LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
    Hi Everybody! Until now I have been able to unlock a couple of Thinkpads thanks to this system which I think is quite easy and straight-forward.
    Anyway now I came across a P50, and it seems that autopatcher is NOT working: if I patch the BIOS, laptop boots up for 5/6 seconds but then it shuts OFF. NO video screen, NO beep codes.
    What I did: dumped the file using a clamp (dumped twice, checked using certutil and generated same hash file so I moved on); patched with autopatched, loaded new BIOS. tried 3 times, same results...
    Can it be because of the MACRONIX chip? That is the 1st one I am finding (previous ones were Winbond). Attacched original DUMP.
    Type: 20EQS28U03
    S/N: PC0K6ER2 17/03
    Bios MACRONIX MX25L12873F
    Bord # BP500 NM-A451 Rev 1.0 2015-11-06
      S.N:- PC0K6ER2
      STEP 1: Flash given patch file
      STEP 2: Boot the machine
      STEP 3: Enter in BIOS settings
      STEP 4: Enter any character when asked for Supervisor Password
      STEP 5: Press enter when it shows Hardware ID
      STEP 6: Press space bar 2x when asked
      STEP 7: Turn off machine
      STEP 8: Restore original BIOS (write your old backup bios)
      STEP 9: Reset BIOS settings to factory default
        Originally posted by qayyum786 View Post
        S.N:- PC0K6ER2
        NOPE... Unfortunately same behaviour as before: laptop does boot automatically once connected to AC, stays on for 4/5 seconds (fans 1/2 seconds), then turns OFF automatically. DOES NOT reboot. If I try to power-it on manually (power button) it starts, again for 5/6 seconds, then OFF. NO video, NO beeps. On the laptop I have video, ram (1 slot), keyboard, nothing else (NO CMOS, no battery, no ssd).
        If I switch back to original BIOS (not patched) everything works normally (but with password). :-(
          Originally posted by Crypts View Post
          I tried this dump but no screen!!
          Hello Friend..
          I tried to flash your file, but when it asks for the supervisor password and I enter any symbol, it just counts it as a wrong password, then i have this message !!
            Patch worked fot Lenovo A475 (NM-B351)
              Hello everyone.
              i have thinkpad T470 i5 7300u with a bios password.
              when you start the computer it asks for a bios password.
              i would like to know if it's possible to get the bios password or would it be possible to one of the members on here to clear it . I have tried lenovo auotpatcher with no luck.
              i have listed the original bios as an attachment
              Motherboard number
              NM-A931 V2.0
              Thinkpad T470 20HE-S0FW00
              serial number PF-11C9UV 18/05
              Ok
                Originally posted by kordex35 View Post
                Ok
                Thank you.
                I tried patching it few times but it didn't work .
                I would like to know how you patched the bios (what tools or technics )
                  hello,
                  please help to patch, tried to use all existing patched bios here but always blank screen.
                  Lenovo Thinkpad T495s Type 20QK Board FA391/FA491 NM-C181
                  Rev. 1.0 2019-03-21
                  Type:20QK-SOLGOO
                  SN:PC1CRA2Y
                  Bump, still need help
                  Last edited by Vesko356; 02-09-2024, 01:08 PM. Reason: Bios removed, already attached in quoted post
                    This is the second laptop I have and the password cannot be removed either (T470 and T480s) - it is restored by an unpatched BIOS. I assume that with some version the autopatcher does not work as expected
                      Patch is working for Lenovo E540 AILE2 NM-A161. Flash only 4mb and boot. Trick is start clicking Enter just before you see Lenovo logo otherwise laptop will freeze and then normally proceed with patching.
                        i have password please help me to patch lenovo l460
                        Bl460 nm-a651 rev 1 this is my bin backup thanks alot
                        Hello everyone.
                        Can you help me unlock my bios please?
                        I have windows 11 and couldn't run autopatcher. turn off antivirus but still can't use it
                        Lenovo t450
                        sn: PC-09KHL7 15/12
                          File damaged
                          lenovo t450 password
                            Do I have to read bios again ?
                              Please check if its ok now ?
                                damaged
                                  Sorry about that. Can you check 1 more time please . Now should be ok. Thank you 🙏
                                    Try this file ....
                                      I did the whole process but the password is still on the bios
                                      STEP 1: Flash and replace current BIOS with the generated patch file
                                      STEP 3: Press ENTER/F1/etc. to enter BIOS settings
                                      Can someone advice please ?
                                      step8. Do I need to erase chip and flash with original bios , right ?
                                      • Vesko356
                                        Vesko356 commented
                                        Editing a comment
                                        Yes, of course
