  • jbonavita
    • Jan 2017
    • 10
    • argentina
    Some issues
    Things I tried
    1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...-guide?t=88533
    to no good results (same behaviour from the original BIOS)
    Things I noticed
    Backup bios size : 8 MB
    TP500LN donwloaded BIOS from this forum : 8MB
    Bios for model TP500LA downloaded from ASUS support : 6 MB
    So, Im in need of:
    - A normal backup of a working bios for TP500LA (8 MB) for direct flashing
    - A merge from the ASUS webpage 6 MB BIOS and the part of the TP500LN BIOS that made it work
    - Repair or something my original BIOS
    As of now, Im thinking to cut a part (2 MB) from the 500LN bios and merging to the 6 MB 500LA to make a 8 MB one, but I dont know how
    Thanks in advance
  • LEO037_2029_
    BIOS_LEGEND
    • Nov 2023
    • 85
    • Argentina
    try and feedback bro ( prueba y comentame amigo).
    • shiyab
      • Sep 2023
      • 3634
      • india
      Thanks in advance
      post snid
      • jbonavita
        • Jan 2017
        • 10
        • argentina
        Thanks, I will flash it right now, later post a feedback
        Originally posted by shiyab
        post snid
        Are you refering to serial number ID? I´ts TP500LA-DH71T
        • shiyab
          • Sep 2023
          • 3634
          • india
          yes
            • 24919
            He was referring to the serial number, but it`s not TP500LA-DH71T , the serial is about 15 digits long
            https://eu-rma.asus.com/img/info/nb_serial2.jpg
            https://eu-rma.asus.com/uk/info/sn
            • jbonavita
              • Jan 2017
              • 10
              • argentina
              Oh, I get it.
              SNID EAN0WU51172144C
              • jbonavita
                • Jan 2017
                • 10
                • argentina
                Flashed it and the notebook boots fine, but the easy flash option in BIOS is showing " please plug in battery and its remaining capacity should be more than 20%. System doesnt permit flashing BIOS. Please press any key after pluging the battery"
                Pressing a key does nothing, the battery is internally connected already
                • jbonavita
                  • Jan 2017
                  • 10
                  • argentina
                  Tested merge.bin. and worked flawlessly, the notebook boots as normally do, no delays etc. But now is has no serial number installed. I have battery problems and MyAsus app doesn´t recognize this machine (to try some calibration, etc). It is possible to re-add the SNID posted above? thanks
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12713
                    Here
                    If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our bios, boardview & schematic archive.
                    Subscribe to support us. It only takes 1 minute:
                    https://www.badcaps.net/settings/subscriptions
                    • razor_amd
                      by razor_amd
                      12-15-2020, 07:07 PM
                    • ronaldopdias
                      ASUS ROG Strix B660-I Gaming WiFi – BIOS dump vs ASUS CAP size mismatch, need corruption check, please.
                      by ronaldopdias
                      I’m troubleshooting an ASUS ROG Strix B660-I Gaming WiFi motherboard and I’m a bit stuck at the BIOS level. What I’ve tried so far
                      • Attempted to flash the BIOS using the USB BIOS FlashBack (Q-Flash) port with a properly formatted FAT32 USB drive.
                      • BIOS file downloaded directly from the official ASUS support page.
                      • Followed the exact FlashBack procedure (correct port, renamed file, standby power only).
                      Issue:
                      The FlashBack LED does not blink at all — no activity whatsoever. Further investigation
                      Because FlashBack didn’t work, I:
                      • Removed the BIOS SPI IC from
                      02-04-2026, 03:16 AM
                    • vic6688
                      ASUS ExpertCenter D700SA - Need BIOS admin password removed
                      by vic6688
                      I would like to ask for your help with my ASUS desktop.
                      Model:
                      BIOS:
                      AMI Aptio V
                      BIOS Flash:
                      Winbond W25Q128JV (16MB)
                      I forgot the BIOS Administrator password.
                      I have already read and verified the complete BIOS dump using a CH341A programmer, and I have attached the original 16MB BIOS dump.
                      If possible, I would prefer to recover or identify the current BIOS password so that I can continue using the original BIOS without reflashing.
                      If...
                      09-05-2026, 06:23 PM
                    • NielsTH
                      Asus K75V (K75VJ) Bios flash undo help needed
                      by NielsTH
                      Hi forum members.
                      I hope you can help me with the next issue.
                      I've got an old Asus K75V (K75VJ) laptop, that I updated to Windows11.
                      The upgrade itself was succesfull, but had trouble installing new security updates.
                      After a lot of Windows troubleshooting and no success, I took a look at the Asus support site and found new Bios version.
                      K75VJ - Support
                      When downloading the bios update, the name of the download was "K45VMAS233", and made me causious and doubtful.
                      When I opened the Bios and loaded the file, I checked the current version and the...
                      01-12-2026, 10:08 AM
                    • Martisolutions
                      BIOS/ME Region Help - ASUS F556UJ (Motherboard X556UJ_MB REV 2.0) - Hangs at 0.33A - RAM Communication Error
                      by Martisolutions
                      I am requesting help with a BIOS/ME Region issue on an ASUS laptop. I have followed the "BIOS guides, methods, resources and tools" provided in the forum, specifically trying to clean the ME Region and updating the BIOS region to version 413, but I haven't been able to succeed, i've tried to download a the same ME Region v11.0.0.1180_COR_LP_C_NPDM_PRD_RGN.bin but not able to fit it since it is bigger than the actual size from the ME region of my chip.
                      System Details:
                      • Make: ASUS
                      • Full Model: F556UJ-XO015T (Mainboard X556UJ_MB REV 2.0)
                      • Serial
                      04-28-2026, 10:13 AM
