Hi I'm new here, need help, the original bios was lost, tried so many files and didn't work the best result that i have the laptop stays stucked at tpm screen and if i press F2 stay stucked on the bios scren, keyboard not responding, my laptop is a G3 3500 motherboard 19753-1 pcb selek n18e
Dell G5 15 5500 bios needed
Re: Dell G5 15 5500 bios needed
Hi I'm new here, need help, the original bios was lost, tried so many files and didn't work the best result that i have the laptop stays stucked at tpm screen and if i press F2 stay stucked on the bios scren, keyboard not responding, my laptop is a G3 3500 motherboard 19753-1 pcb selek n18e -
My board hanging at bios screen; need to reflash bios bin.... kindly send me any working fileAttached Filesif you find these attachements useful please consider making a small donation to the site
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Here's your new file, try it and let me know.Attached Filesif you find these attachements useful please consider making a small donation to the site
OK, try this one with your 16MB chip.Attached Filesif you find these attachements useful please consider making a small donation to the site
g5 15 5500Attached Filesif you find these attachements useful please consider making a small donation to the site
​https://www.badcaps.net/donateComment
Try this one. If it doesn't work then let me know i will make another bios of different version. This is the first release of bios for this motherboard.Attached Filesif you find these attachements useful please consider making a small donation to the site
Dell G5 15 5500 g3 need bios
pcb selek g3 mlk n18p 19795-1 403yf$ca
The old bios is not available
It gives a loud beep from the fans and restarts without its imageAttached Filesif you find these attachements useful please consider making a small donation to the site
Hi All! Please add svtag BZFQ563 . Thanks All!Attached Filesif you find these attachements useful please consider making a small donation to the site
Hello, someone can clean my bios and ec dump? Big thanks in advance.
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by capoplaysHey everyone,
I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
When I check the BIOS using the F12 menu Flash...-
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
by 417731Hi, I have a problem while updating the bios 1.27.0. After that the display went off & the bios states as Dell Inspiron 3505 in the F2 boot > bios > Device when I plug into a secondary monitor. As I don't have any experience in bios, request you to please help me to flash the Vostro bios as they share the common motherboard (GDI53 LA-K037P).
Model: Dell Vostro 3405
Tag:F0B1YF3
CPU:Ryzen 3500U
Thanks in advance-
- Loading...
