Hp elitebook 840 g5 bios password
  • YKMN
    • Dec 2022
    • 29
    • NL
    #141
    Re: Hp ellİtebook 840 g5 bios password
    Could you guys help me with resistor value near pin 7 of Bios (post 63) i accidentally wiped him away with wick from the board Is it 3,3k omh ?
    • hoaca388
      Badcaps
      • Jan 2022
      • 11878
      #142
      Originally posted by NaneName
      Hi all!
      Probe delivered. But the situation is bad. All 5 readings gave different results.
      The situation by region is in the attachment.
      "+" - match
      "-" - difference
      Is the 3rd reading correct? For flashing, the chip will be soldered.
      Post 3rd result. The 3rd read I saw enough areas of the bios file.
      • YKMN
        • Dec 2022
        • 29
        • NL
        #143
        In case anyone will need it, i find out its value of 15 Ohm, be aware there are different configurations of traces layout on motherboards. Mine corresponds to photo from post 63 (6050A2945601-mb-a01).
        • macsoftware
          • Jul 2016
          • 25
          • MOROCO
          #144
          help me plz i want clean the admin password from this bios elitebook 830 g5 thank you
          • satishkumar
            • Sep 2015
            • 164
            • India
            #145
            • macsoftware
              • Jul 2016
              • 25
              • MOROCO
              #146
              Originally posted by satishkumar
              not working the fun starting and no stoping
              • hardware1
                • Sep 2021
                • 2939
                • N/A
                #147
                Here's your Unlocked file, in the first boot go to bios menu and disable security options (Default).
                If that password still exist, upload the other chip (EC) it could be 16MB or 32MB.
                all donations are welcome,
                • macsoftware
                  • Jul 2016
                  • 25
                  • MOROCO
                  #148
                  thank you the first bios it s working
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11878
                    #149
                    Originally posted by mah3r0
                    I need bios dump file bin for hp 15-fa0031dx
                    • Derhalt
                      • Nov 2018
                      • 7
                      Hi,just tried to unlock my hp 840G5 Bios with thetool from the first page on https://www.badcaps.net/forum/showthread.php?t=103184, but it doesn't worked. As there are two IC's which belongsto the BIOS, I'm not sure if I did it with the right one. So question first, is the large 32MB the right one and if yes, is somebody able to do the unlock of my attached one?
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11878
                        #151
                        Try this file
                        Product name : HP EliteBook 840 G5
                        Serial number : 5CG8291RP1
                        SKU : 3RF16UT#ABA
                        Build ID : 17WWCSAT601#SABA#DABA
                        Fearture byte : 3X476J6S6b7B7H7M7Q7W7m7saBapaqauawb8bUbhcAdUdpdqgdhKhkjh.5F
                        • Derhalt
                          • Nov 2018
                          • 7
                          great works!!!
                          How do I update now the lost device details,likethe srial number etc.?
                          • Derhalt
                            • Nov 2018
                            • 7
                            the laptop is currently in step 30 of the manufacturing program mode...
                            • volinakis
                              • Jan 2021
                              • 2744
                              • N/A
                              #154
                              press F10, in "Main" you have a tab "set machine unique data" and write all data hoaca388 gave you. After that use BCU 4.0 to exit MPM mode or restart laptop 27 times or whatever counter shows.
                              • Derhalt
                                • Nov 2018
                                • 7
                                Done
                                • repairit.ie
                                  • Jan 2020
                                  • 8
                                  • Ireland
                                  #156
                                  HP 840 G5 Bios unlock
                                  Hi Guys,
                                  Can someone help me with unlocking this BIOS ?
                                  I tried RCunlocker and HPUnlocker but password @ Power-On Authentication is always there.
                                  Can someone unlock it for me please?
                                  • peste
                                    • 12944
                                    • ROMANIA
                                    #157
                                    Re: HP 840 G5 Bios unlock
                                    Originally posted by repairit.ie
                                    Hi Guys,
                                    also post the content of the other bios chip..
                                    • repairit.ie
                                      • Jan 2020
                                      • 8
                                      • Ireland
                                      #158
                                      Here is the 32mb Bios
                                      Thanks!
                                      • repairit.ie
                                        • Jan 2020
                                        • 8
                                        • Ireland
                                        #159
                                        I used again HP unlocker and unlocked other 32mb bios. Programmed them into chips and there is no password.
                                        The only thing now is that computer displays "BIOS identity Data Needs To Be Restored. The embedded controller MUD data does not match the BIOS MUD data."
                                        Then Gives me two options RESTORE and DO NOT RESTORE.
                                        Restore option does not work, only when i click on DO NOT RESTORE computer loads to OS.
                                        There is couple of details missing in info about computer in BIOS like production date etc.
                                        Any way to fix this issue? Was there something that HPUnlocker did that this message came up?
                                        • xedry@yahoo.com
                                          • May 2016
                                          • 7
                                          • philiphines
                                          #160
                                          can someone help hp elitebook 840 g5 bios password file, i try to use hp unlocker to 32mb bios files do i need to unlock the ec file also using hp unlocker?
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                            But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                            I'm trying to reset my bios without success.
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
                                          • tlindi
                                            Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                            by tlindi
                                            Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                            >Read BIOS guides, methods, resources and tools
                                            Ack
                                            >Try the method at BIOS guides, methods, resources and tools before requesting help
                                            Ack
                                            >Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                                            python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
                                            01-30-2025, 04:26 AM
                                          • Nopslide
                                            HP Omen 15-dh0052nf power-on & bios password
                                            by Nopslide
                                            Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                            My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                            Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                            04-01-2024, 04:27 PM
                                          • BlackVisor
                                            How to Decode BIOS password for RedmiBook Pro15 2022 6800H
                                            by BlackVisor
                                            RedmiBook Pro 1542022 6800H
                                            SKU: TM2113-39463
                                            Model Number: RMA2204-AB
                                            CMIIT ID: 2022AP1835
                                            SN: 39463/22WD01355
                                            BIOS version: RMARB5B0P1010 20230628
                                            1. I bought this laptop from flea market, and the seller said that he had never set a password, however here is a password required when pressing F2 to enter BIOS.
                                            2. And after entering incorrrect password 3 times, there is no any useful information like "recovery code"
                                            3. I used universal bios backup tool, and dumped 8MB bin file, but hex code after "SystemSupervisorPw" is...
                                            01-14-2024, 06:35 AM
