12V 10A CCTV camera system power supply pulsating
  • rddube
    Aspiring Expert
    • Jun 2013
    • 940
    Re: 12V 10A CCTV camera system power supply pulsating
    Originally posted by harp
    before do anithing, do exactly one more time very same measurement, write data to compare.
    my analisy
    point A is far end of +, our reference of this test
    probing ground
    point D is maximum 166.6 through jumper wire
    point F slightly lower 166.1
    pin#1 dramaticaly lower 164.2, on sam plane with F, were is 2v lost?!?
    point C near cap 165.3... something is pulling it down (mosfet try switch)
    point B 164.3 (27.2mV ripple present)
    point E 165.2 no ripple! there is only a 000 resistor between point E and B.
    So, check what is going on between point F and pin#1, also point B and E, where is lost 1v and ripple? Check 000 resistor, it is not posible it is ok.
    Is this make sense to you?
    Your board may suffer of circular crack arround solder point, and when you measure this, you push it with probe and connect again with track, and all seems ok, but it is intermitten.
    Ok, redid the readings with my other multimeter, and this is what I get (see photo).
    • rddube
      Aspiring Expert
      • Jun 2013
      • 940
      Also, after taking the readings, I took out the mosfet on the primary side and here's a photo, and the readings it gives me in my component tester (there are 3 screens).
      • CapLeaker
        Leaking Member
        • 8196
        Now run this PSU without the mosfet and measure the pins on the PWM
        • CapLeaker
          Leaking Member
          • 8196
          Btw fix that solder joint on point A. Looks to me suspicious. Matter effect reflow all them solder joints that you
          A: didn’t touch yet
          B: looking shady like point A in the picture.
          • rddube
            Aspiring Expert
            • Jun 2013
            • 940
            Ok, so took the readings on the PWM without the primary mosfet in and fixed the suspicious solder joints (I think I've now reflowed the whole board ):
            Results
            Pin 1 - GND
            Pin 2 - .1V to 1.2V jumping around
            Pin 3 - 16V to 19V jumping around
            Pin 4 - .012V to .263V jumping around
            Pin 5 - .2V to .86 V jumping around
            Pin 6 - 0V
            Pin 7 - 12.4V to 15.7V jumping around
            Pin 8 - .292V to 1.18V jumping around
            • CapLeaker
              Leaking Member
              • 8196
              Crazy thing. You did get kind of a different result if I compare your last results with those in post 122. But yet the darn thing does kinds the same shit what it did before. Now I am out of ideas, besides replacing every component one by one. Personally I think something went high resistance or open.
              • harp
                • Jun 2022
                • 604
                • Planet Earth
                #227
                Please do exact measurements of all ic legs (without mosfet) in AC setting mV.
                Also, check the output DC without load and mosfet.
                Till now, I was thinking that jumping oscilations came from mosfet who try to start transformer windings... when is mosfet out, the transformer is disconnected from current path? From where the exactly same oscilations now came from?
                Seems to the big current is not involved anyway...
                • petehall347
                  • Jan 2015
                  • 4427
                  • United Kingdom
                  #228
                  any news yet ?
                  • rddube
                    Aspiring Expert
                    • Jun 2013
                    • 940
                    Hello everyone, sorry for the delay in replying, have been extremely busy at work and was just completely exhausted by the time I could get to work on this. It's the weekend now, so here goes, measurements of all ic legs without mosfet in AC setting mv:
                    Pin 1 - 0mv
                    Pin 2 - 0mv to 478mv jumping around in between randomly no fixed delay
                    Pin 3 - 0mv to 622mv jumping around in between randomly no fixed delay
                    Pin 4 - 0mv to 462mv jumping around in between but synchronously, like it was timed
                    Pin 5 - 0mv
                    Pin 6 - .8 to 2.2mv
                    Pin 7 - 0 -657mv jumping around randomly no fixed delay
                    Pin 8 - 154mv to 420 mv jumping around randomly no fixed delay
                    Output without load and mosfet is .02DCV
                    • harp
                      • Jun 2022
                      • 604
                      • Planet Earth
                      #230
                      Allmost all jumping arround...
                      It is kind of contradictional, but it is what it is. Mosfet is out. Mains 163v have two big capacitor and nothing to load, but it is present 0.6v ocasional ripple...
                      Pin#3... it is now only connection with power through 1.5M resistor.
                      Pin#6... sense resistor flow 10mA for nothing?
                      So, desolder IC from pcb (no mosfet no ic from now), and do DC and AC measurement on IC pads, I am interesting is still pulsating... do same DC reading on secondary output without load.
                      Pause here to discuss on forum with results...
                      Next I will do, is to desolder everything, but everything at all on primary side, clean pcb truely, inspect every (unpopulated) track end-to-end and double-time for 0.0 ohm resistance and visual.
                      Check separate each desolder component, make note... I suggest that not soldering it back that component, but use some other from scratch board.
                      For 000 resistor use instead a wire, and ommit placing any extra unnecesary component apart from bare bone test IC circuit, use IC socket on now on, it is possible that ic (batch) is faulty.
                      Then scrape on pcb a little notch in isolation coating like tear shape next to every THT pin, to reach fresh copper, put back fully tested component in a fully tested track and stretch tin solder to flow this area.
                      After soldering each component, test fot continuity and shorts with near area.
                      Suggestion from others?
                      • petehall347
                        • Jan 2015
                        • 4427
                        • United Kingdom
                        #231
                        i would be changing the 1.5 meg resistor first .
                        • lotas
                          • Jan 2016
                          • 4625
                          • Russia
                          #232
                          Yes, it can be reduced a little and set to 1.2 MOm.
                          • Alimash
                            • Jul 2019
                            • 31
                            • Lebanon
                            #233
                            Just a thought, a similar issue happened to me, and i solved it by simply resoldering the whole board, it turns out some joints has moisture.
                            It took me a lot of time to figure it out.
                            • rddube
                              Aspiring Expert
                              • Jun 2013
                              • 940
                              Hey Harp, I appreciate your help and the effort in trying to diagnose this, but I am at a point where it's almost a no go with this thing! I think I'm going to try what Alimash suggested and if that doesn't revive it, well it will have been a long adventure..I'll keep you posted on my resoldering of the whole board.
                              • CapLeaker
                                Leaking Member
                                • 8196
                                I wouldn’t trust this psu anyway much and replace it with a Meanwell that fits.
                                This being said, I would use this old power supply as an “educational” piece. Maybe even put it on the side in later to fix pile when the weather gets bad or you are bored or something. Then go at it again. I did this a few times and the end was successful.
                                • petehall347
                                  • Jan 2015
                                  • 4427
                                  • United Kingdom
                                  #236
                                  would be nice to find out what is the fault after 6 pages ,,
                                  just noticed the last voltages are ac so that threw me a little .
                                  whatever it is will be something really silly as those things get overlooked often . most of my call outs turn out that way after the so called experts have had a go at whatever it was ,
                                  • rddube
                                    Aspiring Expert
                                    • Jun 2013
                                    • 940
                                    Ok, so I gave this thing a last shot and redid all the soldering on the entire board thinking it might be the solution, but alas, no still the same erratice voltages. On the startup cap, I get between 11.6V to 15.2V jumping around in between.
                                    • CapLeaker
                                      Leaking Member
                                      • 8196
                                      I am still saying it acts like there is something high in resistance or open somewhere on this darn thing.
                                      • rddube
                                        Aspiring Expert
                                        • Jun 2013
                                        • 940
                                        I checked almost every component, changed the output capacitors, etc. Redid all soldering and even changed the PWM chip again just to make sure. Same symptoms.
                                        Starting to think there is something wrong with the transformer but did check that too and it's a complete mystery!
                                        • harp
                                          • Jun 2022
                                          • 604
                                          • Planet Earth
                                          #240
                                          You can NOT feed an external voltage to pin 7, If you connect an external power supply ground to this power supply HOT ground you will blow it up.
                                          R_J, can you please explain how exactly external psu will blow it up, current pathway?
                                          Supose to both wall psu adapter have not direct ground pin.
                                            by sam_sam_sam
                                            03-31-2024, 02:12 PM
                                            by sam_sam_sam
                                            07-01-2024, 06:34 AM
                                          • shamsudeen
                                            Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                            by shamsudeen
                                            Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                            I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                            i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                            07-19-2025, 07:14 AM
                                          • JimBanville
                                            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                            by JimBanville
                                            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                            Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                            I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                            09-13-2023, 07:21 AM
