12V 10A CCTV camera system power supply pulsating
  • CapLeaker
    Leaking Member
    • 7986
    Re: 12V 10A CCTV camera system power supply pulsating
    Make sure the transformer windings didn’t brake off from the legs.
    • rddube
      Aspiring Expert
      • Jun 2013
      • 908
      So removed transformer, checked continuity for all the legs, redid the solder joints just in case, re-checked continuity between windings and legs. Reinstalled, tested and same result.
      • harp
        • Jun 2022
        • 584
        • Planet Earth
        #103
        Found working voltage on ic OB2269
        pin1: 0.0v
        pin2: 1.5v
        pin3: 1.3v <--- !?
        pin4: 2.0v
        pin5: 5.6v
        pin6: 0.0v
        pin7: 11.9v
        pin8: 0.01v
        https://www.youtube.com/watch?v=3p1xYX7B9sY
        Compare to your psu (with C4)
        Pin 1: GND
        Pin 2: .1V to .3V oscillating
        Pin 3: 16V to 19V oscillating
        Pin 4: 0V to 1.3V jumping around sometimes to 3.2V
        Pin 5: same as pin 4
        Pin 6: 0V, sometimes shows .1V or .2V then 0V
        Pin 7: Oscillating between 11V and 15V
        Pin 8: .001V
        If you disconnect psu from mains, and remove secondary output diode and then feed adjustable 10-14v to output terminals, so that tl431 circuit is working, you can monitor opto transistor resistance (primary side) and confirm that switch on at 12v point. Set on 12v with trimpot 1K.
        If this is ok... so 12v connected is to output without diode and optocoupler working.
        When you connected psu in mains like in that condition, what is voltage on each ic pin, is they still pulsating or not?
        If they are still pulsating, and energy on secondary is independed, regulated and calm, that prove that problem is on primary side.
        On primary is generaly main windings and aux... and then we must find a way to separate one from another... maybe is transformer windings problem, if you have ringing tester you can confirm that.
          • 30932
          looked at the datasheet.
          pin3 is not getting power - if it follows the example then it's just a resistor or 2 to the rectified mains - check that.
          • rddube
            Aspiring Expert
            • Jun 2013
            • 908
            pin1: 0.0v
            pin2: 1.5v
            pin3: 1.3v <--- !?
            pin4: 2.0v
            pin5: 5.6v
            pin6: 0.0v
            pin7: 11.9v
            pin8: 0.01v
            Pin 1: GND
            Pin 8: .001V
            Ok, so I'll try to do this and will report back.
            • rddube
              Aspiring Expert
              • Jun 2013
              • 908
              Not sure I understand, pin 3 is getting from 16V to 19V coming from those 2 large caps, going through the 1.5M ohm resistor?
              • rddube
                Aspiring Expert
                • Jun 2013
                • 908
                Hi again, to measure resistance on the opto (primary side), I will have to do it with the secondary energized and I'm not sure it is a good idea to take resistance readings on an energized circuit, because to measure resistance, the multimeter sends a small amount of voltage to calculate the resistance. Anyone?
                • RukyCon
                  A Fake Rubycon
                  • Jan 2017
                  • 816
                  The two sides of an opto are electrically isolated from each other, this is necessary to ensure that the secondary side of the PSU remains isolated from mains, but besides that, i don't think i've ever had any issues with measuring components in-circuit while the circuit was "live", just as long as you don't short anything out.
                  As for the PSU itself, was D2 ever properly tested? I say this because i've had diodes test fine when tested with something like a multimeter (which may only be passing <10ma though the diode) only for said diode to 'fail' under any real load, so sometimes it may be worth testing said diode with a current adjustable power supply. Thought i'd throw my 2 cents in, just in case they help.
                  I'm not a expert, I'm just doing my best.
                    • 30932
                    the first problem is pin3 not getting power
                    if the main caps are stable at about 160v or 340v if it's a doubler, then you need to check the traces and resistor to pin3
                    • harp
                      • Jun 2022
                      • 584
                      • Planet Earth
                      #110
                      You are right, but idea is that you measure resistance on not-energized part of circuit on optocoupler. Optocoupler is device with two isolated circuit. Pin 1 and 2 (LED) is energised in this kind of test, but pin 3 and 4 (optotransistor) are electricaly, physicaly and galvanic isolated from LED side. Only light pass to other side. There not be any voltage, you can check first with voltmeter if doubt.
                      Just DO NOT mismatch sides (like usual ) and measure resistance of powered LED... be careful, attention.
                      • rddube
                        Aspiring Expert
                        • Jun 2013
                        • 908
                        Ok, thanks for the advice. As for D2, I tried another same diode and had the same results, so we're still trying to identify the culprit
                        • rddube
                          Aspiring Expert
                          • Jun 2013
                          • 908
                          Ok, got ya. Will report back.
                          • rddube
                            Aspiring Expert
                            • Jun 2013
                            • 908
                            Do you really mean pin 3? The main cap is getting 160V and on one end of R3 getting 163V, while the other end of R3 (1.5M ohm) going to pin 3 is oscillating between 16V to 19V.
                            • RukyCon
                              A Fake Rubycon
                              • Jan 2017
                              • 816
                              Okay, wasn't aware of that, but good to know. One thing i would probably try (if i had nothing better to try) is maybe swapping C4 with a slightly larger capacitor (say between 22 - 47uf). Worse case i could see is that it makes the PSU slightly slower to start up, though i haven't dealt with this exact controller before, and thus you may want to wait for a second opinion before trying it just to prevent anything from going south.
                              BTW, for curiosity's sake, what brand are those caps on the PSU?
                                • 30932
                                well thats good - i wonder why it's oscillating.
                                maybe the chip is trying to drive a short circuit
                                • rddube
                                  Aspiring Expert
                                  • Jun 2013
                                  • 908
                                  The brand is Cap-Top (Low ESR) - never heard of them, but I did take all of them out and checked them with my component tester and they all tested good. C4 I changed for an Elite cap that measure 10.2 uf ESR .04.
                                  • CapLeaker
                                    Leaking Member
                                    • 7986
                                    I am getting a feeling something is high resistance or open.
                                    • petehall347
                                      • Jan 2015
                                      • 4423
                                      • United Kingdom
                                      #118
                                      post a nice list of present voltages at the ic to compare with what they should be .. lets see if its doing what it is told or if doing as intended with this fault condition .
                                      • rddube
                                        Aspiring Expert
                                        • Jun 2013
                                        • 908
                                        Ok, so did the above test - removed secondary output diode, injected 12V on the output and took measurements of optocoupler resistance primary side:
                                        No voltage applied (power off) - 3.191K ohms
                                        10V applied - 1.086Mohms
                                        12V applied - 1.086Mohms
                                        13.3V applied 1.088Mohms
                                        Took out the voltage from the output, left the secondary diode out and plugged into mains, readings on the chip:
                                        Pin 1 - Gnd
                                        Pin 2 - .03V - 5V jumping around erratically
                                        Pin 3 - .14V to 19V jumping around erratically
                                        Pin 4 - 0V - 1.9V jumping around erratically
                                        Pin 5 - .2V to 4.6V jumping around erratically
                                        Pin 7 - 11V - 22V jumping around erratically
                                        Pin 8 - .01V - .28V jumping around erratically
                                        Will reinstall the ouput diode and do the tests that Petehall437 just asked.
                                          • 30932
                                          pin3 should not be eratic - it should be a stable voltage from that resistor-dropped mains
                                            by sam_sam_sam
                                            03-31-2024, 02:12 PM
                                            by sam_sam_sam
                                            07-01-2024, 06:34 AM
                                          • JimBanville
                                            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                            by JimBanville
                                            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                            Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                            I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                            09-13-2023, 07:21 AM
                                          • madan1
                                            555 based power supply getting too hot
                                            by madan1
                                            Good day.
                                            I have an AC/DC -> DC PWM (rectifier + 555 buck converter) power supply with MDF11n60, which is getting very hot.
                                            The input is AC from a transformer and the output powers a 24v dc fan. The power supply is used to regulate the speed of the fan.
                                            After several runs on the bench power supply I noticed that the mosfet is reaching 80+C*. The mosfet reads fine on component tester, the thermal paste is changed, the fan is cleaned and with freshly oiled bearings.
                                            When powered directly from the bench psu, the fan takes ~0.7A on 12V. The current consumption is similar...
                                            Yesterday, 04:38 PM
