Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
  • Andreas_de
    • Jul 2024
    • 16
    • Deutschland
    Hello!
    i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
    Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
    Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
    For creating the HEX dump any programming device of Microchip is required. I use an on old PicKit 3 with MPLAB IPE to program the controller. I tried to do a dump of my existing PIC18F87K90, but its fully dead and I dont get response when my programmer is connected.
    Attached you see the pinheader which is already mounted in every MANSON NTP power supply and how to connect the programmer.
    The pre-owner of this power supply did anything, that killed the PIC18F87K90. I dont know what he did exactly but I guess he tried something with the service port on the back of the power supply.
    Software release/revision is R1.0 on my board but I take what I get . I think there is probably only one software version for the whole NTP power supply series which is configures via service port for different models.
    Andreas
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
    03-31-2024, 02:12 PM
  • BigPete
    Panasonic LED TV Dead after EMMC dump
    by BigPete
    I recently took a dump of the 4GB EMMC dump of a new and working Panasonic main board and now the TV won't turn on.
    The dump was successful and the program finished without errors.
    I used a XGecu T48 to do the dump.
    I actually had a few issues getting it to go and I might write up something as a bit of a guide as I couldn't find much in English to go from.
    One thing I did do was connect a 1kohm resistor from the 1.2v line to the RSTN pin as per the instructions, could this have caused issues?
    I also shorted out the crystal of the adjoining ECU together and at one...
    03-15-2026, 03:08 AM
  • Sacajuoy
    Samsung UE46C6735 turns off intermittently - power supply unit PD46AF1 (BN44-00357B) real fault.
    by Sacajuoy
    I've had this Samsung UE46C6735 for many years now and Samsung early on replaced the power supply under warranty explaining that there were design flaws as well as bad capacitors. I worked in electronics design industry at the time and was well aware of the bad capacitor situation.
    Now, the TV worked flawlessly for many many years but in recent years it developed a habit of turning on and off and in the last week it never turned on properly, just blinked on for a short moment and I could hear relay clicking for every try to turn on. At first I was looking for a new TV so on the day...
    09-12-2026, 12:18 PM
  • jovani1989
    HikVision DS-7104HQHI-K1 MB: DS-80303_P REV 2.0 Firmware dump or unlock required
    by jovani1989
    HikVision DS-7104HQHI-K1 Motherboard: DS-80303_P REV 2.0 and SN: C47579229 Firmware dump or unlock required. Thank you!...
    06-11-2025, 01:54 PM
