Dell G5 15 5500 bios needed
hello every one
i have dell g5 15 5500
mainboard Selek g3 mlk n18p 19795-1
Service Tag: 2LWMG63
it had short circuit on gpu mosfet
after replacing it came to life but stuck on logo
tried whith to flash another ec.bin it worked but fan are very loud and it shut down after afew minute
can any one fix my ec bios
i uploded both ec and main
best regardsAttached Filesif you find these attachements useful please consider making a small donation to the site
Tryhello every one
https://www.badcaps.net/donateComment
Try older version.Attached Filesif you find these attachements useful please consider making a small donation to the site
hello every one
mainboard Selek mlk n18E 19753-1
Service Tag: 519P463
Please clean my file, no displayAttached Filesif you find these attachements useful please consider making a small donation to the site
try and feedbackAttached Filesif you find these attachements useful please consider making a small donation to the site
Off topic, post by the model number in the thread title. This thread is for the G5 15 5500 ,yours is G3 15 3500 , post your request in the G3 15 3500 topic -> https://www.badcaps.net/forum/troubl...3500-bios-helpComment
Hello everyone 👋
is there a way to provide the correct Service Tag from this dump files?
i think the bin on the main chip is corrupted and the Tags on the case are faded too 😢
G5 5500
selek mlk n18e 19753 1
Thanks 💙Attached Filesif you find these attachements useful please consider making a small donation to the site
G5 15 5500Attached Filesif you find these attachements useful please consider making a small donation to the site
Hello guys, i hope i get the help i need here,
I had displays problems with my laptop, it's a Dell G5 15 5500, i took it to some "expert", the display is fine now, while i look at the bios setup, i have the wrong one (screenshot taken) , it shows that i have the G3 3500 with no service tag and asset tag, i guess the expert resetted it and installed another bios?
Hope my problem is well explained, can anyone help me get my laptop setup to its default configuration?
Thanks1 PhotoComment
Post your dump and service tag number ?Hello guys, i hope i get the help i need here,
Thanks↵
Hello, please could repair my bios, the laptop turns on but with black screen, there is no video, I appreciate the help.
DELL G5
Motherboard: SELEK MLK N18E 19753-1
ServiceTag: 99TJ103
try thisAttached Filesif you find these attachements useful please consider making a small donation to the site
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by capoplaysHey everyone,
I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
When I check the BIOS using the F12 menu Flash...-
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
by 417731Hi, I have a problem while updating the bios 1.27.0. After that the display went off & the bios states as Dell Inspiron 3505 in the F2 boot > bios > Device when I plug into a secondary monitor. As I don't have any experience in bios, request you to please help me to flash the Vostro bios as they share the common motherboard (GDI53 LA-K037P).
Model: Dell Vostro 3405
Tag:F0B1YF3
CPU:Ryzen 3500U
Thanks in advance-
- Loading...
