12V 10A CCTV camera system power supply pulsating
  • harp
    • Jun 2022
    • 598
    • Planet Earth
    #141
    Re: 12V 10A CCTV camera system power supply pulsating
    It is not neccesery to remove secondary diode again, unless (like I mentioned before) you feed 12Vdc to output and simultaniously power psu from mains 220Vac, due to specific testing purpose.
    So yes, just feed 12v and check again pin1&3 of TL431 and primary side of optocoupler, maybe to try reverse probe, or other dmm... if in off state is 3k reading accross pin3&4 of opto, then when interLED power on must be some lower reading, dont you think?
    • CapLeaker
      Leaking Member
      • 8146
      Originally posted by rddube
      Ok, cleaned the probes and deoxed them, but the lowest I get with very high quality probes is .5 ohms, there is no way to 0 it. Whereas the cheaper tester Tais TA118A is dead 0 ohms when connecting the 2 probes together. It cost +- 40$ compared to the Fluke 87 V which had cost me over 500$. Probably need calibration and cleaning, but they're asking over 300$ CAD to do this at Fluke, not worth it.
      If you get real good probes, you will get it down to 0.2ohm. Flukes usually do not go down to flat zero as it measures the resistance of the leads. She is fine and well within tolerance.
      • petehall347
        • Jan 2015
        • 4426
        • United Kingdom
        #143
        was the ic changed for a new one yet ?
        • rddube
          Aspiring Expert
          • Jun 2013
          • 936
          Ok, redid the test and here is what i get when I inject 12v at the output:
          TL431 Reference 2.6V
          TL431 Cathode 1.8V
          opto pin 3 & 4 no power : .680M ohms
          with 12 V on output: 105 ohms
          • rddube
            Aspiring Expert
            • Jun 2013
            • 936
            Yes the IC was changed for a new one.
            • harp
              • Jun 2022
              • 598
              • Planet Earth
              #146
              TL431 Cathode 1.8V
              Now opto look ok, so it is prove that led and transistor worked.
              For TL431, I guess it is also ok, but not sure.
              My suggestion is, that all the time that going with testing and troubleshooting, you have permanently soldered dummy load on output, say 100R few wats. When you find the problem, voltage will arive on output, otherwise, without load may pulsate anyway.
              Notice down first initial measurement of this setup, voltage on (loaded) output, for future reference.
              Somebody earlyer suggested to connect larger capacitor on pin7. To dont overbutched your pcb, try to add temporarly parallel biger and bigger caps on other side direct on solder points, or use fine aligator clamp. Monitor output, if any change and compare?
              I highly suggested that you use a bulb current limiter always when troubleshooting with live mains.
              Also, on your post #102 when took off transformer, have you write readings of resistance and inductivity?
              • CapLeaker
                Leaking Member
                • 8146
                TL431 Cathode 1.8V
                That's what I was looking for earlier. There isn't much more to proof that the secondary is o.k.
                You got the primary and the transformer still as suspect.
                • petehall347
                  • Jan 2015
                  • 4426
                  • United Kingdom
                  #148
                  am sure this will have been looked at already in the pic .
                  on another thought i dont really understand this circuit but i might have expected the gate of the chopper transistor to be getting something other than 0v . Pin 8 - 9.54kΩ to ground .is this ok ?
                  • petehall347
                    • Jan 2015
                    • 4426
                    • United Kingdom
                    #149
                    another thing is have the bad solder joints been rectified yet ? i see a few on the first pic .
                      • 31015
                      that image is the winding to power the chip once running.
                      thats why i asked about that diode on pin7
                      • rddube
                        Aspiring Expert
                        • Jun 2013
                        • 936
                        Ok, so tried with a load, no output at all. Without load, pulsating from 4V to 6V.
                        Tried a 47uf capacitor, still same result - with load no output, witout load pulsating between 2 - 3V.
                        When I took off transformer I did not write resistance but I checked and it all seemed good. Don't know how to check inductance however.
                        • rddube
                          Aspiring Expert
                          • Jun 2013
                          • 936
                          Yes, I redid almost all the solder joints.
                          • rddube
                            Aspiring Expert
                            • Jun 2013
                            • 936
                            I'm about to give up on this thing unless any of you have any other ideas, I think we spent enough time trying to resolve this. Many thanks to all of you!
                            • rddube
                              Aspiring Expert
                              • Jun 2013
                              • 936
                              I was thinking in putting in a 1uf cap instead of the 10uf cap. What do you think? Usually, startup caps are 1uf 50V, so maybe this could be the problem because when I put a 47uf cap it just didn't make any difference.
                                • 31015
                                22 or 47uf would be better
                                but check the related diode too
                                • harp
                                  • Jun 2022
                                  • 598
                                  • Planet Earth
                                  #156
                                  I think that your chip have no needed voltage to operate in pin7. So how about that you disconnect primary aux diode and connect 2x9v battery (18Vdc) on that resistor for pin7. Wait aproval if this idea will provide power to ic to test.
                                  If is all component around the board is ok, that only left a transformer. Inductance can measure with "transistor testers", when is out. When you choose to step ahead to rewireing it, know that this not impossible, and also reffer to repair electronic...
                                  https://m.youtube.com/watch?v=ODcqLmg7vR4
                                  • CapLeaker
                                    Leaking Member
                                    • 8146
                                    At the end of the day it isn’t that wild, because it is just a singe voltage PSU. You can always replace it with a different one. To me there is somewhere something open or high resistance, or the transformer got a shorted winding. To measure the transformer you need a ring tester, you can’t measure its resistance besides an open.
                                    • rddube
                                      Aspiring Expert
                                      • Jun 2013
                                      • 936
                                      At the end of the day it isn't that wild, because it is just a singe voltage PSU. You can always replace it with a different one. To me there is somewhere something open or high resistance, or the transformer got a shorted winding. To measure the transformer you need a ring tester, you can't measure its resistance besides an open.
                                      I do have a ring tester but not too sure how to use it. Also, I've been told that they are not that accurate, but it's the one that you build with a kit. I could with some guidance test the transformer - it's got 2 X 3 connected legs on the secondary side and 4 legs on the primary side.
                                      • CapLeaker
                                        Leaking Member
                                        • 8146
                                        That’s o.k. Can’t be worse than a Effed up measurement. You just have to know what windings are where and on which side and you have to measure one winding to the other winding etc. One more test you also could do is an insulation test on the transformer. Maybe it’s looking good like that, but starts arcing when under higher voltage? I don’t have a ring tester, but I do have a 1000v Isolation tester.
                                        • rddube
                                          Aspiring Expert
                                          • Jun 2013
                                          • 936
                                          That's o.k. Can't be worse than a Effed up measurement. You just have to know what windings are where and on which side and you have to measure one winding to the other winding etc. One more test you also could do is an insulation test on the transformer. Maybe it's looking good like that, but starts arcing when under higher voltage? I don't have a ring tester, but I do have a 1000v Isolation tester.
                                          Ok, so I took the transformer out. The winding which is the feedback winding on the primary side looks fine with the blue ring tester. The other winding on the primary side comes out as a short, but then all windings on the secondary side all show up as shorts (there are 3 legs connected together and 3 other legs connected together, if I measure between both 3 legs, it shows up as short.).
                                          Do I have to disconnect the 3 legs connected together before taking measurements?
                                            by sam_sam_sam
                                            03-31-2024, 02:12 PM
                                            by sam_sam_sam
                                            07-01-2024, 06:34 AM
                                          • shamsudeen
                                            Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                            by shamsudeen
                                            Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                            I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                            i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                            07-19-2025, 07:14 AM
                                          • CMCM
                                            Russound CA4 Power Supply Repair
                                            by CMCM
                                            Hello Everybody,
                                            Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                                            Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                                            The outputs marked 12v and 20v are all measuring only 1v.
                                            The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                                            The capacitors physically look clean (no bludgesor leaks) and...
                                            07-03-2025, 01:12 PM
