Power supply build quality pictorial.closed.use part 2
This topic is closed.
This is a sticky topic.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    #101
    Re: Power supply build quality pictorial
    cooler master(hipro)
    looks decent for a cheap psu.i would rather not see ost in anything though.panasonic inputs and teapo on the output exept for 2 ost.
    look at the input filtering.
    this unit is heavy.and no pfc choke to account for the weight.
    • mutant
      • Mar 2006
      • 123
      #102
      My new power supply. Enermax ELT620AWT 620 watt. I hope it lasts.
      • tiresias
        • Feb 2006
        • 489
        #103
        Welcome mutant!
        I'm sure it will last - I've always found the Enermax units to be reasonably powerful, very well-made and solidly-built. Another bonus is that the insides are always so "neat", with all components relatively accessible for measurements or troubleshooting.
        Comparing it, (at first glance) with my 480W Enermax 'Coolergiant', I can easily see that the heatsinks on yours are are probably twice as wide (maybe even more so in the case of the sink on the output diodes). Your input toroid and main transformer also appear to be more massive.
        __________
        PS. By the way - what brand are those output capacitors? They don't appear to be Enermax's usual JP CE-TUL series.
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          #104
          Hmm, a Primary Hitachi capacitor, just as usual...
          But like tiresias said the secondary caps looks "different" (for an Enermax that is) Jackcon maybe?
          Anyway, I've seen a few Enermax units 5 years old, still going strong with no bulging caps despite not using any good caps really... I think the nice layout and airflow in them helps allot... (have we ever seen a bad Enermax PSU here on badcaps btw?)
          • mutant
            • Mar 2006
            • 123
            #105
            Originally posted by tiresias
            Welcome mutant!
            __________
            I'm not sure what brand but I attached a better pic of them.
            I do like this Enermax and hope it is money well spent. It's the most expensive power supply I've ever bought at $159 us. It's replacing a 400 watt that became unstable because I overloaded it
            3 capacitors leaked and I replaced them thanks to the info of this site
            I'm new to learning about capacitors. I have learned more on this website and forums about capacitors than anyplace else. It's a great resource.
            Yes I still have an old Enermax thats about 5 years old too.
            So is Hitachi not ideal to have?
            Well thanks for everyones comments.
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              #106
              i did replace a hitachi cap recently.it was 20+ years old in an oven of a motor drive.
              btw all the epoxy sealed panasonics were open too.
              the hitachi was a 2700@450v beercan.
              fanuc used good parts but when something runs hot enough that the mill operators warmed their lunch in the cabinet failures can be expected.
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                #107
                Hitachi is very good
                LOL! Gotta remeber to take a pic of the caps in my tubelaser machine at work... Adige LT702D
                • larrymoencurly
                  • Oct 2004
                  • 960
                  Power supply found inside a Neo brand model N525U2-BK-LT external USB2 drive enclosure I bought from DealSonic. The high voltage side uses an FQPF 5N60C MOSFET. I forgot the capacitor brands:
                  • Shroomie
                    • Apr 2006
                    • 356
                    #109
                    An Austin '250w' AT supply, L&C built, model LC-200C. The "Hyena" AT is very similar.
                    From a K6 machine I got free a while back. All the capacitors are "Viva" brand.
                    You know there's something wrong when you open up a PSU and are glad to find Teapos.
                    Why I don't buy cheap cases!
                    • japlytic
                      • Oct 2005
                      • 2086
                      DVE (Dee Van Electronics) DVS-1454P from 1996, Rubycon USP 470uF 200V primary units, CapXon KM series (2200uF 16V before output inductor on +12V, 1000uF 16V after output inductor on +12V, 3300uF 6.3V after output inductor on +5V, 1000uF on -12V rail ) with one "WC" brand (HL series) 6800uF 6.3V unit before output inductor on +5V, as well as a couple of low-value Jamicons.
                      Primary switching transistors are 2SC2625.
                      • Fatal0E
                        • Jan 2004
                        • 252
                        #111
                        Brand new as of 4/25/06 PC Power & Cooling Silencer 360 ATX
                        this is mine, bought for personal use, its a piece of junk. I think I damn near melted it and it shut off.
                        • Per Hansson
                          • Jul 2005
                          • 5895
                          • Sweden
                          #112
                          Cisco 827 Power Adapter Model ADP-20JB. +5v: 3.0A, -24v: 0.05A -71v: 0.06A Max 20W. Has Delta Electronics written all over it. Uses a Primary bulk cap from Rubycon, MXW 400v 56uF. Some smaller Rubycon YXF caps and 10v 1000uF United Chemi Con LXJ caps for the output side (and some smaller KMF) Without doubt the most well built power adapter I have ever seen, it also has a thermal protection circuit in the form of a thermistor connected to the main transformer... The Cisco 827 ADSL modem itself does not have a single capacitor inside of it...
                          • willawake
                            Super Modulator
                            • Nov 2003
                            • 8457
                            • Greece
                            #113
                            Fortron Bluestorm 400w - FSP400-60THN-P
                            the primary caps are teapo, the rest are teapo, ost, capxon. the fan is usual protechnic for the bluestorm series. i like these psu they are very nice to show to clients, all the bling and inside not BS. prices 55 euro for the 350w which is nice and what i usually get for them, and 79 for the 400w. but if you need 20 pin atx then bluestorm 20+4 pin is the way to go for nice psus. actually i have problems to find good 20 pin psus at the moment, everything is either crap or 24 pin. adapters suck, they are so bulky impossible to cable tidy nice......
                            the primary caps are 1000uf 200v instead of 820uf on the 350w.
                            • dood
                              Deputy dood
                              • Mar 2004
                              • 2462
                              Enhance SFX-1209F 90w ATX PSU
                              This is out of the MSI SlimPC series of machines. It is ATX spec, but in a small formfactor. For a sense of the size, look at the power cord plug compared to the size of the rest of the chassis. Teapo main caps, a mix of Teapo and Jamicon on the output side.
                              Ludicrous gibs!
                              • Zap
                                • Apr 2006
                                • 13
                                #115
                                I won't name any names like G-Y but I heard a little birdy say that there were some pervs in this here forum that likes to view pics of nekkid power supplies, so without further ado here are some pictures for your fwapping pleasure!
                                First picture shows the setup. We have 8 beautiful models for today's pictorial. I'm your photographer Zap D. Bone. The camera is a 5MP Kodak on a tripod because one hand may be busy at times. My lovely assistant Miss Postal Scale (and her MIA friend Mr Ruler) will help with some of the vital specs of the models. We also have two assistants, Right Light and Left Light, also known as righty and lefty. Bulbs are "natural light" flourescent, which really suck at lighting up a room but seems to be better for pictures.
                                • Zap
                                  • Apr 2006
                                  • 13
                                  #116
                                  Our first lovely PSU is an Apollo unit that is perhaps made by HEC. She's the most petite of the bunch but isn't shy about undressing for the camera. Her vitals are:
                                  HEC-200FC-T
                                  16.7/21/10 (amps on 3.3/5/12)
                                  3.3+5= 110W
                                  200W total
                                  1x 20 pin
                                  1x 4 pin +12v
                                  1x FDD
                                  4X molex
                                  1x single row 6 pin???
                                  10cm deep
                                  2 pounds, 2 ounces
                                  single 80x25mm fan labeled "HEC sleeve bearing"
                                  2 screws to disassemble, no warranty stickers
                                  big caps say LTEC, some others say CapXon
                                  • Zap
                                    • Apr 2006
                                    • 13
                                    #117
                                    Next up is Big Sis, a HEC Orion. Can you believe that she's a virgin? I took her right out of her shrinkwrapped box and popped her warranty stickers - once you pop you can't stop! Her vitals are:
                                    HP585D
                                    36/36/19/20 (amps 3.3/5/12v1/12v2)
                                    585W max
                                    1x 20+4 pin
                                    1x 4 pin +12v
                                    1x SATA
                                    1x PCI-E
                                    2x FDD
                                    6x molex
                                    16cm deep
                                    3 pounds, 2 ounces
                                    two 80x25mm fans with stickers saying "Ruilian Science & Technology"
                                    5 screws to undress her, two covered by stickers
                                    big caps say CapXon, smaller caps say Teapo
                                    • Zap
                                      • Apr 2006
                                      • 13
                                      #118
                                      Our next gal is the svelte Fortron unit. She's trim and "green" but works out so there's more to her than meets the eye... I think. Her vitals:
                                      FSP400-60GLN
                                      30/30/14/15 (amps 3.3/5/12v1/12v2)
                                      3.3+5= 152W
                                      400W total
                                      1x 20+4 pin
                                      1x +12v
                                      1x PCI-E
                                      1x FDD
                                      2x SATA
                                      6x molex
                                      14cm deep
                                      3 pounds, 11 ounces
                                      4 screws to undress, no warranty sticker
                                      120x25mm "Yate Loon brushless" fan
                                      all caps seem to be CapXon
                                      • Zap
                                        • Apr 2006
                                        • 13
                                        #119
                                        Next up are another pair of siblings and a cousin (the family that sleeps together stays together, ya know). We have the younger sister, the Antec True330 with the following vital stats:
                                        True330
                                        28/30/17 (amps 3.3/5/12)
                                        3.3+5+12= 310W total
                                        1x 20 pin
                                        1x +12v
                                        1x inline 6 pin???
                                        1x fan RPM
                                        2x "fan only" molex
                                        7x molex
                                        2x FDD
                                        14cm deep
                                        4 pounds, 3 ounces
                                        80x25mm and 92x25mm clear "Top Motor" fans
                                        4 screws, one covered by a sticker
                                        caps?
                                        • Galvanized
                                          • Mar 2006
                                          • 468
                                          #120
                                          Hey Zap. Would it be too much to give the rating/spec on the caps? Plz.
                                          There is a 10 minuet time limit for editing here.
                                          Dang! Set the beer down and step away from the camera. j/k
