12V 10A CCTV camera system power supply pulsating
  • rddube
    Aspiring Expert
    • Jun 2013
    • 940
    Re: 12V 10A CCTV camera system power supply pulsating
    Thanks R_J for such good learning details. Will try with a 470ohm resistor and wil also make sure all charges are depleted before taking measures. Will report back shortly.
    • rddube
      Aspiring Expert
      • Jun 2013
      • 940
      So I decided to take out that variable resistor and test out of circuit, and it measures a perfect 510ohms in the middle position.
      So I took measurements of that area under the board and this is what I have (please see picture).
      What do you think?
      • R_J
        • 9550
        The resistance looks ok, Reference and Cathode are reversed on your picture. Is this a TL341?
        You might want to check R13, R14 and 000Ω at loc. ZD2
        • rddube
          Aspiring Expert
          • Jun 2013
          • 940
          Hi R_J,
          It is a AZ431 which I think is the same. I also think I identified the reference and the cathode correctly, because if you turn the board around, that's how it is positionned. I'll check R13, R14 and the 0ohms at loc ZD2 and report back.
          • harp
            • Jun 2022
            • 602
            • Planet Earth
            #45
            You are incorectly labeled TL431 pins on picture. Reference pin #1 is that one who have voltage divider attached to it, thus 11k8, 2k4 and pot. In datasheet it is presented from top view, you cant just rotate it 180 deg...
            And maybe another point, I not sure:
            What is weird, is when I remove C4 and test, I get no more pulsing on the top pin of R10 (a nice clean stable 18V), but then I get no output on the secondary side, nothing?
            Can you remove C4 again and measure voltage on all pins of pwm, to compare if also other pulsating stops .
            • R_J
              • 9550
              Originally posted by rddube
              Hi R_J,
              That datasheet shows the TOP VIEW of the ic, not the bottom view, The reference pin does not drive the optocoupler.
              • rddube
                Aspiring Expert
                • Jun 2013
                • 940
                Sorry R_J, you are correct, my bad. Gets confusing. I'll get on with the tests that you suggested and also those suggested by harp. Thank you for sticking with me! Attached is corrected photo.
                • rddube
                  Aspiring Expert
                  • Jun 2013
                  • 940
                  R13 measures .998K ohms
                  R14 measures 2.209K ohms
                  000 at loc. zd2 measures 0 ohms.
                  • rddube
                    Aspiring Expert
                    • Jun 2013
                    • 940
                    C4 removed, no more pulsating, 6.1V (steady) on output of secondary.
                    PWM:
                    Pin 1: GND
                    Pin 2: .11V steady
                    Pin 3: 18V steady
                    Pin 4: .1335V steady
                    Pin 5: .323V steady
                    Pin 6: .044V gradually decreasing to .038V
                    Pin 7: 13.77V steady
                    Pin 8: .013V
                    btw, C4 is a 10uf 50V cap changed from the original for a very low ESR cap. It was not present on the board during the above test.
                    • harp
                      • Jun 2022
                      • 602
                      • Planet Earth
                      #50
                      With C4
                      Pin 1: GND
                      Pin 2: .1V to .3V oscillating
                      Pin 3: 16V to 19V oscillating
                      Pin 4: 0V to 1.3V jumping around sometimes to 3.2V
                      Pin 5: same as pin 4
                      Pin 6: 0V, sometimes shows .1V or .2V then 0V
                      Pin 7: Oscillating between 11V and 15V
                      Pin 8: .001V
                      Without C4
                      Pin 1: GND
                      Pin 2: .11V steady
                      Pin 3: 18V steady
                      Pin 5: .323V steady
                      Pin 8: .013V
                      Pin 7 vdd needs to be at 16.5v or above for the ic to operate
                      How to isolate the problem - I dont know if it is right way, but grand masters are watching and can correct me Do not anything without their aproval.
                      I will desolder D2 and feed 18V into pin#7. With this can be isolated eventualy problem on aux windings. You may observe current draw also.
                      Second, if first idea do not work upgrade to second idea - desolder secondary output diode and feed output of psu with 12V, to check feedback. When you adjust trimpot, some changes must see on primary side, eg change gate voltage in AC mode.
                      Double check R4 and R6 on gate.
                      • R_J
                        • 9550
                        You can NOT feed an external voltage to pin 7, If you connect an external power supply ground to this power supply HOT ground you will blow it up.
                        Disconnect D2 and see if you have the same pulsing problem, and the voltage on pin 7 stays the same, if it does I suspect either R7 or the feedback winding on the transformer could be open.
                        The gate drive PWM is operating at 65KHz how do you expect to see a change in duty cycle with your meter?
                        I would try unsoldering the primary side of the optocoupler and see if the voltage on pin 2 is at 6v, and be careful not to short the ic pins when checking.
                        • rddube
                          Aspiring Expert
                          • Jun 2013
                          • 940
                          Ok, R_J, got ya. When you say "Disconnect D2 and see if you have the same pulsing problem, and the voltage on pin 7 stays the same,", do you mean after reinstalling C4 or I leave C4 out? Also, is the feeback winding the one I measured in post #19 ?
                          • R_J
                            • 9550
                            C4 needs to be in place or the ic will never ever try to start. If you disconnect D2 and the pulsing stayed the same then that could be where the problem is. I suspect the pulsing will stop as a result of no run voltage from the feedback winding.
                            I re-read that post #19, seems a long time ago, so the winding is not open.
                            I would try disconnecting the optocoupler on the primary side to see if you get closer to 12v on the secondary output. It may not work due to all the safety features of this ic.
                            • rddube
                              Aspiring Expert
                              • Jun 2013
                              • 940
                              D2 removed, pulsing on the secondary output and on pin 7 of the PWM, pulsing from 11V to 15V approx. For the next test (disconnecting the optocoupler on the primary) do I reinstall D2?
                              • R_J
                                • 9550
                                So nothing changes in the operation of the power supply if D2 in in circuit or not? if that is the case the feedback circuit can't be working.
                                With D2 anode connected and the cathode in free air, check if there is any voltage on D2 cathode, or if you can, place a 10µf cap between hot ground and D2 cathode and see if that circuit charges the cap. basically have u1 pin 7 disconnected from the circuit.
                                If you have another diode try replacing D2 it might be failing
                                • rddube
                                  Aspiring Expert
                                  • Jun 2013
                                  • 940
                                  Ok, so just to make sure I get this right, I place a 10uf cap between D2 cathode and hot ground (what is hot ground, is it primary ground or same ground as pin 1 - dumb question) ?
                                  Also R_J, I did have another D2 diode that I scavenged from old boards and exactly same behavior. I tested both with my fluke multimeter in diode mode and both test good.
                                  Another question R_J, should I remove the transformer to check the feedback coil? What if it gave me the wrong reading because it was connected in circuit?
                                  • R_J
                                    • 9550
                                    There is no need to remove the transformer, the feedback winding can be checked when D2 is out of circuit, The reason I suggested to add a cap to D2 so it can charge and give a proper voltage, basically it is acting as C4, so use C4's ground. Hot ground is the primary ground, basically the main filters negative lead or U1 pin1.
                                    By isolating u1 pin7 we can check the transformer winding, the 22Ω resistor and D2 to make sure it is supplying voltage.
                                    • rddube
                                      Aspiring Expert
                                      • Jun 2013
                                      • 940
                                      Should I remove C4 ?
                                      • R_J
                                        • 9550
                                        No, you need C4 in place so the ic will actually start, (pulse) without C4 the ic will not start and you will not get any secondary or feedback voltages.
                                        • rddube
                                          Aspiring Expert
                                          • Jun 2013
                                          • 940
                                          ok, so here goes!
                                            by sam_sam_sam
                                            03-31-2024, 02:12 PM
                                            by sam_sam_sam
                                            07-01-2024, 06:34 AM
                                          • shamsudeen
                                            Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                            by shamsudeen
                                            Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                            I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                            i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                            07-19-2025, 07:14 AM
                                          • JimBanville
                                            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                            by JimBanville
                                            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                            Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                            I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                            09-13-2023, 07:21 AM
