Hp elitebook 840 g5 bios password
  • m.sabry2110
    • Oct 2017
    • 129
    • egypt
    #321
    Originally posted by motanya
    Serial Number : 5CG8494FHJ
    Description : HP EliteBook 840 G5
    Password unlok​
    try
    • bibi019
      • Jun 2014
      • 57
      • algeria
      #322
      Hi all i need clean file for tHis bios dump Hp elitebook 840 g5. i5 8 generation sn 5CG92229D3
      yours
      emergency
      • hoaca388
        Badcaps
        • Jan 2022
        • 11883
        #323
        yours
        emergency
        HP EliteBook 840 G5 Base Model Notebook PC
        • bibi019
          • Jun 2014
          • 57
          • algeria
          #324
          tHanks for tHe replay but tHe bios still locked it ask always for bios administrator password any Help
          • motanya
            • Nov 2021
            • 160
            • Kenya
            #325
            Originally posted by m.sabry2110
            try
            Worked, thank you
            • rddube
              Aspiring Expert
              • Jun 2013
              • 944
              Hello everyone, need help in Bios unlocking this Lenovo 840 G5. I tried with the HP unlock tool on the larger Bios chip but it didn't work. So I am uploading both bios chips could anyone remove the bios lock? Many thanks!
              • peste
                • 12945
                • ROMANIA
                #327
                try.. The 16 MB one remains the same.
                • rddube
                  Aspiring Expert
                  • Jun 2013
                  • 944
                  Hi Peste, no that didn't work this is the screen I get when hitting F10
                  • rddube
                    Aspiring Expert
                    • Jun 2013
                    • 944
                    Not sure if this is important, but when I boot and press F10, before getting the Bios Administrator Password screen, I get this screen which say PROPERTY OF GHD then the HP logo and then the message Protected by HP Sure Start.
                    I tried looking for the string "PROPERTY OF GHD" in both the 16MB and 32MB files but did not find anything. Not sure what to try next?
                    • rddube
                      Aspiring Expert
                      • Jun 2013
                      • 944
                      Ok, so figured it out and will post the solution in case someone has the same issue. Unlocking the 32MB file did not to the trick. Used RcUnlocker on the 16MB chip and that did the trick it is now unlocked. Many thanks to all of you and thanks Peste!
                      • madmanaic73
                        • Jan 2025
                        • Sweden
                        #331
                        I have a HP 840 G5 that is admin password locked (abandoned from a company). I have been trying a good way to unlock it and reading up on almost the entire thread here it seems reading out the 32MB chip patching it with RCUnlocker is what most people say. I did this (was a Winbond 25Q256JVEQ chip) and to my surprise RCUnlocker told me that the 32MB file was not compatible and I should try a 16MB file. My two questions to anyone who could bring more insight:
                        1. Is RCUnlocker indeed not compatible with 32MB BIOS files? It seems a lot of people have run it successfully
                        2. Is it so that SOME 840 G5 are password locked in the 32MB BIOS and others in the 16MB? It seems very inconcistent.
                        Thanks in advance!
                        • rddube
                          Aspiring Expert
                          • Jun 2013
                          • 944
                          Originally posted by madmanaic73
                          Thanks in advance!
                          Read the previous post to yours. I mistakenly reported it as a Lenovo 840 G5 but it is an HP 840 G5. Good luck!
                          • madmanaic73
                            • Jan 2025
                            • Sweden
                            #333
                            That is what led up to these questions, I suspect you are right, but in other replies in this thread it is clearly stated to be the 32Mb chip that should be patched (which seems impossible to me using RCUnlocker). Seems a bit inconsistent and would be interesting to understand if this is different in different versions of the 840 G5.
                            • madmanaic73
                              • Jan 2025
                              • Sweden
                              #334
                              rddube I was hoping to not have to desolder the 16MB chip (since I successfully connected to the 32Mb using wires). Just to double check: How did you connect to the 16Mb chip? Desolder? Clip? Wires? It seems that with wires my flash device says (no connection to IC) and at the same time a LED is flashing yellow on the motherboard (probably powered backwards from the chip flasher).
                              • rddube
                                Aspiring Expert
                                • Jun 2013
                                • 944
                                The 16mb chip is on the other side of the motherboard, so you are going to take the motherboard out. I always desolder the bios they are so easy to desolder and use one of these attached SOP8 to DIP8 (I have different sizes) and resolder onto the board. You can always use the little board that comes with the CH341 programmer - just make sure you've got pin 1 on pin 1, etc. I never use the clips they are junk as far as I'm concerned.
                                • madmanaic73
                                  • Jan 2025
                                  • Sweden
                                  #336
                                  OK, so everything worked out just fine, let me share my learnings from this:
                                  1. HP 840 G5 more often that not seems to have password configured in the EC chip on the backside of the motherboard, in my case a Winbond 25Q128JV SMD chip.
                                  2. This chip can't be read or programmed when connected to the motherboard, there seems to be a protection kicking in. Must be desoldered.
                                  3. The chip can easily be read and programmed with CH341A programmer when desoldered, and RCUnlocker worked on the first try.
                                  4. Beware to read more than once and compare readouts, also after programming, read back several times and file compare.
                                  5. Be very careful when resoldering to use enough flux and flow the connecting pins and pads generously.
                                  All in all it worked great, but it was tricky to arrive at this solution due to the contradictory information in this thread. At least this procedure should work for all devices with the same motherboard type than mine.
                                  Thanks rddube for the help to arrive at the right answer.
                                  • GB1999
                                    • Mar 2023
                                    • 71
                                    • Malaysia
                                    #337
                                    hi, please help me remove the admin lock.
                                    840 g5
                                    sn: 5CG9152N96
                                    THANKS IN ADVANCE
                                      • 21150
                                      840 g5
                                      sn: 5CG9152N96
                                      THANKS IN ADVANCE
                                      Read the post above yours, use RCUnlocker https://www.badcaps.net/forum/troubl...23#post1622423
                                      • jiten1885
                                        • Apr 2021
                                        Looking to remove password from this HP 840 G5 bios.
                                      • lapfix
                                        • Mar 2020
                                        • 2742
                                        • my workshop
                                        #340
                                        Try and GIVE feedback
                                        First boot load bios factory defaults, save and exit and then at the next boot disable security options
                                        You must fill your DMI manually.​
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • traxformania
                                          TONGFANG "GM7TG7P" Bios Password Problem?
                                          by traxformania
                                          I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                          But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                          I'm trying to reset my bios without success.
                                          I tried :
                                          -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                          11-15-2023, 07:32 AM
                                        • tlindi
                                          Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                          by tlindi
                                          Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                          >Read BIOS guides, methods, resources and tools
                                          Ack
                                          >Try the method at BIOS guides, methods, resources and tools before requesting help
                                          Ack
                                          >Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                                          python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
                                          01-30-2025, 04:26 AM
                                        • Nopslide
                                          HP Omen 15-dh0052nf power-on & bios password
                                          by Nopslide
                                          Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                          My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                          Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                          04-01-2024, 04:27 PM
                                        • BlackVisor
                                          How to Decode BIOS password for RedmiBook Pro15 2022 6800H
                                          by BlackVisor
                                          RedmiBook Pro 1542022 6800H
                                          SKU: TM2113-39463
                                          Model Number: RMA2204-AB
                                          CMIIT ID: 2022AP1835
                                          SN: 39463/22WD01355
                                          BIOS version: RMARB5B0P1010 20230628
                                          1. I bought this laptop from flea market, and the seller said that he had never set a password, however here is a password required when pressing F2 to enter BIOS.
                                          2. And after entering incorrrect password 3 times, there is no any useful information like "recovery code"
                                          3. I used universal bios backup tool, and dumped 8MB bin file, but hex code after "SystemSupervisorPw" is...
                                          01-14-2024, 06:35 AM
