mec 16xx dump with info block
  • rbnote
    • Nov 2013
    • 83
    • brazil
    #241
    Re: mec 16xx dump with info block
    Hi guys
    I need file dump ec mec for yoga 5th 20uc pls?
    • volinakis
      • Jan 2021
      • 2744
      • N/A
      #242
      Originally posted by myjunaid
      Thank you very much for your time and for the pictures
      i have done the exactly the same before with connected RST to no 7 and without connected to pin7 to RST it gives error ID verification error
      it has usb C charger which i connected but i noticed i am not getting 3.3v on pin 7 but when i connect the wires and plug the usb c the laptop fan starts spinning and off for some time then on again but i have not connected the power button or i need to connect the power button and switch on by pressing it
      also posts #46 saying the some mainboard RST pin 7 is empty solder pad then add 10 k resister there and my mainboard pin 7 is not connected to resister as well
      also can it be a issue of RT809H Drivers ?
      choose MEC1653#ISP from menu, duble click on it. Told you before, READ ALL posts from this topic, users are willing to share infos but you also have to work a little bit. Look at the pins of your picture, I marked them with what wires you have to connect. TMS to pin 1 of programmer, TDO to pin 2, GND to pin 4 TDI to pin 5 TCK to pin 6. If it doesn't work you have to add 10k pull up resistors between pins and 3.3V or you have a problem with motherboard, I see there is a problem around pin 6 where is 3.3V. Check if you have resistors R8257 to R8530.
      • volinakis
        • Jan 2021
        • 2744
        • N/A
        #243
        Originally posted by RethoricalCheese
        Scan the barcode. You need codes starting with 1S (bottom case sticker) and 8S (motherboard sticker)
        Thanks, I solved almost all errors, only 2202:Product Name is Invalid. I did look in all menus of LMU and still didn't figure out what to do. Please help!
        • volinakis
          • Jan 2021
          • 2744
          • N/A
          #244
          Solved, finally! Had to edit plnsrv.ini, model wasn't in list.
          • volinakis
            • Jan 2021
            • 2744
            • N/A
            #245
            Originally posted by rbnote
            Hi guys
            Try this. Thanks to AAAC.
            https://www.badcaps.net/forum/showpo...8&postcount=23
            • DeKu
              • Jan 2020
              Hi People,
              I have an X13 YOGA Type 20SY.
              I read the Flash from the "MX25L25673GM2I-08G" IC, resulting in a 32MB big file. Unfortunately, the Lenovo Auto Patcher does not seem to work in my Case.
              So I wanted to ask if the Vertyanov Device is the way to go for me!
              Any help would be greatly appreciated.
              Regards
              • novator2007
                • Oct 2016
                • 15
                • mumbai
                #247
                Hello All,
                Iam trying to repair T460 NM-A581,probably,with bad EC FW.
                I bought/have a RT809H.
                1. How max. long can be debug cable(prog.device-MB)
                2. Maybe someone know where is JTAG_Enable resistor?
                Debug/JAG connector is J9(I hope),also there is some Test Points near CPU(TDO,TMS and so on)
                • dkbose5
                  • Feb 2018
                  does anyone have any information on the T14s, how to read mec1663? it looks like is in e different place-not the same as t490
                  • RethoricalCheese
                    • Mar 2013
                    • 1519
                    • Estonia
                    #249
                    novator2007, dkbose5, give us some clear pictures.
                    • mferna14
                      • Jun 2018
                      • 1028
                      Originally posted by JOHNLAG7
                      In my case with svod3 done read the t490 1663mec file and save it is 256kb ok then erase it and write an unlocked file after that i boot to bios and supervisor password gone all ok then i repeat the process and write back the original file that i save the first time and i can confirm t490 unlocked.
                      No PULL-UP resistors to JTAG signals needed or 3.3v power suply as pin 6 has 3.3v only connect direct to svod3 all 6 jtag pins.
                      PULL-UP Resitor must move to PULL-DOWN like attached photo and put back after every step.
                      Thank you for all the information, it is GREAT!!! I am able to read MEC1663 & get the 256KB file which I attached. Kindly inform me now from where will I get an unlocked file (Without password as mine has a password), or someone can kindly auto patch this file for me, I would appreciate. Mine is a Lenovo Thinkpad T490 (Motherboard NM-B901 Rev:1.0). Thanks in advance.
                      • AAAC
                        • Jan 2020
                        • 458
                        • Mexico
                        #251
                        @mferna14
                        If you were able to read MEC1633L chip, the next step is to ERASE it and then to PROGRAMM it with the file that you saved. The master password is not stored in this file that you saved, but in an EEPROM area on MEC chip as far as I know, so when you erase MEC chip the EEPROM contents get erased too! Then you will have to use Lenovo Maintenance Utility to type the missing information (model, serial number, etc.).
                        As far as I know some JTAG EC/KBC programmers can access the EEPROM directly and clean it removing the Supervisor Password, without having to save any file and later needing to use utility to type the laptop missing information.
                        • mferna14
                          • Jun 2018
                          • 1028
                          Thanks so much "AAAC"., I will do what you informed me, I will use Lenovo Maintenance Utility instead. Just one more thing, have I got the correct size of the file??? 'cause I was reading the thread that the file can also be 290KB., Just wondering whether my file size 256K is the right one? I would appreciate if I can rectify this confusion. Thanks
                          • mferna14
                            • Jun 2018
                            • 1028
                            Please ignore Post #252... I programmed the copied BIN files to the EEPRom & all is working fine without the PASSWORD. I can now edit the date & time. But no information about the Serial #, etc. To update this info I need Lenovo Maintenance Utility. Where about is this tools to put in all the data for Thinkpad T490?? If anyone can give me this info. Thanks
                            • AAAC
                              • Jan 2020
                              • 458
                              • Mexico
                              #254
                              @mferna14
                              The missing information is printed on stickers fixed to the motherboard, make sure you have all the information so you do this procedure at once, instead of leaving empty fields and having to come back to complete them.
                              Lenovo Maintenance Utility:
                              https://www.badcaps.net/forum/showpo...4&postcount=28
                              • mferna14
                                • Jun 2018
                                • 1028
                                Originally posted by AAAC
                                @mferna14
                                Thanks, will try now... Is this the Sticker you are refering to on the main motherboard????
                                • AAAC
                                  • Jan 2020
                                  • 458
                                  • Mexico
                                  #256
                                  @mferna14
                                  Yes, there may be another sticker in the memory slots area too.
                                  • mferna14
                                    • Jun 2018
                                    • 1028
                                    @mferna14
                                    Thanks for all the information "AAAC". Now all is set & no errors at all. Only in the BIOS I see "ASSET Tag Invalid". No errors though, but how will add the info of ASSET Tag?
                                    • AAAC
                                      • Jan 2020
                                      • 458
                                      • Mexico
                                      #258
                                      @mferna14
                                      You may need to use another utility, as I don’t remember seeing that field while using the Lenovo Maintenance Utility.
                                      • mferna14
                                        • Jun 2018
                                        • 1028
                                        @mferna14
                                        Yes I saw the "Write Asset Tag" in another Lenovo Maintenance Utility, I will make the changes booting from that software. Thanks for all the help.
                                        • dinarte
                                          • Sep 2021
                                          • 13
                                          • Brazil
                                          #260
                                          the solution presented in this topic only works for intel models, right?
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • Mephysis
                                            DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
                                            by Mephysis
                                            Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
                                            I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
                                            03-27-2025, 02:34 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • hyperwood
                                            [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                                            by hyperwood
                                            I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                                            The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                                            I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                                            āœ… What I need:
                                            • A working 2MB BIOS dump
                                            • Matching NM-E471 Rev. 2.0, e.g. JY575
                                            06-25-2025, 02:28 PM
                                          • Andreas_de
                                            Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                                            by Andreas_de
                                            Hello!
                                            i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                                            Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                                            Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                                            04-12-2025, 10:38 AM
