Dell XPS 9310 GDA30 LA-J143P bios repair please
  • qayyum786
    • Aug 2018
    • 1959
    • INDIA
    #41
    Re: Dell XPS 9310 GDA30 LA-J143P bios repair please
    Originally posted by Leandro_038
    Hello friends, help me with this bios, I have the laptop in the Dell logo and I can't do anything, I upload the original bios, Dell XPS 9310 MODEL P117G st 7TCKP73
    posted bios is configured already
    • Mackey
      • Sep 2022
      • 11
      • Namibia
      #42
      Bios Request of Dell XPS 13 9310 (V_3.13.1)
      hi anyone please help me with my Dell XPS 13 9310 (V_3.13.1) BIOS bin file please i will highly appreciate it friends
      THANK YOU in advance.
      • trunguntilyou
        • Aug 2022
        • 367
        • Vietnam
        #43
        please fix me dell 9310 hangs logo, flash 3 yellow 6 white
        svt: F1NS7C3
        • shah05
          • May 2023
          • 5
          • malaysia
          #44
          Originally posted by hoaca388
          xps 13 9310
          hi i have same problem , if i need to use the given bin file which one i need to use and which win bord ic i need to flash . can help me about this
          • shah05
            • May 2023
            • 5
            • malaysia
            #45
            [Mod. Edit-Vesko356] Use if you want to add something instead of posting a new reply!
            • Vesko356
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria 🇧🇬
              #46
              Originally posted by shah05
              Doc1.pdf
              "Do not touch the 25Q80xxxx chip"
              https://www.badcaps.net/forum/showth...58#post1236358
              25Q256xxxx is the bios spi chip.
              Become a Badcaps supporter
              Thanks to all supporters.​
              • shah05
                • May 2023
                • 5
                • malaysia
                #47
                Originally posted by MicroSMD Lab
                This laptop hangs on Dell logo and gives 2 amber, 4 white blink code (service manual suggest RAM failure). I tried another bios from "bios archives" and got a solid white light which blinks when the charger is plugged in. Processor gets hot enough to turn on the fans and the fans spin constantly even though the lid is closed. All voltages seem to be present and no low resistance on any of the inductors. Thanks in advance.
                i have same problem .
                i attached bios i read from chip. some one can help me .thanks in advance
                Service Tag: 7HC0Q73
                • trepachka
                  • Oct 2022
                  • 457
                  I have a XPS 9310 that randomly reboots, sometimes seconds after powering on, sometimes an hour later. Computer acts on its own: boots into bios, goes into a screen color test. Basically, I suspect the bios is partially corrupt.
                  Service Tag# HN45XD3
                  The bios bin file is below:
                  • Markus1741
                    • Sep 2020
                    • 972
                    • N/A
                    #49
                    Try this ME Clean file ....
                    • trepachka
                      • Oct 2022
                      • 457
                      I tried this bin file and the computer is completely dead. I reflashed the original bios and the computer is back to its original state.
                      Can I try another bin file?
                      • Markus1741
                        • Sep 2020
                        • 972
                        • N/A
                        #51
                        Hi you can try ME Clean file from post #47 me be it helps ...
                        • trepachka
                          • Oct 2022
                          • 457
                          This last file you uploaded worked like a charm. Computer is up and running. Thanks a lot.
                          • Markus1741
                            • Sep 2020
                            • 972
                            • N/A
                            #53
                            Nice to hear that I could help and that the notebook is working again.
                            • kenta
                              • Jul 2023
                              • VietNam
                              #54
                              Re: Dell stuck in dell logo reboot
                              You got this problem after BIOS update? And what was the BIOS version before update?
                              Remember to don't choose (OTP) when you select the chip, because this will add some extra length to the file.
                              Have you verified the file after flashing it to the chip?
                              Can you explain more clearly about this issue? Where can I uncheck OTP?
                              • trunguntilyou
                                • Aug 2022
                                • 367
                                • Vietnam
                                #55
                                dell XPS 13 9310
                                svt : JNPCYD3
                                The machine's status is stuck on the logo, flashing 2 yellow 4 white, help me!
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12424
                                  #56
                                  Originally posted by trunguntilyou
                                  dell XPS 13 9310
                                  svt : JNPCYD3
                                  XPS 13 9310
                                  Service Tag: JNPCYD3
                                  ​https://www.badcaps.net/donate
                                  • trunguntilyou
                                    • Aug 2022
                                    • 367
                                    • Vietnam
                                    #57
                                    XPS 13 9310
                                    The situation is still the same, I tried other files and it's still the same,, maybe it's a main error
                                    • ZZZAC
                                      • Oct 2013
                                      • 14
                                      • England
                                      #58
                                      Hi
                                      I have an XPS9310 with corruption in the bios (3,6LED) I have tried other files here and it now works but does not see any SSD's in the NVME slot. The SSD slot was working before corruption.
                                      Can you repair my original file? Service tag DWLL793
                                      • Vesko356
                                        VIP Moderator
                                        • Aug 2018
                                        • 4386
                                        • Bulgaria 🇧🇬
                                        #59
                                        Originally posted by ZZZAC
                                        Hi
                                        Upload your original bios backup.
                                        • ZZZAC
                                          • Oct 2013
                                          • 14
                                          • England
                                          #60
                                          File attached
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • mikeybass
                                            by mikeybass
                                            04-23-2025, 04:30 PM
                                          • capoplays
                                            Help with BIOS update on Dell G15 5515 after chip replacement
                                            by capoplays
                                            Hey everyone,
                                            I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                                            The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                                            When I check the BIOS using the F12 menu Flash...
                                            10-24-2025, 06:53 AM
                                          • Akhlz001
                                            by Akhlz001
                                            09-20-2025, 07:15 PM
                                          • Sathsul
                                            Dell Latitude 5431 issues with dumping bios
                                            by Sathsul
                                            So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
                                            The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
                                            However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
                                            10-28-2025, 07:49 AM
