Power supply build quality pictorial.closed.use part 2
This topic is closed.
This is a sticky topic.
    Re: Power supply build quality pictorial
    Delta DPS-480BB A REV 02 2U Server PSU (Comes with the Intel KSW480 2300 2U chassi)
    480w total, +3.3v 24A, +5v 20A, +12v 32A.
    Nichicon and UCC caps, except for one or two of the really small ones which where Ltec and Rubycon.
    The Primary cap was a Nichicon GN(M) (I was unable to see the ratings of it...)
    Secondary side was Nichicon PW(M) & UCC KY
      Originally posted by kc8adu
      noname
      Linkworld LPF2SS-1 300W PSU, 3.3/5/12V = 22/30/14
        Nice 2U Sever PSU!!
        How about the cost?
        My SAMXON Capacitors Database HERE!!
        X-CON is a new brand for SAMXON's Polymer Capacitors.
          Antec EarthWatts EA-380
          Rubycon USR 220uF 400V on primary side (1.5A ripple rating @ 120Hz; 1.725A ripple rating @ 100kHz).
          2200uF 10V OST RLX bafore +3.3V and +5V inductors with 1000uF 10V JP CE-TUR after each inductor.
          2200uF 16V OST RLX before +12v inductor with 1000uF 16V x2 Teapo SY Series after it.
          1000uF 16V Teapo SY before inductor on -12V rail with OST RLX 220uF 16V after it.
          3300uF 10V OST RLX before +5Vsb inductor with 220uF 16V OST RLX after it.
          SBR30A50CT rectifiers used for +3.3/+5V rails, with two in parallel for +12V rail.
          MOSFETS are FQP13N50C x2 (in parallel) for the PFC, with FQP13N50C x2 for the double forward converter. The PFC rectifier diode is a 8ETH06.
          Fan is Adda.
          The PFC/PWM controller is a CML CM680x series.
          The closest match to the OST RLX Series are Nippon Chemi-Con KZJ or Matsushita FM or Rubycon ZLG (recommended upgrade for all other units as well; if not obtainable, use higher capacitance Nippon Chemi-Con KY or KZE units or Rubycon ZL units or Sanyo ME-WX).
            Bestec ATX100-5 100W MATX power supply (this was found in some earlier HP computers, this one came from a Pavilion 4445).
            My gaming PC:
            AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
            ASUS M4A77TD AMD 770 AM3 Motherboard
            PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
            G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
            TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
            WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
            ASUS Xonar DG 5.1 Channel PCI sound card
            Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
            Antec Three Hundred Mid-Tower Case
            Microsoft Windows 10 Pro 64-bit
            Microsoft Windows 7 Ultimate SP1 64-bit
              Seasonic SS-200G:
              Matsushita TSU 470uF 200V primaries and 600V 4A primary rectifier.
              2SC2810 primary transistors.
              Rubycon YXG 2200uF 10V before and after +5V inductor.
              Rubycon CE-W 1000uF 16V on +12V rail.
              Rubycon CE-W 470uF 16V on -12V rail.
              CTB-34 (40V 15A) rectifier on +5V rail with F12C20 (200V 12A) rectifier on +12V rail.
              Newton NPS-250DP:
              180uF 450V Nichicon LU in PFC stage with 8A 800V primary rectifier.
              W15NB60 x2 in parallel for PFC stage with STVA806D PFC rectifier.
              IRFP450LC x2 for double forward converter.
              2200uF 10V Rubycon YXG before +5Vsb inductor with 470uF 10V YXG after it.
              1500uF 16V x2 Nippon Chemi-Con KY on +12V.
              3300uF 10V Rubycon YXG before and after +3.3V output inductor.
              3300uF 10V Rubycon YXG before +5V output inductor with 3300uF and 1500uF YXG after it.
              1000uF 16V LTEC LZG before -12V regulator with 470uF 16V Rubycon YXG after it.
              STPR10 x2 rectifiers in parallel for +12V.
              MBR3045PT rectifier for +3.3V with two in parallel for +5V.
              A few small value Taicon VT series units were found, along with a Delta fan.
                Dell L350P-00 350W ATX PSU (Lite-On PS-6351-1DFS REV:A)
                350W total
                +3.3v 17A
                +5v 22A
                +12v1 18A
                +12v2 18A
                The primary caps are two Ltec 820uF 220v caps (yes, 820uF!!)
                The secondary side has OST caps mainly, but a few Ltec also (common for Dell PSU's)
                The PFC is passive, bigass transformer screwed to the top cover, the PSU weights about a ton, real impressive that way (mostly due to passive PFC transfomer)
                24pin ATX connector
                4-pin 12v P4 connector
                6-pin PCI-Express videocard connector
                Some oddball 6-pin connector with only 5 wires, never seen before (thought it was EPS +12v first..)
                3 molex HDD and one molex FDD connector
                2 Sata connectors
                The P4 connector was corroded, poor contact resulted in too high resistance and melted the plastic, quite common. Gonna replace the connector...
                  Viotek VIO55
                  20 pin ATX
                  6 molex HDD and one molex FDD connector
                  Input Caps: Teapo 680uf 200v
                  Output Caps (left to right):
                  Fuhjyyu 2200uf 16v (dark blue)
                  YEC 3300uf 10v (light blue, already desoldered, blown)
                  Teapo 1000uf 10v (light blue, inside wire bundle)
                  Teapo 3300uf 10v (brown)
                  The two blown YEC caps measure about 1200uf.
                  Big fan, big case, but small on guts. This supply isn't worth good caps so I put in a Viva 2200uf 16v and two OST 3300uf 6.3v.
                  sig files are for morons
                    Thermaltake Toughpower 430W
                    Thermaltake 430W XP550NP. Group-regulated, No APFC, basically a cheapie unit with highly questionable caps.
                    Primary side: 2 x 680uF 200V CapXcon
                    Secondary side: Ltec, Suscon and Teapo.
                    Will be recapped with:
                    NCC KMD 820uF, 200V on the Primary
                    UCC KY, LXZ, KMG and Panasonic FM on the Secondary.
                    PCB says 300W @ 250V, so not only is it of questionable build quality but it is actually "overclocked" on some pretty shady components.
                    Q6700 @ 3.6 GHz
                    Zippy GSM-6600P
                    Curcial Ballistix PC6400 (4 x 1Gb) Micron D9GMH
                    Abit IP35Pro
                    ATi HD4870
                      Enermax EG465P-VE 431W
                      There may have been another (couple?) of these posted already, but I thought I'd add mine anyway. JP CE-TUR caps throughout, every single one as far as I could make out. A very solid unit.
                        Re: Thermaltake Toughpower 430W
                        Oh... this is OEM from HEC (Compucase Enterprise Co Ltd). The design is exactly same as HEC 350W PSU.
                          Belkin 375VA backup power supplies and an APC:
                          Belkin made by Delta Electric:
                          Belkin made by Centralion Industrial:
                          This 300VA backup by APC (Conext brand) contains a lot more parts than the above two backup supplies:
                          Does the second Belkin (Centralion) really have any MOVs in its surge protection circuit? Because those big green disks look more like capacitors (green ceramic, dull finish) than MOVs.
                            Looks like an MOV to me.
                            Q6700 @ 3.6 GHz
                            Zippy GSM-6600P
                            Abit IP35Pro
                            ATi HD4870
                              How ironic. I have the almost the same unit. :-) Same JP CE-TUR caps as yours, too.
                              In fact, IIRC, I have asked a few questions about the PSU in these forums. My unit's been running fine for the last year or so. Bought it for less than $10. :-)
                              CPU: Sempron 2500+ / P4 2.8E / P4 2.6C / A64 x2 4000+ / E6420 / E8500 / i5-3470 / i7-3770
                              GPU: TNT2 M64 / Radeon 9000 / MX 440-SE / 7300GT / Radeon 4670 / GTS 250 / Radeon 7950 / 660 Ti / GTS 450
                              Main Driver: Intel i7 3770 | Asus P8H61-MX | MSI GTS 450 | 8GB of NO NAME DDR3 RAM (2x4GB) | 1TB SATA HDD (W.D. Blue) | ASUS DVD-RW | 22" HP Compaq LE2202x (1920x1080) | Seasonic S12II-620 PSU | Antec 300 | Windows 7 Ultimate with SP1
                                Newton Power NPS-400AB B
                                Unable to add pictures, I post a simple description and the photos as attachments
                                Pic 1: front grill, the only air intake. Quite tight inside.
                                Pic 2: label. Label writing style resembles the Delta's one.
                                Pic 3: rear grill. Only an 80 mm fan.
                                Pic 4: inside, a bit off focus. I opened the U-shape case, no "void warranty" seals at all; there are two pcbs, the upper one holds the primary side, the lower the secondary side and a fan regulation board.
                                Pic 5: primary side. I think the pfc is active, because there is only a big UCC KMM 390 uF 450v: someone can confirm my thougths? Others capacitors are UCCs, Nichicons and 3 little Letecs: more details in another post. "NPS-400AP B" is written on the pcb, below the big cap.
                                Pic 6: secondary side. Regulators on the right, output stage on the middle and fan control board on the left part; mixed brand capacitors here: 3 Letecs, 2 Rubycons, 6 Nichicons and 4 UCCs.
                                Pic 7: caps. A Letec LZG 4700uF 10v and an UCC KY 3300uF 6.3v in foreground, the top of a Nichicon HD 220uF 16v in the background. More details about caps in another post.
                                Pic 8: regulators. A ST PS2045C in the foreground: his datasheet qualifies as a 20A, 45V Schottky Rectifier.
                                Pic 9: fan. A Delta AFB0812SH, rated 46 cfm at 4000 rpm: at full speed it should be quite noisy.
                                Have an happy life.
                                  zandrax... can post the photo of the copper trace of the secondary PCB ? Thanks.
                                    I forgot them: I'll post in 24-36 hours (I can't now, I have to take the Newton from the server and it's 1 am in Italy now).
                                    BTW, the NPS400-AP (not AB: funny enough) serigraph is on the secondary pcb below the big transformer, not on the primary one.
                                    Zandrax
                                    Edit: I should post the capacitors' list in the "PSU build quality Discussion" thread?
                                    Have an happy life.
                                      Secondary board: circuits
                                      Capacitors are behind the right part: Letecs are in the lower right angle, while others are above them.
                                      Zandrax
                                      Have an happy life.
                                        Delta DPS-175GB 2x175W redundant
                                        running in an IBM Infinity 5000
                                        caps:
                                        pimary: Nichicon GQ
                                        secondary: UCC LXY
                                        fans: 2x Delta AFB0812M (31.4 cfm, 28dBA each).
                                        "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
                                          brought in by one of my cnc guys.
                                          power age "300"
                                          note the 150 on the transformer.
