Dell XPS 9310 GDA30 LA-J143P bios repair please
    Re: Dell XPS 9310 GDA30 LA-J143P bios repair please
    Originally posted by Leandro_038 View Post
    Hello friends, help me with this bios, I have the laptop in the Dell logo and I can't do anything, I upload the original bios, Dell XPS 9310 MODEL P117G st 7TCKP73
    posted bios is configured already
      Bios Request of Dell XPS 13 9310 (V_3.13.1)
      hi anyone please help me with my Dell XPS 13 9310 (V_3.13.1) BIOS bin file please i will highly appreciate it friends
      THANK YOU in advance.
        please fix me dell 9310 hangs logo, flash 3 yellow 6 white
        svt: F1NS7C3
          Originally posted by hoaca388 View Post
          xps 13 9310
          hi i have same problem , if i need to use the given bin file which one i need to use and which win bord ic i need to flash . can help me about this
            [Mod. Edit-Vesko356] Use if you want to add something instead of posting a new reply!
              Originally posted by shah05 View Post
              Doc1.pdf
              "Do not touch the 25Q80xxxx chip"
              https://www.badcaps.net/forum/showth...58#post1236358
              25Q256xxxx is the bios spi chip.
              Become a Badcaps supporter
              Thanks to all supporters.
                Originally posted by MicroSMD Lab View Post
                This laptop hangs on Dell logo and gives 2 amber, 4 white blink code (service manual suggest RAM failure). I tried another bios from "bios archives" and got a solid white light which blinks when the charger is plugged in. Processor gets hot enough to turn on the fans and the fans spin constantly even though the lid is closed. All voltages seem to be present and no low resistance on any of the inductors. Thanks in advance.
                i have same problem .
                i attached bios i read from chip. some one can help me .thanks in advance
                Service Tag: 7HC0Q73
                  I have a XPS 9310 that randomly reboots, sometimes seconds after powering on, sometimes an hour later. Computer acts on its own: boots into bios, goes into a screen color test. Basically, I suspect the bios is partially corrupt.
                  Service Tag# HN45XD3
                  The bios bin file is below:
                    Try this ME Clean file ....
                      I tried this bin file and the computer is completely dead. I reflashed the original bios and the computer is back to its original state.
                      Can I try another bin file?
                        Hi you can try ME Clean file from post #47 me be it helps ...
                          This last file you uploaded worked like a charm. Computer is up and running. Thanks a lot.
                            Nice to hear that I could help and that the notebook is working again.
                              Re: Dell stuck in dell logo reboot
                              Originally posted by hardware1 View Post
                              You got this problem after BIOS update? And what was the BIOS version before update?
                              Remember to don't choose (OTP) when you select the chip, because this will add some extra length to the file.
                              Have you verified the file after flashing it to the chip?
                              Can you explain more clearly about this issue? Where can I uncheck OTP?
                                dell XPS 13 9310
                                svt : JNPCYD3
                                The machine's status is stuck on the logo, flashing 2 yellow 4 white, help me!
                                  Originally posted by trunguntilyou View Post
                                  dell XPS 13 9310
                                  svt : JNPCYD3
                                  XPS 13 9310
                                  Service Tag: JNPCYD3
                                    XPS 13 9310
                                    The situation is still the same, I tried other files and it's still the same,, maybe it's a main error
                                      Hi
                                      I have an XPS9310 with corruption in the bios (3,6LED) I have tried other files here and it now works but does not see any SSD's in the NVME slot. The SSD slot was working before corruption.
                                      Can you repair my original file? Service tag DWLL793
                                        Originally posted by ZZZAC View Post
                                        Hi
                                        Upload your original bios backup.
                                          File attached
