MS Surface no touchscreen after cleaning ME Firmware **FIX**
    • 21197
    Re: MS Surface no touchscreen after cleaning ME Firmware **FIX**
    Originally posted by Penetre
    after an official firmware update, the surface me must be corrupted.
    does not finish installing the firmware update, error Code 10. the touch does not work.
    The BIOS has never been touched, the only thing I have done is change all the hardware parts, LCD, Flex, touch plate...
    I think that I would only have to modify in the bios, so that the touch is activated.
    You havn`t mentioned the model number.If the flash descriptor is locked you will need an SPI programmer to backup the whole bios.
    • Penetre
      • Apr 2022
      • 7
      • España
      the model is a surface 6 pro 1796. I have to desolder the BIOS chip, right?
      I have tried to boot from a USB efi Shell + ru.efi. It turns on correctly, but I don't know how to use it.
      is it impossible to get a dump from there?
      I'm sorry if my questions are silly, I'm still learning on this subject.
        • 21197
        You will have to use an SPI programmer.If the chip is a WSON type (no legs on the chip,soldered flat) you will need to desolder it and use a WSON adapter board,or use a WSON8 pogo adapter
        https://www.badcaps.net/forum/showth...ght=WSON8+pogo
        https://www.aliexpress.com/item/1005001830846980.html
        https://www.badcaps.net/forum/showpo...40&postcount=2
        • Penetre
          • Apr 2022
          • 7
          • España
          wow thank you very much, I hadn't seen that you answered.
          I continue studying, researching and going crazy, looking on the internet, some solution so as not to have to desolder hahaha
          But I think your solution is the most "easy", although it scares me.
          Using the aliexpress adapter is another good option!
          Question from Noob, from the "Ru.exe, Ru.EFI", could not modify the values?
          Thank you very much again.
          • huynhdoluan
            • Oct 2021
            • 31
            • VietNam
            please tell me where you get the ISH Firmware file from, if not, you can't build the file
              • 21197
              The ISH firmware is in the bios
              • ahmypc
                • Oct 2013
                • 79
                • Turkey
                #27
                Which file in pro 7 needs to be changed for me region cleaning?
                  • 21197
                  ME Sub Partition.bin .It is the ME firmware.The new PRD_RGN firmware from the repository must be renamed to: ME Sub Partition.bin .If you can`t find the same PRD_RGN version use the nearest older or newer one.
                  Follow the win-raid guide "D4. CSME 11 - 15 & CSTXE 3 - 4"
                  https://winraid.level1techs.com/t/gu...zation/31277/2
                  • ahmypc
                    • Oct 2013
                    • 79
                    • Turkey
                    #29
                    Thanks.
                    • keczuk
                      • Dec 2019
                      • 83
                      • WWW
                      #30
                      So what if i don't have oryginal bios for Surface 5 PRO.
                      I have ISHC Valid = True but the touch screen not working.
                      How to Fix this ?? Or this is not possible if I don't have original bios
                        • 21197
                        Have you installed all updates and drivers from microsoft. Make a bios backup and open it with FIT version 11 ,the ISH settings should be set the same as they are in the 1st picture (left side) at post #1
                        • keczuk
                          • Dec 2019
                          • 83
                          • WWW
                          #32
                          Yes i have installed all driver. I try this on W10 and W11 and is same result. On bios in FIT is GOOD but touchscreen not working.
                          • zijie
                            • Jan 2023
                            • china
                            #33
                            awosome man!
                            • zijie
                              • Jan 2023
                              • china
                              #34
                              Bro,my surface pro4 touch no woring because of bios,but the original bios was lost,can i use this method to repair it?
                              • peste
                                • Dec 2016
                                • 12973
                                • ROMANIA
                                #35
                                yes, but first make a copy of the bios...
                                • abbassink
                                  • Aug 2015
                                  • 83
                                  • iran
                                  #36
                                  How to open the file (bios bin file)
                                    • 21197
                                    Your ME firmware is corrupted.Cleaning the ME firmware might fix it, if it will open with FIT.Post your bios in one of the same model thread topics if you can`t clean the ME yourself.
                                    Here`s the ME cleaning guides https://www.badcaps.net/forum/showpo...41&postcount=3
                                    • Lgatom
                                      • Jan 2023
                                      • Brasil
                                      #38
                                      Good afternoon, I have a Surface Pro 4 with the Touch not working and the error in the device listing, for the solution according to the procedure described above would I have to access the BIOS memory physically or would there be some software to be used?
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 11897
                                        #39
                                        You have to access the BIOS memory physically by a programmer.
                                        • Dan20701
                                          • Sep 2020
                                          • 199
                                          • United Kingdom
                                          #40
                                          Hello I am working on a Microsoft Surface Pro 6, M1086841-003
                                          and I have no touch screen, I have been following this guide and I think
                                          I get what to do I am just having problems picking what file to use
                                          I have ME Version 11.7.4.3330
                                          There are two files in, CSME 11.7 Repository r10, what one do I use
                                          11.7.4.3330_CON_H_DA_PRD_RGN
                                          11.7.4.3330_CON_LP_C_NPDM_PRD_RGN
                                          Any help picking a file please, How do I know what one?. Thanks.
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • Tamo Neko
                                            Request for MX25VB8035F (1MB) Firmware Dump – Asus TUF Gaming H670-Pro
                                            by Tamo Neko
                                            I'm working on an Asus TUF Gaming H670-Pro motherboard and need help finding a firmware dump for the MX25VB8035F (1MB) SPI flash chip.
                                            What Happened:
                                            I mistakenly removed and erased this 1MB chip, thinking it was part of the main BIOS.
                                            • I later found that the board has two main BIOS chips (8MB + 16MB), which I have backups for.
                                            • My backup for the MX25VB8035F chip is just an empty 1MB segment filled with FFs, meaning I have no valid data to restore.
                                            What I Need:
                                            • A firmware dump for the MX25VB8035F chip from the same motherboard (or a compatible
                                            02-12-2025, 11:29 PM
                                          • Mephysis
                                            DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
                                            by Mephysis
                                            Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
                                            I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
                                            03-27-2025, 02:34 AM
                                          • gun4as
                                            Need firmware dump for LG 23MP48HQ-P
                                            by gun4as
                                            Hello everyone, I have an LG 23MP48HQ-P with a mainboard EAX65543134. After a power flicker, the monitor only shows the "No Signal" message but goes to a black screen with a brief flash when an HDMI/VGA cable is plugged in. I cannot enter the OSD menu. All main voltages (18V, 5V, 3.3V) are stable under load. I made a backup of the firmware, but it was *after* the fault occurred, so my backup is likely corrupted. I flashed it back with no change in behavior. I can only find the firmware for the 24M38H model online. Could someone please share a working firmware dump for the 23MP48HQ-P?...
                                            08-25-2025, 04:28 AM
                                          • eurocomputerland
                                            Canon iSensys MF264DW II, firmware memory dump
                                            by eurocomputerland
                                            Hi, i have canon mf264 printer which is stuck in download firmware mode and I'm after a firmware memory dump for this model, so I can try to rewrite. Thanks for your kind help!
                                            07-22-2025, 04:48 AM
