Dell G5 15 5500 bios needed
  • SComputers
    • Oct 2024
    • 15
    Originally posted by Carlos Simbaña
    It's alive! Now have video, Thank you so much! But it has Alert TPM device is not detected, can that be solved?
    try this one
    • Carlos Simbaña
      • Jun 2024
      • 45
      • Ecuador
      #202
      Originally posted by SComputers
      try this one
      I tried, it´s working perfectly now, thanks a lot, you are the best
      • leonce
        • Mar 2018
        • 21
        • cote divoire
        #203
        hello every one
        i have dell g5 15 5500
        mainboard Selek mlk n18E 19753-1
        Service Tag: deleted from the computer cover, and I don't know how to get it from the dump
        Please clean my file, no display
        • SComputers
          • Oct 2024
          • 15
          Originally posted by leonce
          hello every one
          try this
          • leonce
            • Mar 2018
            • 21
            • cote divoire
            #205
            The fans spin very loudly and after 5 seconds the computer shuts down. When I turn it back on, it's the same behavior. tanks SComputers for your help
            • zenius
              by zenius
              12-08-2024, 06:13 AM
            • mikeybass
              by mikeybass
              04-23-2025, 04:30 PM
            • capoplays
              Help with BIOS update on Dell G15 5515 after chip replacement
              by capoplays
              Hey everyone,
              I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
              The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
              When I check the BIOS using the F12 menu Flash...
              10-24-2025, 06:53 AM
            • Akhlz001
              by Akhlz001
              09-20-2025, 07:15 PM
            • 417731
              BIOS needed for Dell Vostro 3405
              by 417731
              Hi, I have a problem while updating the bios 1.27.0. After that the display went off & the bios states as Dell Inspiron 3505 in the F2 boot > bios > Device when I plug into a secondary monitor. As I don't have any experience in bios, request you to please help me to flash the Vostro bios as they share the common motherboard (GDI53 LA-K037P).
              Model: Dell Vostro 3405
              Tag:F0B1YF3
              CPU:Ryzen 3500U
              Thanks in advance
              07-06-2025, 06:48 PM
