mec 16xx dump with info block
  • keczuk
    • 83
    • WWW
    #121
    Re: mec 16xx dump with info block
    what flex should buy for thinkpad T14 AMD to Keyboard programming. . i have many from SVOD but all are different to big or to small.
    • imranromi
      • Jan 2015
      • 1288
      • Pakistan
      #122
      Which Kbc you use this board?T series use Mec chip i think
      • keczuk
        • 83
        • WWW
        #123
        Yes there is MEC T14 Gen 2... but there is only 16 strange pin j1901 (18 pin) not like T490 like 6 ping and there is info jtag.
        https://www.badcaps.net/forum/attach...1&d=1638991799
        So i think i need keyboard flex like in your case, and try to programm via flex... but someone can share link to shop where i can buy this ?
        • LenBios
          • 122
          • Ker
          #124
          you can not use keyboard connector for mec
          • keczuk
            • 83
            • WWW
            #125
            I was chceck flex from broken keyboard T490... there is 35 pin + 5 pin empty on keyboard conn side 0.5 mm so how you connect this to programmer SVOD or Vertyanov. There is only 32 PIN slot ??
            • RethoricalCheese
              • Mar 2013
              • 1519
              • Estonia
              #126
              You do understand that you need to connect to that 8 pin jtag connector on vertyanov?
              I shouldn't have mentioned that using keyboard connector is possible on some models. It just makes things too complicated but people seem to think it makes it very easy
              • santoslao
                ā €
                • Apr 2017
                • 121
                • BZ
                #127
                I have a lenovo thinkpad T14 i5 10th with supervisor password, I also have an rt809h, can you help me with that how could I proceed? This image is a real one of the lenovo T14 board
                • RethoricalCheese
                  • Mar 2013
                  • 1519
                  • Estonia
                  #128
                  Empty pads under Q8601. Move the resistor which is below those empty pads onto the empty pads.
                  Jtag pinout is written somewhere in this topic.
                  Does anybody know which bytes can disable computrace?
                  • santoslao
                    ā €
                    • Apr 2017
                    • 121
                    • BZ
                    #129
                    Can someone help me about this, I followed all the steps informed here on the forum and managed to read the MEC1663 but I had these messages from rt809h, but I'm afraid to erase the chip and then not be able to turn the machine on again using the same file, can someone help me with this please?
                    Thinkpad T14 1st i5 10ĀŖger
                    • santoslao
                      ā €
                      • Apr 2017
                      • 121
                      • BZ
                      #130
                      In my case now Write / read good. BUT He cut in upload my file in 192KB. I have choose 256 or 290 KB but always upload 192KB .... in svode and rt809h ..
                      Hi friend, can you tell me how you solved your reading and writing problem, I have the same problem, but for a T14 1st, see the screenshots and thank you if you can help me solve this. I'm trying to read the MEC1663 regardless of which one I choose, it only gives this error on the rt809h, I did it as shown in the t490 manual, this one with direct connection, I don't have a resistor.
                      PS: something I received was that when I put the power supply pin 6 has 3.3v and the other pins also have 3.3v except pin 5 GND.
                      • santoslao
                        ā €
                        • Apr 2017
                        • 121
                        • BZ
                        #131
                        now i have this problem, do you know what it can be?
                        https://www.badcaps.net/forum/showpo...&postcount=130
                        • AAAC
                          • Jan 2020
                          • 458
                          • Mexico
                          #132
                          @santoslao
                          - Your EC/KBC file is empty (post #129).
                          - You need to find the resistor and make the change to be able to read the MECxxxx chip (post #127).
                          - The messages you get from programmer is because the JTAG interface is not communicating through the interface (post #130).
                          • 69d0b913
                            • Mar 2018
                            • 146
                            • BR
                            #133
                            Originally posted by AAAC
                            @santoslao
                            Which resistor are you referring to because I made the location change of the 10k resistor and put it where it was not according to the T490 diagram, see that in the photo on my board it shows this change and even so I still have the error, can you be clearer about your answer please?
                            • RethoricalCheese
                              • Mar 2013
                              • 1519
                              • Estonia
                              #134
                              I guess you did not attach a charger to motherboard.
                              AFAIK that 3v3 pin is disconnected so you need to use a charger unless you make a bridge.
                              • 69d0b913
                                • Mar 2018
                                • 146
                                • BR
                                #135
                                yes, I connect the charger, without it it does not even read, without the charger pin 6 does not have 3.3v after inserting and releasing energy for it.
                                • AAAC
                                  • Jan 2020
                                  • 458
                                  • Mexico
                                  #136
                                  Other point to consider if you look at a ThinkPad schematic, is that each of the JTAG interface signals have a PULL-UP resistor (which are not populated in motherboard), some EC/KBC programmers may have these resistors built-in but others may not, so you may need to add them.
                                  • 69d0b913
                                    • Mar 2018
                                    • 146
                                    • BR
                                    #137
                                    Re: despejo mec 16xx com bloco de informaƧƵes
                                    Outro ponto a considerar se você olhar para um esquema ThinkPad é que cada um dos sinais da interface JTAG tem um resistor PULL-UP (que não é preenchido na placa-mãe), alguns programadores EC/KBC podem ter esses resistores embutidos, mas outros não, então você pode precisar adicionÔ-los.
                                    I don't know if I informed but I'm using an rt809h the T490 scheme seems to serve for the T14, but I don't understand why it's giving this problem in reading, I did what you ask in the diagram and checked the jtag pads, changed the 10k resistor of location and soldered the jtag.
                                    • 69d0b913
                                      • Mar 2018
                                      • 146
                                      • BR
                                      #138
                                      Can someone post a photo of the connection in practice on a T490 board for reading the IO MEC1663? I'm not able to do the reading at all, I even managed to see some photos but I can't see where another snake wire is connected as shown in this posted image. Photo was taken from a quick video on YT
                                      https://youtu.be/XBcINkWU7xM?t=624
                                      • 69d0b913
                                        • Mar 2018
                                        • 146
                                        • BR
                                        #139
                                        Can anyone do or have read MEC1663 on rt809 can you help me please? I've been using a machine for 8 months, and for 1 week I've been struggling just to read the MEC1663. I've already done everything that it says here on the forum, but it's not working, I did what it shows in the attached image, see the video where I demonstrate the error, all the jtag1 pins connected and checked, 10k resistor soldered on the empty pad and still not recognizes and does not read the MEC correctly. Watch the video to understand and if you can help me I will be grateful. If anything else is missing, please let me know see video make https://youtu.be/pFoHu0troV0.
                                        • LenBios
                                          • 122
                                          • Ker
                                          #140
                                          if all the wiring is ok select MEC1653 plug the power cord and you will be able to read and write
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • Mephysis
                                            DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
                                            by Mephysis
                                            Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
                                            I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
                                            03-27-2025, 02:34 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • hyperwood
                                            [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                                            by hyperwood
                                            I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                                            The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                                            I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                                            āœ… What I need:
                                            • A working 2MB BIOS dump
                                            • Matching NM-E471 Rev. 2.0, e.g. JY575
                                            06-25-2025, 02:28 PM
                                          • Andreas_de
                                            Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                                            by Andreas_de
                                            Hello!
                                            i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                                            Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                                            Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                                            04-12-2025, 10:38 AM
