only grounded heatsinks I've seen were in the low voltage section of the PSU, namely in FSP (Fortron-Source Power) brand products.
                                        • Sus256
                                          HISENSE 65E7KQ PRO - no boot
                                          by Sus256
                                          Hi all!
                                          HISENSE 65E7KQ PRO
                                          RSAG7.820.13512 - chassis
                                          MT9618BAATAB - cpu
                                          RSAG7.820.12059 - power
                                          HD650Y3U77 - panel
                                          KLM8G1GETF - emmc
                                          The TV does not turn on, the standby indicator is on. All voltages are present.
                                          Emms is dead. Not readable, not detected.
                                          Replaced emmc.
                                          But with another dump there is no launch
                                          Terminal log
                                          UART
                                          AC_ON
                                          RPMB key is not yet programmed
                                          HASH1_VERSION=0x00000000 64bit
                                          E-B
                                          FDE enabled
                                          layout pattern onebin by SAR7,0...
                                          06-01-2025, 02:11 AM
                                        • harp
                                          Metod for removing glued heatsink from fragile component
                                          by harp
                                          I have peltir element glued to heatsink with something thick and sticky like putty... it cant be separate with force or heat without risk of breaking ceramic or damaged semiconductor layers due to force (eg if try twisted, pulled, lifted)... method that I am using is a single thread for needle (thin and firm thread of pure polyester that cant break with bare hands without glowes), and using it like a saw between heatsink and peltir. I holding a heatsink with knee against table. It slowly cut throug putty and release glued parts. It is slow proces, but preserve undamaged component and heatsink....
                                          06-23-2025, 02:01 PM
                                        • Ven
                                          Seeking Advice on Enhancing Heatsink for Main Processor on SAMSUNG TV Motherboard
                                          by Ven
                                          I'm looking to upgrade the heatsink on the main processor of my TV's motherboard for better cooling performance.
                                          The current heatsink is a square-shaped one (2.8cm x 2.8cn) with a basic design, and I believe a more efficient heatsink could help with thermal management and potentially extend the life of the TV.
                                          I'd appreciate any advice on the best type of heatsink to use, specific product recommendations, and tips for installation.
                                          If you've done a similar upgrade, I'd love to hear about your experience and any challenges you...
                                          07-08-2024, 09:32 AM
                                        • piernov
                                          Core 2 "gaming" build with SLI
                                          by piernov
                                          My turn to post a build I guess, wasted way too much time on this one…
                                          First proper SLI board I get so wanted to play around a little bit since I got a couple 8800 GTS.
                                          Everything done with random parts I had lying around.
                                          Specs :
                                          • CPU: Core 2 Quad Q9450
                                          • RAM: 2x2GB KHX6400D2K2
                                          • GPUs: 2x Nvidia GeForce 8800 GTS G80 320MB
                                          • MB: P5N-E SLI
                                          • PSU: Antec Basiq Power 550 Plus
                                          • HDD: Hitachi Ultrastar A7K2000 1TB
                                          • ODDs: DVD ROM, DVD RW
                                          • Case: not sure
                                          Cooling:
                                          • 92mm rear fan
                                          • 120mm front fan
                                          • Additional heatsink on southbridge
                                          05-20-2023, 11:38 AM
                                        • harp
                                          can fanless heatsink replace poor original on RX26PG2
                                          by harp
                                          I have RX26PG2 graphic card with incomplete original heatsink, only aluminium plate... but in original solution it look like such bad termal design that I asking if is proper fanless heatsink be adequate replacement ot better... what you think? Till powering on, it is propper hot......
                                          Today, 10:56 AM
