Dell XPS 9310 GDA30 LA-J143P bios repair please
  • MicroSMD Lab
    • Sep 2018
    • 147
    • Trinidad and Tobago
    This laptop hangs on Dell logo and gives 2 amber, 4 white blink code (service manual suggest RAM failure). I tried another bios from "bios archives" and got a solid white light which blinks when the charger is plugged in. Processor gets hot enough to turn on the fans and the fans spin constantly even though the lid is closed. All voltages seem to be present and no low resistance on any of the inductors. Thanks in advance.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12713
    Re: Dell XPS 9310 GDA30 LA-J143P bios repair please
    Originally posted by microsmd lab
    this laptop hangs on dell logo and gives 2 amber, 4 white blink code (service manual suggest ram failure). I tried another bios from "bios archives" and got a solid white light which blinks when the charger is plugged in. Processor gets hot enough to turn on the fans and the fans spin constantly even though the lid is closed. All voltages seem to be present and no low resistance on any of the inductors. Thanks in advance.
    xps 13 9310
    If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our bios, boardview & schematic archive.
    Subscribe to support us. It only takes 1 minute:
    https://www.badcaps.net/settings/subscriptions
    • MicroSMD Lab
      • Sep 2018
      • 147
      Thanks, are these dumps from other laptops? Should I try both if the first one I try does not work?
      • cmn.fix
        • 45
        Hello guys! not sure if I should reply to this thread. I have a Dell XPS 13 9310 with 3 amber and 6 white flashes (which normally means corrupt bios or incomplete flash). Is there any way to recover from this? Is someone able to repair this somehow if I post the bios dump? Also, I can see 2 chips: 1 winbond and 1 XMC next to the CPU, which one should I read? Thank you in advance!
        • hardware1
          • Sep 2021
          • 2956
          • N/A
          Read the both chips, upload its content, write your device service tag and someone will try to help you.
          all donations are welcome,
          • cmn.fix
            • 45
            Thank you for the quick reply! I have tried to read the XMC QH256BX1Q with my TL866II Plus and realized it's not supported. Can anyone recommend a programmer for this chip?
              • 24681
              Do you have the latest TL866II software version installed, its in the support list as WSON8
              http://www.autoelectric.cn/MiniPro/TL866II_List.txt
              XM25QH256B @WSON8
              • cmn.fix
                • 45
                XM25QH256B @WSON8
                Top man! I was still on version 7.51. I have managed to read the XMC but not sure if the Winbond 25Q80DV1G read is fine as flash detect gives me 26 possible selections. Also, second chip looks mostly empty after reading.
                Thank you guys for taking your time with a newb!
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12713
                  top man! I was still on version 7.51. I have managed to read the xmc but not sure if the winbond 25q80dv1g read is fine as flash detect gives me 26 possible selections. Also, second chip looks mostly empty after reading.
                  xps 13 9310
                  • cmn.fix
                    • 45
                    Originally posted by hoaca388
                    xps 13 9310
                    Thank you! I see they are different size and can't tell what chip to flash each of them (I guess the _R goes to the winbond?). Also I forgot to post the service tag for it: 7HC0Q73
                      • 24681
                      The winbond chip is only 1MB and its not the bios chip , its only 8 Mega Bits . The XM25QH256B is 256 Mega bits ,divide 256 by 8 = 32 ,so 32MB.
                      Both files posted by hoaca388 are 32MB .Dell provide 2 different updates in the bios update, and he doesn`t know which one is for laptop so he`s posted both. Your laptop spec from the service tag doesn`t give the CPU ID ,but does list the platform as MODENA TGL .Try the TGL bios first, the other one i assume is for Tiger Lake Refresh CPU`s.
                      https://www.dell.com/support/home/en...QT090/overview
                      • cmn.fix
                        • 45
                        First one worked like a charm. You guys are amazing. Thank you hoaca388 and thank you SMDFlea!
                        • sikocan
                          • Oct 2019
                          • 356
                          Can someone fix this BIOS file? Stuck on blank screen, same as his, 3 amber 6 white LED.
                          • lapfix
                            • Mar 2020
                            • 2775
                            • my workshop
                            Your servicetag !
                            • sikocan
                              • Oct 2019
                              • 356
                              Hlb6793
                              • lapfix
                                • Mar 2020
                                • 2775
                                • my workshop
                                Hlb6793
                                Try this clean me of your bios and give feedback
                                • Don-qie
                                  • Feb 2023
                                  • 5
                                  hello,
                                  I'm also in a similar predicament as above. I flashed with the modenaTGL bios and that brought everything back to life.
                                  I'm curious as to the method graft the new service tag and windows OEM key (another question here, the above threads looks to be only modifying service tag -- not windows key... are the dell keys generic? ) into a clean ME bios on these new dell laptops? I've taken a look at this bios via HxD and UEFITool but it looks like the bios guard requires disassembly ( dinked around a bit with Dell PFS Update Extractor too )
                                  anyways, would be cool to learn how to do it if anyone could point me in the right direction. feels weird just asking others to do the work for me.
                                  Thanks!
                                  • Don-qie
                                    • Feb 2023
                                    • 5
                                    i looked at the bin files a bit more last night. was able to spot the windows key and replace no problem. this service tag thing is a bit strange though. cant seem to spot it anywhere in the bios. any suggestions?
                                    • lapfix
                                      • Mar 2020
                                      • 2775
                                      • my workshop
                                      You ask about :
                                      1 = how to built a new bios
                                      2 = How to copy servicetag and windows key from old to new dump
                                      3 = How to clean me the new built
                                      this is it !
                                      • Don-qie
                                        • Feb 2023
                                        • 5
                                        yes sir, in so many words!
                                        reading up on this site for bios editing seems straight forward to me. however, these new style dell laptops feel a little bit different and documentation feels a little flimsy -- at least from what I've found lately
                                        • Tesla
                                          Dell XPS-15 (9520) Mostly Bricked after common BIOS-Firmware upgrade - Full Repair Log
                                          by Tesla
                                          I have a Dell XPS-15 (9520) with the LA-L402P motherboard. It seems to have bricked itself after a common BIOS-Firmware upgrade. Now, it just shows BIOS screen for a few seconds before turning-itself back Off (and doesn't seem to be fully Posting). I've done these many times before with no problems.
                                          I was hoping to please have my own-thread to work-through this (hopefully successful) repair as a whole. Apart from the possible need to have a BIOS-dump fixed-up, I have a feeling I'm going to have other questions. This includes using my new XGecu-T76 for the first time (should be here...
                                          03-19-2026, 07:51 PM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • TopPop
                                          Dell Latitude 5530 BIOS Password Removal Attempted but I Broke the Laptop
                                          by TopPop
                                          Sorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
                                          I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip...
                                          12-14-2025, 09:40 PM
                                        • mikeybass
                                          by mikeybass
                                          04-23-2025, 04:30 PM
                                        • kantusjack
                                          Dell XPS12 9Q23 board – no POST after BIOS corruption, now unstable after crossflash
                                          by kantusjack
                                          I am troubleshooting a Dell XPS 12 with motherboard 9Q23 (Compal LA-8821P) that failed during a Windows 10 update. The system powered off abruptly and never booted again. Initial behaviour
                                          • No display at any time (internal or external)
                                          • Power button would immediately shut the system off
                                          • System auto-powers when AC adapter is connected (battery removed)
                                          • Beep code: 3 beeps – pause – 3 beeps (continuous)
                                          • Fan never spins
                                          This behaviour suggests that POST starts but fails very early in initialization. On this platform, 3 beeps are generally associated with system board / chipset...
                                          03-14-2026, 10:33 AM
