mec 16xx dump with info block
  • wangbreeze
    • Jan 2024
    • 19
    Originally posted by wangbreeze
    Sharing my experience. I have two t490 that need svp removal. I have the rt809f programmer.
    the first one did not give me problems. Read erase write and svp is gone.
    however, the second one I cannot even recognize the mec chip. The programmer reported 0xCDCDCDCD as the mec chip id. This is the same as if the chip is disconnected from the programmer (i actually tried it with out any pins attached to the programmer, it also reported this chip id).
    I wonder what could be the cause of this discrepancy in the chips response. The one without problem has it’s BIOS dated back to 2021 while the one giving me problems has BIOS dating back to 2022 (so it’s newer).
    anyone can help? Thanks.
    Turned out to be the programmer issue. The RT809F I have worked on the first machine but stopped working on the second (showing 0xCDCDCDCD chip id and reading garbage). I used another rt809h and everything works now.
    • vuquanghoanh
      • Feb 2023
      • 45
      • US
      #402
      did you update the product brand to thinkpad T**?
      Sure. I have successfully entered the brand name. Just like in the photo.
      But every time I start up, the laptop still reports error 2202.
      I don't know what to do anymore​
      • Maxpower3
        Bad Veteran
        • Feb 2018
        • 1226
        • France
        #403
        not 7th gen just 7th
        Click image for larger version  Name:	Nouveau Image bitmap (2).bmp Views:	0 Size:	1.14 MB ID:	3220764
        otherwise use planar service with your serial
        https://www.badcaps.net/forum/troubl...id#post3220825
        • noktabiz
          • Aug 2016
          • 8
          • türkiye
          #404
          I have successfully removed EC password. The system has received complete information. But when starting the laptop there is still message 2202: Product name is invalid.
          I used the Gold key to re-enter the information but the problem was not resolved.
          Has anyone solved this problem yet?​
          Thanks,
          Change the ec you use. and write another one and enter your information again
          • vuquanghoanh
            • Feb 2023
            • 45
            • US
            #405
            Thank you so much.
            I have been trying to enter Brand name for 1 week but without success. With your guidance, I succeeded the first time.
            Thank you so much.
            • vuquanghoanh
              • Feb 2023
              • 45
              • US
              #406
              I followed Maxpower3's instructions and it worked. Follow him, you will also succeed.
              Let's thank Maxpower3.​
              • mily.gawel
                • Aug 2018
                • 42
                • Polska
                #407
                Hello, maybe one of you can help me. I have 2 T14s laptops with board number NM-C891, after soldering the wires and moving the resistor, I still get the message in SVOD 4.
                MEC IDCODE: B1240020
                Device ID: 0
                Device Revision: 0
                Device Status: 0
                Flash Status: 0000000000
                Boot Block in not protected mode
                the reading is empty every time. I will add that in the X390, where the board is very similar, I managed to do it every time. Maybe someone had a similar problem ?
                • wangbreeze
                  • Jan 2024
                  • 19
                  Device ID: 0
                  Device Revision: 0
                  Device Status: 0
                  I think the chip is locked sometimes. In this case, you cannot read. You would need to erase and write the EC file extracted from Lenovo BIOS update package.
                  • mily.gawel
                    • Aug 2018
                    • 42
                    • Polska
                    #409
                    Unfortunately I tried but it also cannot be cleaned.
                    • TigTex
                      • Jun 2014
                      • Portugal
                      #410
                      try
                      Hey Maxpower3, I've noticed that you've filled with F the blocks from 0x300 to 0x34F. Is this all it takes with all MEC1663 to erase SVP or was this something specific for this user's laptop?
                      I've screwed up a T14 gen1 and now I need to erase the SVP to make it bootable again (0199 System Security error). I'm going to use a Vertyanov JIG V3 for that and I would like to avoid losing all OEM info and windows activation.
                      • Maxpower3
                        Bad Veteran
                        • Feb 2018
                        • 1226
                        • France
                        #411
                        yes 300 to 34F is enough, no loss of DMI information or windows key​
                        just look at the following CON# (43 4F 4E 23 53 00 02 A8 F4) or BC B0 B1 DC AC FF FD 57 0B 02 A8) in Xor version.
                        Same principle for all, can be doubled on certain models​
                        • skazide
                          • Jul 2015
                          • 142
                          • morocco
                          #412
                          Originally posted by monolith-2001
                          I have read the EEPROM area of MEC1663.
                          Where and how should I edit the BIN file to remove only the BIOS password?"
                          Thank you in advance.
                          X1 Carbon Gen8 20UA
                          how you did it bro
                          • EGUG
                            • May 2024
                            • 11
                            • Deutschland
                            #413
                            I have RT809F and a damaged Thinkpad T490 board (M2-Connector was damaged and is removed). I use it for testing the procedure of removing the SVP from MEC-Chip. (Yes, I have the SVP.) I do this test because we received Thinkpads T490 donated for our school but they have SVPs. At present they are used. But during summer holidays I hope to remove the SVPs this way.
                            Typ 20N3001EGE
                            Serial PF1DTJNC
                            Bios N2IET99W (1.77)
                            The MEC chip is recognized correctly. I can read and write the MEC using MEC1633_256. My problem is that erasing of the Chip doest not work.
                            Does anyone have an idea what the cause could be?
                            • ajbernasko
                              • Mar 2022
                              • 229
                              • ghana
                              #414
                              I have SVOD4, I can read and write it5679-1M chip for the P14s gen 2, nm-D451. Can someone share the file for this chip ?
                            • EGUG
                              • May 2024
                              • 11
                              • Deutschland
                              #415
                              Nobody has an idea ? (Post 413)
                              • vuquanghoanh
                                • Feb 2023
                                • 45
                                • US
                                #416
                                My laptop has bios password.
                                Thinkpad T490S FT491/FX390 NM-B891 REV 2.0
                                S/T: MJ-0C3ABP
                                Here is bios dump. Please unlock it.
                                Thanks,...​
                                • Stefan Steff
                                  • Mar 2024
                                  • 277
                                  #417
                                  S/T: MJ-0C3ABP
                                  Thanks,...​
                                  Hi !
                                  There is no difference between your uploaded MEC content and the factory one (attached)...they are identical.
                                  The password is stored in the 2K EEPROM inside the MEC.
                                  There are programmers (like SVOD 4) that can read the eeprom content separately and then you can delete the password.
                                  If you don't have such a programmer you can simply erase and reprogram the whole MEC1633 and after that reinsert the DMI info.
                                  This is my opinion.
                                  SS
                                  • vuquanghoanh
                                    • Feb 2023
                                    • 45
                                    • US
                                    #418
                                    Originally posted by Stefan Steff
                                    Hi !
                                    This is my opinion.
                                    SS
                                    I read the Mec file, erased the chip. Reload the original file (do not edit). Password is removed. This is how I did it successfully for the T490S and T14 Gen 1.
                                    Thank you very much​
                                    • Stefan Steff
                                      • Mar 2024
                                      • 277
                                      #419
                                      Wonderful
                                      You're welcome !
                                      • bhatt
                                        • Dec 2015
                                        • 92
                                        • pakistan
                                        #420
                                        Originally posted by aldopc
                                        Re: mec 16xx dump with info block
                                        Hello, do it with this tool and watch this video. https://www.youtube.com/watch?v=gKL9JUTgo-g&t=519s
                                        what is the u1u zip file password
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • Mephysis
                                          DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
                                          by Mephysis
                                          Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
                                          I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
                                          03-27-2025, 02:34 AM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
                                        • hyperwood
                                          [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                                          by hyperwood
                                          I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                                          The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                                          I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                                          ✅ What I need:
                                          • A working 2MB BIOS dump
                                          • Matching NM-E471 Rev. 2.0, e.g. JY575
                                          06-25-2025, 02:28 PM
                                        • Andreas_de
                                          Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                                          by Andreas_de
                                          Hello!
                                          i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                                          Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                                          Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                                          04-12-2025, 10:38 AM
