mec 16xx dump with info block
  • jetseth
    • Sep 2022
    • 7
    Re: mec 16xx dump with info block
    Hi!
    I have a ThinkPad X270 with a bricked EC image after a bad flash under Windows, I have a svod4 programmer but I can't seem to be able to read the MEC1653, I tried using the 32-pin keyboard connector after taking out R182 but I still can't read it, is there any test points I can use to hook it up directly? I'm a bit confused after reading the whole thread...
    • mazoot
      iFixit
      • Jan 2019
      • 41
      • Moldova
      #322
      Originally posted by jetseth
      Hi!
      make a clear photo of your board near EC and model of board
      Kill the state in yourself and you will be free like a wind...
      • jetseth
        • Sep 2022
        • 7
        Here you go, NM-B061 Rev. 0.4
        • greymind
          • Feb 2023
          • 12
          • New Zealand
          #324
          Originally posted by anhbanxoi
          Yes, somebody connected like the attachment photo.
          Hi, I've a X1 Yoga Gen 5 as well. May I know what is the cheapest programmer that I can use to do this? I need to remove the SVP as well.
          Sorry, I'm totally new here and don't have any experience in this. Please help a total beginner. Cheers.
          • greymind
            • Feb 2023
            • 12
            • New Zealand
            #325
            Also, can somebody tell me which one is the 10k resistor? How do you take it off and put back in? Do I have to solder it back in? Thanks
            • RethoricalCheese
              • Mar 2013
              • 1519
              • Estonia
              #326
              You don't take it off, you move it to the correct position. By soldering.
              • greymind
                • Feb 2023
                • 12
                • New Zealand
                #327
                Any idea which is the 10k resistor to move? Cheers
                • dimah77
                  • Sep 2016
                  • 147
                  • ALGERIA
                  #328
                  measure this one, if 10K, then it must be that
                  • greymind
                    • Feb 2023
                    • 12
                    • New Zealand
                    #329
                    Thank, when I tried to measure it, I just realised that this maybe out of my league. The actual resistor is so small compared to the photo. I may not have the right tool to do that.
                    I'll see if my mate can help with that. Thanks.
                    • couillu76
                      • Jan 2022
                      • 39
                      #330
                      found some infos for unlocking mec 1663 especially when the mec blocks cant be read
                      https://www.youtube.com/watch?v=PyJhlwxCI5w&t=1314s
                      • couillu76
                        • Jan 2022
                        • 39
                        #331
                        today i have followed this video i have posted my Mec1663 was locked i could only read the the id of the chip. and doing what the guy explained on the video i managed to read the chip and all information on it and unlock the bios with my SVOD4 ,only had to read the 2k eepron of the mec erased it and restarted , bios password gone
                        • sandro123
                          • Apr 2014
                          • Italy
                          #332
                          @couillu76
                          I have done all changes , pullup resiostors and the same situation
                          can only READID , no data
                          thank you for help
                          • roadrun
                            • Jan 2023
                            Originally posted by volinakis
                            I want to share my 1st experience with MEC1663 from Yoga X1 4th gen.
                            Many thanks to AAAC, RethoricalCheese, EvilBzyk, their shared knowledge helped me a lot.
                            1. Connected jtag pins as in picture, no pull up resistor needed. Moved 10k resistor from pull-down to pull-up. Chose MEC1633#ISP. power on motherboard.
                            2. Got message "Chip may be damaged or encrypted, the data is not valid" I did try other options, MEC1653#ISP, MEC1633_256k, same result.
                            3. I hit "Erase" and laptop stops working, no power on/charge led lit.
                            4. I took EC file from bios update and trim 32bytes, the same version it was in bios (I took a photo of info in bios before pulling off the motherboard) wrote the file into EC then power off motherboard. Waited few minutes an power on motherboard, power on/charge led lit. Moved the 10k resistor to pull down.
                            5. schematics IS WRONG! TP1 IS REVERSED WITH TP5.
                            Hello, can you explain how to find the MEC-Image in an bios update? And how I trim it correct. I can read the CHIP ID, but after verifying the checksum is 0 and RT809H says it is encrypted.
                            I have downloaded an bios update for LINUX, which contain 2 cab files. One is an bin for EC with 760kb , which is to much for an MEC1633.
                            • rbvndonh
                              • Mar 2021
                              • 162
                              • B
                              #334
                              So it means Svod 3/4 connect to 192kb area, but it is required to connect with 256kb area, which RT809H do (if you not choose ISP).
                              I wonder if it is possible to force OEM update tool to push full 256kb flash, as it contents this part of memory for MEC..
                              There is no other JTAG DIY tool to read and write this MEC area?
                              Buying RT809H for repair of 3 laptops per year is kind of overpayment..
                              • dani981
                                • Mar 2018
                                • 89
                                • Hungary
                                #335
                                Hi Please Help me Lenovo P52 EP520-NM-B562 Rev 1.0
                                Pull up resistor place? R577 replace R600 ?
                                JTAG enable short 0 ohm resistor R661 R662 R663 R664 ?
                                • dimah77
                                  • Sep 2016
                                  • 147
                                  • ALGERIA
                                  #336
                                  I do it with RT809F, wich is 3X more cheaper
                                  • stylius
                                    • 13
                                    • Vilnius
                                    #337
                                    Hello. Need some help and idea. X1 carbon 7 generation. Needed remove bios pasword. Try read mec1633 with RT809 but not sucefuull, chip maybe locked. So i try erase, all ok. But now dont have EC dump. Try write latest bios update EC file from lenovo suport, but laptop dont turn any more. I edit ec file, try compare from other same ec dump, size and adress location same. So my edited dump i hope are okey. When i try write dump i verification not ok. It ok for mec?
                                    • narsil
                                      Enas
                                      • Dec 2017
                                      • 83
                                      • france
                                      #338
                                      Originally posted by 69d0b913
                                      this is not a valid serial
                                      What did you do to have the file read
                                      I see it but the file is empty
                                      • narsil
                                        Enas
                                        • Dec 2017
                                        • 83
                                        • france
                                        #339
                                        You don't need a resistor, just jump and read it, if you couldn't read it, you can extract the EC from the original file and then just flash the MEC16xx, nothing more than that. After the procedure you will have to write all the machine information such as the serial number of the machine board and a few more things. Some machines can't read the MEC16xx just write, I had this same experience on a T14 thinkpad, I discovered it after 3 weeks of attempts, so I just wrote it I used the same way I described it above and then I was successful.
                                        PC-1ZK52X
                                        20T3-SAG200
                                        I want the file if possible
                                        Can it be shipped because the original file comes empty and I cannot read it
                                        • stylius
                                          • 13
                                          • Vilnius
                                          #340
                                          Solved with vertinanov jig.
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • Mephysis
                                            DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
                                            by Mephysis
                                            Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
                                            I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
                                            03-27-2025, 02:34 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • hyperwood
                                            [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                                            by hyperwood
                                            I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                                            The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                                            I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                                            āœ… What I need:
                                            • A working 2MB BIOS dump
                                            • Matching NM-E471 Rev. 2.0, e.g. JY575
                                            06-25-2025, 02:28 PM
                                          • Andreas_de
                                            Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                                            by Andreas_de
                                            Hello!
                                            i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                                            Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                                            Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                                            04-12-2025, 10:38 AM
