Dell G5 15 5500 bios needed
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
Re: Dell G5 15 5500 bios needed
Here are you New Bios, try it and give me results.Attached Filesif you find these attachements useful please consider making a small donation to the site
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Perhaps someone can verify that I am having bad BIOS issues. Currently, the BIOS is password protected by 8FC8 password. I have the password for it. However, on every boot, the keyboard starts flashing different colors (I think that's normal), the screen that is supposed to be prompting me to enter the password gets distorted. I get a window with its message cut off at different times. May be on my 10th attempt I get the 8FC8 window with full message and the box to enter the password in but the keyboard gets disabled, no keys work. External keyboard also does not work. However, I can do Ctrl-Alt-Del to reboot no problem. My thinking is if BIOS is bad, then you get random results like I am getting now.
Can someone confirm it's the BIOS?
Also, does the motherboard have a single or two BIOS chips? I am yet to take out the motherboard from the case.Comment
All speculation is conjecture.Perhaps someone can verify that I am having bad BIOS issues. Currently, the BIOS is password protected by 8FC8 password. I have the password for it. However, on every boot, the keyboard starts flashing different colors (I think that's normal), the screen that is supposed to be prompting me to enter the password gets distorted. I get a window with its message cut off at different times. May be on my 10th attempt I get the 8FC8 window with full message and the box to enter the password in but the keyboard gets disabled, no keys work. External keyboard also does not work. However, I can do Ctrl-Alt-Del to reboot no problem. My thinking is if BIOS is bad, then you get random results like I am getting now.
If your device has 2 bios chips, they will be located near each other (on Dell computers).
Solution: post your bios file here we will rebuild it so you can rule out the cause of the error caused by bios (since you already have the password, you don't need to delete the password in the new file)↵
​https://www.badcaps.net/donateComment
I have attached the BIOS I extracted from both chips. I would appreciate if someone fixed it for me. It does have 8fc8 password lock on it and I do have the password for it. But if you can remove the password while at it, that would help me avoid doing this extra step. Thank you.Attached Filesif you find these attachements useful please consider making a small donation to the site
Re: dell g5 5500 bios clean please
attachedAttached Filesif you find these attachements useful please consider making a small donation to the site
thankyou for your time, unfortuantely i have 3 backups only with the OTP and have since flashed a couple roms on here in hopes of fixing the issue.
I have added the 2 bios files if you can assist in anyway it would be awesomeAttached Filesif you find these attachements useful please consider making a small donation to the site
Here's your New BIOS, try it and let me know.Attached Filesif you find these attachements useful please consider making a small donation to the site
I would be grateful if you could send me the bios files for this machine.
I tried all of the above and none of them worked.
S/N: HW2XF63
I attach the old bios.Attached Filesif you find these attachements useful please consider making a small donation to the site
Dell G5 15 5500 Bios bricked after update
Model P89F
P89F003
S/N HW2XF63
Laptop was bricked after latest bios update. It has dual bios. I flashed many other files from another thread with no luck.Attached Filesif you find these attachements useful please consider making a small donation to the site
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by capoplaysHey everyone,
I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
When I check the BIOS using the F12 menu Flash...-
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
by 417731Hi, I have a problem while updating the bios 1.27.0. After that the display went off & the bios states as Dell Inspiron 3505 in the F2 boot > bios > Device when I plug into a secondary monitor. As I don't have any experience in bios, request you to please help me to flash the Vostro bios as they share the common motherboard (GDI53 LA-K037P).
Model: Dell Vostro 3405
Tag:F0B1YF3
CPU:Ryzen 3500U
Thanks in advance-
- Loading...
