Dell G3 15 3500 bios help
  • amigosssss
    • Dec 2018
    • 12
    • Czech
    #181
    Originally posted by danito
    Try and report
    Tried and no change, no working. 0,7A no post, only fans full speed
    • shiyab
      • Sep 2023
      • 1477
      • india
      #182
      hi try both file flash
      • Atendimento StartChip
        • Jan 2024
        • 9
        • Brasil
        #183
        Hello, friends!
        Need some help with my dell g3.
        Black screen, restarts and the fan is too fast with other bios I tested.
        Bellow are the original bios.
        Appreciated in advance!
          • 20918
          Originally posted by Atendimento StartChip
          Hello, friends!
          Please type and post the service tag.
            • Jan 2024
            • 9
            • Brasil
            #185
            Service Tag: HNL2RD3​
            • Robson Oliveira
              • May 2017
              • 4
              • Brazil
              #186
              DELL G3 15 3500 - SELEK 19753-1 Service Tag: 6HMQ0D3
              It worked normally, after testing it turns on but no display, fans works at max speed.
              I tested others bios without success.
              Please help to fix my bios files.​
              • shiyab
                • Sep 2023
                • 1477
                • india
                #187
                hi try flash both file 8mb 16mb
                • Robson Oliveira
                  • May 2017
                  • 4
                  • Brazil
                  #188
                  Thanks Shiyab, I tried both but they won't work, laptop won't turn on.
                  In fact this was the initial defect.
                  With others bios that I tested the laptop turns on and fans at max speed.
                  I opened both (8MB - original and sent) with ME Analyzer 1.304 and they show errors (attachments).
                  I still need help!!​
                    • Jan 2024
                    • 9
                    • Brasil
                    #189
                    Hello, friends.
                    I need some help with my Dell G3 15. I´m having black screen, restarts and the fan is too fast with other bios I tested.
                    If possible, restore original bios or one that works properly.
                    Thanks in advance!
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 11741
                      #190
                      Dell G3 15 3500
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11741
                        #191
                        Hello, friends.
                        Thanks in advance!
                        Dell G3 15 3500
                        • Robson Oliveira
                          • May 2017
                          • 4
                          • Brazil
                          #192
                          Originally posted by hoaca388
                          Dell G3 15 3500
                          Thanks HOACA388 for your help.
                          But the notebook is still working with a black screen.
                          I've writeen both BIOS. When connecting the power supply or internal battery, the laptop starts, caps lock turns on, blinks twice, after a few seconds it turns off and then restarts the cycle indefinitely.
                          I waited 30 minutes when turning it on for the first time. The fans is working normally now but the keyboard is inoperative.
                          I would appreciate any help.​
                          • Robson Oliveira
                            • May 2017
                            • 4
                            • Brazil
                            #193
                            Dell G3 15 3500
                            Sorry, I changed the post, this is the correct one.
                            Below is the same post:
                            I waited 30 minutes when turning it on for the first time. The fans is working normally now but the keyboard is inoperative. The power led lights up for a few moments.
                              • Jan 2024
                              • 9
                              • Brasil
                              #194
                              Dell G3 15 3500
                              Thanks a lot, hoaca388, for your help.
                              Just giving the feedback, it hapenned the same thing as the other bios I tested (black screen and fan too fast).
                              I am starting to think that it is not a bios problem.
                              I apreciate your help anyways!
                              • PCMajster
                                • Nov 2022
                                • Poland
                                #195
                                I have a problem with my Dell G3 laptop.
                                Service Tag: JS3GF63
                                The CPU fan was not working at all and the GPU fan was running at full speed.
                                After uploading both files from post nr 190 in this topic on a trial basis, the fans both run at full speed, you have to wait several seconds for the logo and the Service Tag cannot be saved.
                                I tried clearing ME, but FIT can't open the file.
                                If it is not possible to fix my bios, I would ask you to add the Service TAG to the one in post nr 190
                                Thank you!
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 11741
                                  #196
                                  Thank you!
                                  Dell G3 15 3500
                                  Service Tag: JS3GF63​
                                  • amr soliman
                                    • Oct 2015
                                    • 120
                                    • egypt
                                    #197
                                    hello every one
                                    i have dell g3 15 3500
                                    mainboard Selek g3 mlk n18p 19795-1 403yf$ja
                                    reg type:p89f003
                                    thats all details i have s/n and service tag are removed
                                    it had short circuit on gpu mosfet
                                    after replacing it came to life but stuck on logo
                                    tried whith to flash another ec.bin it worked but fan are very loud and it shut down after afew minute
                                    can any one fix my ec bios
                                    i uploded both ec and main
                                    best regards
                                    • amr soliman
                                      • Oct 2015
                                      • 120
                                      • egypt
                                      #198
                                      Any help please
                                      • volinakis
                                        • Jan 2021
                                        • 2733
                                        • N/A
                                        #199
                                        Originally posted by amr soliman
                                        hello every one
                                        reg type:p89f003
                                        best regards
                                        try
                                        • amr soliman
                                          • Oct 2015
                                          • 120
                                          • egypt
                                          #200
                                          Originally posted by volinakis
                                          try
                                          Thank you for your response I will try tomorrow and give the results
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • mikeybass
                                            by mikeybass
                                            04-23-2025, 04:30 PM
                                          • jhanra
                                            by jhanra
                                            in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                            11-02-2024, 04:19 AM
                                          • gizaha
                                            by gizaha
                                            02-13-2024, 07:18 AM
                                          • mrrubik
                                            Dell Optiplex 7010 micro bad BIOS flash?
                                            by mrrubik
                                            Hi folks,
                                            I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
                                            After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
                                            Steps I took:
                                            1. Read BIOS with CH341a, verified hash twice
                                            2. Patched
                                            12-23-2024, 04:11 PM
