Dell G3 15 3500 bios help
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Re: Dell G3 15 3500 bios help
Hi everyone, Dell G3 15 3500 stucked in manufacturing mode
service tag: G9k1863
Thanks in advanceAttached Filesif you find these attachements useful please consider making a small donation to the site
Dell G3 15 3500
motherboard: selek g3 mlk n18p 19795-1
black screenAttached Filesif you find these attachements useful please consider making a small donation to the site
hi
can anyone fix this bios
i cant clean me, i get the error in the picture when i open it with fit.
i tried with another cleaned copy, it stuck in manufacturing mode and he cant save the service tag and the fans always in full speed.
SERVICE TAG: 54Y81B3Attached Filesif you find these attachements useful please consider making a small donation to the site
try and reportAttached Filesif you find these attachements useful please consider making a small donation to the site
Hi Masters, anyone can help me to clean ME for this file?
Dell G3 3590
P89F001
Service tag: 9GCZPT2
Laptop doing crazy things, FANs start working at 90 degrees, than run at full speed, mouse is not working...would like to start with ME region cleaning.If I try to clean, always getting 308 error...
Many thanksAttached Filesif you find these attachements useful please consider making a small donation to the site
tryHi Masters, anyone can help me to clean ME for this file?
Dell G3 3590
P89F001
Re: Dell G3 15 bios help
Hello everyone, the dell G3 15 new laptop , the Selek g3 mlk n18p 19795-1 motherboard, Manufactoring mode, the service tag is not saved in the bios settings, the native bios was , but with this the laptop starts but high speed fan and keyboard sound... in the archive original dumps
Service Tag 57KV003Attached Filesif you find these attachements useful please consider making a small donation to the site
Dell G3 15 3500
try to reprog the two chips with the file 1
the laptop will be stuck on manufacturing mode and can't save the service tag
then reprog only the 8mb chip with the file 2, you will can save your service tag and it quit the manufacturing mode.
inform us with the result. thnksAttached Filesif you find these attachements useful please consider making a small donation to the site
think you very machtry to reprog the two chips with the file 1
inform us with the result. thnksComment
i have a Dell G3 with PCB SELEK G3 MLK N18P 19795-1 that doesn't have image.Can someone help me?Attached Filesif you find these attachements useful please consider making a small donation to the site
try this post and inform me:
https://www.badcaps.net/forum/showpo...9&postcount=79Comment
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by capoplaysHey everyone,
I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
When I check the BIOS using the F12 menu Flash...-
by evolpeHi guys, can anyone help me with this bios? It needs to be cleaned.
Motheboard: GDI5A LA-K033P REV 1.0 (A00)
Service TAG: BNV5GD3
I've attached the two BIOS (16MB and 8MB). The laptop turns on but only displays a backlight. I tried another BIOS and it works fine, but I can't exit manufacturing mode. Thanks to anyone who can help me....-
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
- Loading...
