HP 840 G7 password
  • stars-n-dust
    • Apr 2019
    • 59
    Re: HP 830 G7 password
    HP EliteBook 830 G7 with password, please help unlock.
    • hoaca388
      Badcaps
      • Jan 2022
      • 12431
      #102
      Re: HP 840 G7 password
      Use this tool with EC file.
      https://www.badcaps.net/forum/showth...ght=rcunlocker
      • rampapalos
        • Feb 2020
        • Philippines
        #103
        Originally posted by Vesko356
        You're welcome.
        how can you attached the file 3 bios are there what are use for flash how can you find the 2 bios can you give same pic so i ca solve the problem
        • skazide
          • Jul 2015
          • 144
          • morocco
          #104
          plz need to unlock this lap
          camellia-6050a3140901-mb-a01(a1)
          • Mazorca
            • Jan 2017
            • 463
            Try the 16MB bin with RCUnlocker.
            • skazide
              • Jul 2015
              • 144
              • morocco
              #106
              i did thidn't work
              • Mazorca
                • Jan 2017
                • 463
                RCUnlocker did unlock the 16MB here locally, but if it didn't work, test the 32MB. First time I do this. Maybe start with flashing 32MB only.
                • skazide
                  • Jul 2015
                  • 144
                  • morocco
                  #108
                  after a long time 10 to 20 minute it finshed , then asked for information on the pic i tried to just enter some bit dont know octet de fonction ....but when iam on the bios tried to disable secure boot to install pc to update bios he demande the pass so the pass still existe?
                  • Mazorca
                    • Jan 2017
                    • 463
                    Translates as function byte, so probably password is still there. Sorry the method didn't work, applied one that is for 840 G8.
                    • skazide
                      • Jul 2015
                      • 144
                      • morocco
                      #110
                      its ok friend thanks for your help, a guys send me a dump and it worked
                      • Mazorca
                        • Jan 2017
                        • 463
                        Can you share it so I can study it and learn method?
                        • skazide
                          • Jul 2015
                          • 144
                          • morocco
                          #112
                          of corse
                          • Mazorca
                            • Jan 2017
                            • 463
                            Got it, its a method I have studied but have not applied before. Thank you, still learning here.
                            • vougheart
                              • Jul 2020
                              • 65
                              • philippines
                              #114
                              HELP MY G7 840 G7 Password SWAT problem
                              • Mazorca
                                • Jan 2017
                                • 463
                                If you are willing to try, unlock the 16MB file with RCUnlocker, and if it doesn't, continue with the BIG CHIP_unlocked. Please report back. Make sure you have good backups before any flashing is done.
                                This is how hoaca388 solved it:
                                "You used the bios of another machine, so in the 32MB bios file, there is MPM information of that device and it has enabled the "security endpoint". I rebuilt the new 32MB bios file, cleaned the ME region.
                                With the 16MB file, I deleted the first NvramActiveRegn region.
                                But now you may have trouble with MPM again."
                                No trouble with MPM was reported, but further work may be needed, perhaps also cleaning ME Region on the 32MB chip. I only cleaned the USER CRED Region.
                                • vougheart
                                  • Jul 2020
                                  • 65
                                  • philippines
                                  #116
                                  i tried this files sir but the response is 7blinks on capslock
                                  and i tried the backup again but it has the same response now 7 blinks on capslock
                                  can you help me with this problem sir😭
                                  • Mazorca
                                    • Jan 2017
                                    • 463
                                    Your backup should always work. Resolder if chip was taken out. If it is a WSON, I usually take it out, clean underside of chip, clean and tin again all pads, with very little solder, lots of flux and hot air station a little bit higher temp setting, faster time. I have had WSON chips that somehow are soldered on one corner but the opposite corner diagonally is lifted, probably due to too much solder in the middle pad. Using a digital microscope helps seeing that tiny detail.
                                    • vougheart
                                      • Jul 2020
                                      • 65
                                      • philippines
                                      #118
                                      thank you so much for the idea sir btw i will try it again to flash
                                      • vougheart
                                        • Jul 2020
                                        • 65
                                        • philippines
                                        #119
                                        i tried again this files but still lock btw thank you for reply
                                        Try:
                                        feedback for this file thank you sir the lock is gone but i cant default factory when i turn on it will stuck on restart no display and this message when turn on "hp endpoint security control problem" how to turn off this message everytime i turn on
                                        • Arrow16
                                          • Apr 2022
                                          • 229
                                          • Philippines
                                          #120
                                          please help me remove the bios password hp elitebook 840 g7 thank you
                                          https://www.mediafire.com/file/pppbq...+lock.rar/file
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • m1ch43lzm
                                            Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                                            by m1ch43lzm
                                            Hi everyone
                                            I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                                            Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                                            Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                                            There's also an extra OTP Secu.R...
                                            09-06-2025, 05:47 PM
                                          • Nopslide
                                            by Nopslide
                                            04-01-2024, 04:27 PM
                                          • chunhualo
                                            Please Help unlock bios password for Alienware 13 r1 bios password 7digit service tag
                                            by chunhualo
                                            HI I have forgotten my old laptop Alienware 13 r1 bios password .
                                            Can anyone find the master password for my laptop
                                            The service tag number is : 2JJVH12
                                            03-16-2025, 04:13 AM
                                          • Zain Ahmas
                                            unlock bios password ADVAN soulmate apn21s.
                                            by Zain Ahmas
                                            help me to unlock bios password ADVAN Soulmate board code: apn21s
                                            11-10-2025, 01:14 AM
