Dell G5 15 5500 bios needed
Re: Dell G5 15 5500 bios needed
here are the workers, but an error comes out
Alert! TPM device is not detectedAttached Filesif you find these attachements useful please consider making a small donation to the site
https://www.dell.com/support/kbdoc/e...ecision-or-xps
https://www.dell.com/support/kbdoc/e...-and-bitlocker
Intel PTT must be enabledComment
Dell G5 15 5500 motherboard code : 19753-1.
orginal dump deleted...
Service tag : 6PDS663
the bios in the forum works but it turns on automatically and the fan is constantly spinning at high speed.
please clean me working orginal dump...Comment
THIS MY tested bios you can try post you replyAttached Filesif you find these attachements useful please consider making a small donation to the site
can you help me?https://www.dell.com/support/kbdoc/e...ecision-or-xps
I think another service has removed the bios chips before.so i can't access the original dumps.it is necessary to extract a bios from the original dell site......Comment
this file both bios flash it and wait display come 100%.check it replay me.Attached Filesif you find these attachements useful please consider making a small donation to the site
SIO number : MEC1515-NBhttps://www.dell.com/support/kbdoc/e...ecision-or-xps
Try this 8MB fixed file, and flash the 16MB from post #9Attached Filesif you find these attachements useful please consider making a small donation to the site
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by capoplaysHey everyone,
I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
When I check the BIOS using the F12 menu Flash...-
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
by 417731Hi, I have a problem while updating the bios 1.27.0. After that the display went off & the bios states as Dell Inspiron 3505 in the F2 boot > bios > Device when I plug into a secondary monitor. As I don't have any experience in bios, request you to please help me to flash the Vostro bios as they share the common motherboard (GDI53 LA-K037P).
Model: Dell Vostro 3405
Tag:F0B1YF3
CPU:Ryzen 3500U
Thanks in advance-
- Loading...
