mec 16xx dump with info block
  • RethoricalCheese
    • Mar 2013
    • 1519
    • Estonia
    #161
    Re: mec 16xx dump with info block
    https://www.badcaps.net/forum/showpo...4&postcount=28
    Use this to write back machine info. Info is on stickers at bottom. They start with 1S and 8S.
    But still, what did you do with RT809H to get it working?
    • cgtec
      • Feb 2014
      • 56
      • France
      #162
      Originally posted by 69d0b913
      After a lot of persistence I managed to remove the T14 bios password! I believe that few here know how to do it and no one shares it, I understand that certain types of information are not shared and are sold! But I persisted, and I come to inform you that the (Thinkpad T14 1st 20S1) was unlocked by an RT809H the only programmer I have, as I don't have access to a vertyanov. Here are the photos in the attachment, now I just need to invert the bios information, but I had taken a photo before.
      you shold be 290K zise of MEC1663 and you see the HXD the information in the last 2k
      • 69d0b913
        • Mar 2018
        • 146
        • BR
        #163
        Now I have another problem, I already corrected all the information in the T14 bios, but now I have an error at startup (2202: Product Name is Invalid) I tried with lenovo maintenance utility v1.08, 1.11, 1.89 and it is not working, does anyone know how to fix?
        • 69d0b913
          • Mar 2018
          • 146
          • BR
          #164
          Finally, I managed to solve this damn T14 again. Now it works perfectly without a password and without computrace.
          • andrew25
            • Feb 2016
            • 223
            • Malawi
            #165
            Originally posted by Ghamidi
            try..
            can you share me ec dump for t490s... its urgent please
            • 69d0b913
              • Mar 2018
              • 146
              • BR
              #166
              send SN
              • andrew25
                • Feb 2016
                • 223
                • Malawi
                #167
                send sn
                s/n pc- 1b4v1y
                • 69d0b913
                  • Mar 2018
                  • 146
                  • BR
                  #168
                  s/n pc- 1b4v1y
                  this is not a valid serial
                  • andrew25
                    • Feb 2016
                    • 223
                    • Malawi
                    #169
                    pc1b4v1y
                    • 69d0b913
                      • Mar 2018
                      • 146
                      • BR
                      #170
                      pc1b4v1y
                      try..
                      After flashing the file you will need to fix the bios information with LMU..
                      • andrew25
                        • Feb 2016
                        • 223
                        • Malawi
                        #171
                        try..
                        lt me try, will give feedback
                        • Maxpower3
                          Bad Veteran
                          • Feb 2018
                          • 1226
                          • France
                          #172
                          pc1b4v1y
                          questions: Lenovo does not support unlocking as there is more than 350 days of warranty left
                          • andrew25
                            • Feb 2016
                            • 223
                            • Malawi
                            #173
                            try..
                            write error, readed size 258kb.. your file 256kb
                            • 69d0b913
                              • Mar 2018
                              • 146
                              • BR
                              #174
                              What tool are you using to record? MEC1663?
                              • andrew25
                                • Feb 2016
                                • 223
                                • Malawi
                                #175
                                micro vision programmer rev 4
                                • 69d0b913
                                  • Mar 2018
                                  • 146
                                  • BR
                                  #176
                                  I don't know this tool, I use rt809h and it works fine, I unlocked a lenovo T14 10th ger with the same technique, T490s has MEC1663 as well as T14. The genuine file extracted from the original lenovo .exe file is 257kb, so you need to remove the first byte to adjust-it.
                                  • 69d0b913
                                    • Mar 2018
                                    • 146
                                    • BR
                                    #177
                                    If you were able to read the file, you can insert it back, as this will reset the MEC password. If not, you will have to insert the file I sent you and use the tool to fix the BIOS information.
                                    • 69d0b913
                                      • Mar 2018
                                      • 146
                                      • BR
                                      #178
                                      try with this one
                                        • 21164
                                        never heard of that programmer,can you post a picture of it
                                          • 21164
                                          on site warranty, it makes you wonder why anyone would be unlocking it hmmm
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • Mephysis
                                            DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
                                            by Mephysis
                                            Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
                                            I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
                                            03-27-2025, 02:34 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • hyperwood
                                            [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                                            by hyperwood
                                            I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                                            The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                                            I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                                            āœ… What I need:
                                            • A working 2MB BIOS dump
                                            • Matching NM-E471 Rev. 2.0, e.g. JY575
                                            06-25-2025, 02:28 PM
                                          • Andreas_de
                                            Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                                            by Andreas_de
                                            Hello!
                                            i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                                            Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                                            Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                                            04-12-2025, 10:38 AM
