12V 10A CCTV camera system power supply pulsating
  • rddube
    Aspiring Expert
    • Jun 2013
    • 908
    I've been working on trying to resolve why this power supply doesn't work properly i.e. it pulsates from 4 to 6-7 volts on the output and the green led even pulsates.
    I've checked pretty much everything on the board, all capacitors are good as they were all taken out and tested (except for the blue ones), I changed the OB2269AP chip for a new one, checked all mosfets, nothing goes!
    I changed the optocoupler as I read in another thread that that may be the culprit, but to no avail.
    Need some help from the grand masters! Thank you!
    • 30937
    Re: 12V 10A CCTV camera system power supply pulsating
    did you check the output diodes?
    ideally with a load
    • harp
      • Jun 2022
      • 590
      • Planet Earth
      Not grand master, but check the gate that do not floating, surround resistors...
      • rddube
        Aspiring Expert
        • Jun 2013
        • 908
        ideally with a load
        Hi stj,
        Presume you mean these? They are a SR301Q0CT.
        I did check them by takeing that component out and with my multimeter they both tested good. How would I do that with a load (still learning)?
        Many thanks!
        • lotas
          • Jan 2016
          • 4468
          • Russia
          Did you change the TL431?
          • rddube
            Aspiring Expert
            • Jun 2013
            • 908
            No, but I did pull it out and tested it with my component tester and it tested good.
            • R_J
              • 9517
              Replace the small electrolytic C4? near the ic
              Do you have any load on the power supply output? if not it might be in burst mode.
              • rddube
                Aspiring Expert
                • Jun 2013
                • 908
                Hi R_J. I did replace C4 it is a 10uf 50v cap. Here is another photo with voltage readings, and you'll see where the pulsating starts on the primary side.
                • R_J
                  • 9517
                  What is the voltage on Pin #7 of U1?
                  What is the voltage on pin #2 of U1?
                  Do you have a load on the power supply?
                  • lotas
                    • Jan 2016
                    • 4468
                    • Russia
                    Your OB2269AP may be defective, substandard, it has been supplied many times, many PWMs are now on the market with defects (you take them from one batch - they don’t work, you buy them from another place - everything works).
                    • rddube
                      Aspiring Expert
                      • Jun 2013
                      • 908
                      Pin #7 of U1 is oscillating between 9v to 13v-14v
                      Pin #2 of U1 is oscillating between .10v and .20v
                      I tried with a load on the power suppy, but doesn't even power a 12V fan...
                      • rddube
                        Aspiring Expert
                        • Jun 2013
                        • 908
                        Your OB2269AP may be defective, substandard, it has been supplied many times, many PWMs are now on the market with defects (you take them from one batch - they don't work, you buy them from another place - everything works).
                        That could very well be the problem. I purchased these on Ebay from a seller that had 100% feedback, but you never know. I got 5 chips, but they seem to be all from the same batch. Will try to switch and report back. Might even try to reinstall the original one and see. If nothing works, I will order others from a different source. This sucks, if such is the case. Tks Lotas.
                          • Jul 2011
                          • 6024
                          What happened to quality control it does seem to exist if it is a crapshoot if you get a good or not REALLY
                          • rddube
                            Aspiring Expert
                            • Jun 2013
                            • 908
                            Well did the tests with another one from the same batch, same result - pulsating. Removed it, put in the original OB2269AP, same result. Went hunting in my scrap boards and found one that seemed intact, so tried that one same result!
                            What is weird, is when I remove C4 and test, I get no more pulsing on the top pin of R10 (a nice clean stable 18V), but then I get no output on the secondary side, nothing?
                            • CapLeaker
                              Leaking Member
                              • 7991
                              Funny… I just repaired a Northern NVR with 16 cameras two days ago where the power led was blinking and didn’t want to boot. Problem was a bad 16v 1500uF capacitor on the output. Changed the cap and put the NVR back in service. Took me like 30mins to fix. That was an easy repair.
                              Did you check the primary capacitors?
                              • R_J
                                • 9517
                                Check that the feedback winding on the transformer is not open, check R7 and check D2.
                                C4 gets its initial charge via R10, then once the supply starts, C4 should get charged via D2.
                                Pin 7 vdd needs to be at 16.5v or above for the ic to operate.
                                I would also check the voltage across the optocoupler (secondary side) If it is high (1~2v) it may be turning on the optocoupler and taking pin2 low, shutting down the ic.
                                  • 30937
                                  100% feedback is a bit suspicious.
                                  i'm happy with sellers in upper 90's - your gonna get unhappy customers because of poor postal system or just idiots buying stuff they didnt need
                                  • lotas
                                    • Jan 2016
                                    • 4468
                                    • Russia
                                    Yes, it needs to be checked under load, load a 12v car lamp at the output.
                                    • rddube
                                      Aspiring Expert
                                      • Jun 2013
                                      • 908
                                      Not sure which is the feedback winding so I indicated where I think it is in the attached photo with the resistance reading. R7 reads 25 ohms, and D2 I pulled out and tested with multimeter in diode mode and it seems fine.
                                      When you say C4 gets its initial charge via R10, you mean via pin 7 of the chip, because I don't see how C4 could get charged via R10 ? Pin 7 is oscillating between 9V- 13-14V. Finally, measured voltage on secondary side of optocoupler which oscillates between .1V and .6V-.7V.
                                      • rddube
                                        Aspiring Expert
                                        • Jun 2013
                                        • 908
                                        Ok, did try it with a 12v car lamp, but doesn't even show any sign of voltage, no glow at all not even pulsating.
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          by sam_sam_sam
                                          07-01-2024, 06:34 AM
                                        • JimBanville
                                          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                          by JimBanville
                                          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                          Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                          I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                          09-13-2023, 07:21 AM
                                        • madan1
                                          555 based power supply getting too hot
                                          by madan1
                                          Good day.
                                          I have an AC/DC -> DC PWM (rectifier + 555 buck converter) power supply with MDF11n60, which is getting very hot.
                                          The input is AC from a transformer and the output powers a 24v dc fan. The power supply is used to regulate the speed of the fan.
                                          After several runs on the bench power supply I noticed that the mosfet is reaching 80+C*. The mosfet reads fine on component tester, the thermal paste is changed, the fan is cleaned and with freshly oiled bearings.
                                          When powered directly from the bench psu, the fan takes ~0.7A on 12V. The current consumption is similar...
                                          06-23-2025, 04:38 PM
