HP 840 G7 password
  • jotati7062
    • Jan 2024
    • 12
    • SA
    #321
    Originally posted by Vesko356
    You MUST:
    Thank u I end up using RCUnlocker on the 16mb chip & its good now.
    • Vesko356
      Vesko356 commented
      Editing a comment
      Good for you. You're welcome.
  • mr.Data
    • Sep 2018
    • 74
    • Netherlands
    #322
    Hello friends,
    I have a EliteBook 840 G7 where I flashed the 32mb BIOS chip with HPUnlocker but the password still exists.
    Now I read about unlocking the 16mb chip and also use RCUnlocker.
    I could not find the 16mb chip.
    Anybody have experience with unlocking an 840 G7?
    • Vesko356
      Vesko356 commented
      Editing a comment
      Thread merged.
      Read the rules before posting
      You MUST:
      • Post under a related thread if it exists
      • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
  • leo037_2023
    DEMIGOD OF BIOS
    • Oct 2023
    • 63
    • Buenos Aires - Argentina
    #323
    try to find chips like WINBOND - xmc - MXIC - GIGADEVICE - cFeon and backup and attach here...
    • Elaid02
      • May 2022
      • 34
      • FRANCE
      #324
      Hii
      Need unlock bios password
      Hp elitebook 840 G7
      SN : 5CG1053NYJ
      Bios attached
        • 20888
        Originally posted by Elaid02
        Hii
        Hp elitebook 840 G7
        SN : 5CG1053NYJ
        Bios attached
        You MUST:
        • rex98
          • Feb 2023
          • 1278
          • Mandaue CEBU, Philippines
          #326
          Hii
          Hp elitebook 840 G7
          SN : 5CG1053NYJ
          Bios attached
          only flash this EC. do not touch the main.
          • izaak94
            • Mar 2019
            • 126
            • mexico
            #327
            Hello, I need help deactivating Absolute. Thank you
            SN:5CG1049713
            • izaak94
              • Mar 2019
              • 126
              • mexico
              #328
              Originally posted by rex98
              i cant upload directly.
              first boot reset to factory defaults and exit, 2nd boot reset security settings to defaults.
              use bcu here's you dmi info:
              Serial Number: 5CG1049713
              Product Number: 20V17UC#ABM
              CT Number: PJSCQ00WBERONK
              Description: HP EliteBook 840 G7 Notebook
              build_id: 20WWCMBT601#SABM#DABM
              Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBapaqauawb8bUcAdUdpdqeMfPguhKhkj4jhk8mEmV.tN
              MAC Address: B0-22-7A-72-6C-84
              Thanks, working perfect
              • Sagnusm
                • Mar 2024
                • 3
                • Ukraine
                #329
                Hello! I received a faulty 840 G7 laptop with two BIOS chips removed. My customer said that the laptop was locked to the company (Windows Autopilot?) Serial: 5CG1364XCT (this number inside the dump matches). I couldn't start the laptop - it blinks 2 times. Probably the original dumps are damaged. I tried different ways of cutting off the dump from the official website, also with replacing the ME region. I also tried flashing both chips from "#298".
                Does anyone have verified service dumps for this model? with which the laptop will definitely start
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11735
                  #330
                  XX
                  • Sagnusm
                    • Mar 2024
                    • 3
                    • Ukraine
                    #331
                    Originally posted by hoaca388
                    XX
                    Thanks for the given file, however it did not work at all. The mainboard behaves faulty as before without any improvement. I tried this dump you sent in pair with my native dump EC, as well as with other EC dumps I could find. No positive result.
                    I would like to ask if this dump you sent launches any mainbord, because in my case the removal of slips by the hub is not executed, as well as the power cores is absent because of this. I would like to be sure that the problem I am facing is not caused by the BiOS dumps pairing.
                    • Rolandoaquino
                      • Feb 2021
                      • 13
                      • mexico
                      #332
                      Serial Number:5CG0441QGS
                      Product Number: 24X44UC#UUF
                      XU100259-20079
                      A/S 1588-3003
                      R-R-hpk-HSN-136C-4
                      thank you everyone
                      • qayyum786
                        • Aug 2018
                        • 1933
                        • INDIA
                        #333
                        XU100259-20079
                        A/S 1588-3003
                        R-R-hpk-HSN-136C-4
                        thank you everyone
                        try
                        • Rolandoaquino
                          • Feb 2021
                          • 13
                          • mexico
                          #334
                          the password is gone but it show like this please help thank you
                          • Rolandoaquino
                            • Feb 2021
                            • 13
                            • mexico
                            #335
                            SWAT Issue please fix
                            XU100259-20079
                            A/S 1588-3003
                            R-R-hpk-HSN-136C-4
                            thank you everyone
                            • rex98
                              • Feb 2023
                              • 1278
                              #336
                              XU100259-20079
                              A/S 1588-3003
                              R-R-hpk-HSN-136C-4
                              thank you everyone
                              first boot press f10 reset bios to factory defaults and exit, 2nd boot reset security settings to daults and exit.
                              you can disable permanently the absolute lock in BCU tool.
                              here's your DMI info. use bcu:
                              Serial Number: 5CG0441QGS
                              CT Number: PJSCQ00WBEE0WF
                              build_id: 20WWCMBT601#SUUF#DUUF
                              Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPguhKhkjhk8mE.ye
                              MAC Address: 3C-18-A0-7E-31-D9​
                              • Rolandoaquino
                                • Feb 2021
                                • 13
                                • mexico
                                #337
                                Thank you so much i appreciate it. God Bless team badcaps. Will try!
                                • dreamvin
                                  • Aug 2018
                                  • Ukraine
                                  #338
                                  please help delete module absolute computrace NB hp elitebook 840 g7
                                  sn 5CG0523JYH
                                  SKU 24M80UP#ABA
                                  UUID 2FFD401C6ADE6F41B97F8B6FA2FA706B
                                  UUIDsf 1C40FD2F-DE6A-416F-B97F-8B6FA2FA706B
                                  ASSET TRAKING NUMBER 4420021
                                  • smallvhin
                                    • Jul 2015
                                    • 182
                                    • philippines
                                    #339
                                    Master pls. help me to clean dump file.
                                    SN:5CG0465ZFL
                                    ProdID: 24X44UC#UFF
                                    more thanks master🙏
                                    • rex98
                                      • Feb 2023
                                      • 1278
                                      #340
                                      SN:5CG0465ZFL
                                      ProdID: 24X44UC#UFF
                                      more thanks master🙏
                                      here.
