Dell G3 15 3500 bios help
I also have a problem with a customer's Dell G3 15 3500.
An incomprehensible problem with the battery, I made a post on the Dell forum, but no answers, and a YouTube video of the problem, which is more telling:
https://www.dell.com/community/fr/co...04d60b154acb7e
I have already tested 4 different BIOSes from Electronic Repair School: new BIOS, clean ME, NVRAM, but none of them work (error code 5 white LEDs and 3 orange).
Model: G3 15 3500 - P89F002
SN: HGFBD63
Service Code: 37998483051
Board number: SELEK MLK N18E 19753-1 FJTCA$96
Sincerely.Comment
post the contents of the bios chip even if it is corrupted..Hello,
SN: HGFBD63
Sincerely.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
Here is the BIOS and ME content.
Thanks.Attached Filesif you find these attachements useful please consider making a small donation to the site
hi tryAttached Filesif you find these attachements useful please consider making a small donation to the site
Dell G3 15 3500
Service Tag: HGFBD63Attached Filesif you find these attachements useful please consider making a small donation to the site
https://www.badcaps.net/donateComment
After reading all the postas, i flashing the BIOS, whit #131 the screen displayed an image and asked for the service tag or to press Alt+F. I couldn't do it, and it restarted. After that, the screen had no brightness. Using a flashlight, I was able to enter the BIOS setup and enter the service tag. Now the laptop works 'fine,' but the screen has no brightness.
I suspect it might be a hardware failure, but I would like to consult about it. Thanks!!"
Hi, I need you to clean this BIOS, please. I tried all the ones available here, and they all have the same issues, but I have no screen brightness... Please clean it.
Model: Dell G3 15 3500 selek g3 mlk n18p 19795-1 403yf$ja
Service TAG: 741F503
Dell G3 15 3500
Service Tag: 741F503Attached Filesif you find these attachements useful please consider making a small donation to the site
Thank you very much! Now the machine turns on, but like many others here, I have the problem that the screen has no brightness, and the coolers don't turn on until 95º. Do you think it could still be a BIOS issue, or should I abandon the software side altogether? Thanks a lot for taking the time to do this!
Chek hardware.
PCB SLEEK G3 MLK N18P 19795-1 403YF$LA Motherboard received in no display condition. Customer original fault is Keyboard and touchpad not working after removed battery. Already someone tried to programmed BIOS then no display. Unfortunately the product service tag is also missing. I tried no of bios and no display - Fan spinning in full speed then board power OFF, Anyone can help meComment
i need ad service tag dell g3 mlk n18p 19795-1
service tag : JKN5R93Attached Filesif you find these attachements useful please consider making a small donation to the site
hi i need bin working for dell g5 service tag B11F463 MODEL MOTHERBOARD SELEK G3 MLK N18P 19795-1Attached Filesif you find these attachements useful please consider making a small donation to the site
TRy and feedbackAttached Filesif you find these attachements useful please consider making a small donation to the site
Dell G3 15 3500
TAg 9VK2YZ2
Mainboard 19795-1
The machine has been repaired at another shop, and the original BIOS is lost. I have downloaded many BIOS versions, but I am facing the issue of not saving the tag and boot slow 30s. Please help me.
Attached is the BIOS that does not save the tag. Please help meAttached Filesif you find these attachements useful please consider making a small donation to the site
1st boot, press F2,Dell G3 15 3500
TAg 9VK2YZ2
Mainboard 19795-1
write service tag manually in bios setup save & restart.
2nd boot press Alt+F to exit manufacturing modeAttached Filesif you find these attachements useful please consider making a small donation to the site
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by capoplaysHey everyone,
I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
When I check the BIOS using the F12 menu Flash...-
by evolpeHi guys, can anyone help me with this bios? It needs to be cleaned.
Motheboard: GDI5A LA-K033P REV 1.0 (A00)
Service TAG: BNV5GD3
I've attached the two BIOS (16MB and 8MB). The laptop turns on but only displays a backlight. I tried another BIOS and it works fine, but I can't exit manufacturing mode. Thanks to anyone who can help me....-
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
- Loading...
