Dell G3 15 3500 bios help
hi try both file flashAttached Filesif you find these attachements useful please consider making a small donation to the site
Hello, friends!
Need some help with my dell g3.
Black screen, restarts and the fan is too fast with other bios I tested.
Bellow are the original bios.
Appreciated in advance!Attached Filesif you find these attachements useful please consider making a small donation to the site
DELL G3 15 3500 - SELEK 19753-1 Service Tag: 6HMQ0D3
It worked normally, after testing it turns on but no display, fans works at max speed.
I tested others bios without success.
Please help to fix my bios files.​Attached Filesif you find these attachements useful please consider making a small donation to the site
hi try flash both file 8mb 16mbAttached Filesif you find these attachements useful please consider making a small donation to the site
Thanks Shiyab, I tried both but they won't work, laptop won't turn on.
In fact this was the initial defect.
With others bios that I tested the laptop turns on and fans at max speed.
I opened both (8MB - original and sent) with ME Analyzer 1.304 and they show errors (attachments).
I still need help!!​Attached Filesif you find these attachements useful please consider making a small donation to the site
Hello, friends.
I need some help with my Dell G3 15. I´m having black screen, restarts and the fan is too fast with other bios I tested.
If possible, restore original bios or one that works properly.
Thanks in advance!
Service Tag: HNL2RD3Attached Filesif you find these attachements useful please consider making a small donation to the site
Dell G3 15 3500
Service Tag: 6HMQ0D3Attached Filesif you find these attachements useful please consider making a small donation to the site
​https://www.badcaps.net/donateComment
Dell G3 15 3500Hello, friends.
Thanks in advance!
Service Tag: HNL2RD3​Attached Filesif you find these attachements useful please consider making a small donation to the site
Thanks HOACA388 for your help.
But the notebook is still working with a black screen.
I've writeen both BIOS. When connecting the power supply or internal battery, the laptop starts, caps lock turns on, blinks twice, after a few seconds it turns off and then restarts the cycle indefinitely.
I waited 30 minutes when turning it on for the first time. The fans is working normally now but the keyboard is inoperative.
I would appreciate any help.​Comment
Sorry, I changed the post, this is the correct one.
Below is the same post:
I waited 30 minutes when turning it on for the first time. The fans is working normally now but the keyboard is inoperative. The power led lights up for a few moments.
Thanks a lot, hoaca388, for your help.
Just giving the feedback, it hapenned the same thing as the other bios I tested (black screen and fan too fast).
I am starting to think that it is not a bios problem.
I apreciate your help anyways!Comment
I have a problem with my Dell G3 laptop.
Service Tag: JS3GF63
The CPU fan was not working at all and the GPU fan was running at full speed.
After uploading both files from post nr 190 in this topic on a trial basis, the fans both run at full speed, you have to wait several seconds for the logo and the Service Tag cannot be saved.
I tried clearing ME, but FIT can't open the file.
If it is not possible to fix my bios, I would ask you to add the Service TAG to the one in post nr 190
Thank you!Attached Filesif you find these attachements useful please consider making a small donation to the site
Thank you!
Service Tag: JS3GF63​Attached Filesif you find these attachements useful please consider making a small donation to the site
hello every one
i have dell g3 15 3500
mainboard Selek g3 mlk n18p 19795-1 403yf$ja
reg type:p89f003
thats all details i have s/n and service tag are removed
it had short circuit on gpu mosfet
after replacing it came to life but stuck on logo
tried whith to flash another ec.bin it worked but fan are very loud and it shut down after afew minute
can any one fix my ec bios
i uploded both ec and main
best regardsAttached Filesif you find these attachements useful please consider making a small donation to the site
tryhello every one
reg type:p89f003
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by capoplaysHey everyone,
I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
When I check the BIOS using the F12 menu Flash...-
by evolpeHi guys, can anyone help me with this bios? It needs to be cleaned.
Motheboard: GDI5A LA-K033P REV 1.0 (A00)
Service TAG: BNV5GD3
I've attached the two BIOS (16MB and 8MB). The laptop turns on but only displays a backlight. I tried another BIOS and it works fine, but I can't exit manufacturing mode. Thanks to anyone who can help me....-
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
- Loading...
