Hp elitebook 840 g5 bios password
  • viji90
    • Jul 2017
    • 22
    • india
    #281
    HP elitebook 840 g5 bios password clean
    pls help me to my locked file
  • Expired
    • Feb 2023
    • 34
    Try to clean your self first https://www.badcaps.net/forum/troubl...elines?t=88758
    if your still having issues send the 16mb bios file.
    • gctdpacov
      • Nov 2022
      • 43
      Originally posted by rex98
      only flash this ec. use RC unlocker in all HP 16MB ec next time.
      Thanks for your help
      • Echoo
        • Apr 2018
        • 88
        • Budapest
        #284
        Hello!
        I unlocked the bios password with RCUnlocker of the 840 G5, but since then every time I turn it on I get an HP Endpoint Security Controller problem. I am attaching the backup copy of the 32MB chip, please help me with the solution!
        HP EliteBook 840 G5
        PN: 2FA66AV
        SN: 5CG8253GZD
        Last edited by Echoo; 05-30-2024, 12:49 AM. Reason: I tried to write about this in the appropriate topic, but there was no reply. Here it is disassembled on my desk...
        • rex98
          • Feb 2023
          • 1280
          • Mandaue CEBU, Philippines
          #285
          Originally posted by Echoo
          Hello!
          HP EliteBook 840 G5
          PN: 2FA66AV
          SN: 5CG8253GZD
          flash this main and the original locked EC.
          first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
          after following my instruction to get rid of Manufacturing mode. use BCU. or flash the original main.​
          • Echoo
            • Apr 2018
            • 88
            • Budapest
            #286
            Thank you for your help! Perfect!
            • Ado02
              • Jul 2021
              • 100
              #287
              Could someone please help remove the password from the attached files?
              I've attempted using the unlock tool, but it still prompts me for the password.
              Attached are the files from both ICs and the unlock files as well.
              SN: 5CG85033FH
              Model: HP EliteBook 840 G5
              Motherboard: COMPUTRO-6050A3079801-MB-A01
              Thank you!
              • peste
                • 12973
                • ROMANIA
                #288
                Thank you!
                read the rules..https://www.badcaps.net/forum/troubl...before-posting
                post the S/N, , the motherboard model, the full name and model of the laptop,
                ​etc.
                • Ado02
                  • Jul 2021
                  • 100
                  #289
                  ​etc.
                  Thank you - I update the post with requested info
                  • rex98
                    • Feb 2023
                    • 1280
                    #290
                    SN: 5CG85033FH
                    Thank you!
                    only flash this 16mb
                    • Ado02
                      • Jul 2021
                      • 100
                      #291
                      Thank you for your help. I followed your instructions but encountered an issue. I received a message indicating that the BIOS blocks don't match and that I need to update the BIOS. However, when I reached the battery screen (the battery capacity error message due to the battery not being connected), the system froze.
                      Upon restarting the laptop, I observed six orange flashes and then nothing happened. I removed the chip again and compared the files, noting that some changes had been made.
                      Do you have any suggestions on how to proceed?​
                      • rex98
                        • Feb 2023
                        • 1280
                        #292
                        Serial Number: 5CG85033FH
                        Product #/SKU: 3UP81ET#ABU
                        CT Number: PGWNQ00WBBO1RJ
                        Description: HP EliteBook 840 G5
                        BuildID: 17WWCSBT602#SABU#DABU
                        Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfAgdhKhkjh.GE
                        MAC Address : E4:E7:49:9E:89:F2​
                        • lovepreet fatehpur
                          • Jul 2024
                          • canada
                          #293
                          Hi request to unlock bios HP ELITEBOOK 840 G5
                          i tried to unlock with hp unlocker but password still there.
                          productid 6AU11UP#ABA
                          SN 5CG9292NXS
                          i have read most of posts about unlocking the bios but i am so confused could you please tell me all steps just for my case
                          i am attaching dump file
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 11903
                            #294
                            SN 5CG9292NXS
                            HP EliteBook 840 G5
                            Serial_5CG9292NXS
                            Sku_6AU11UP#ABA
                            Fearture byte_3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqhKhkj4jh.mh
                            Build Id_17WWCSCT601#SABA#DABA
                            CT Number_6GPRE05WYAS7WB
                              • Jul 2024
                              • canada
                              #295
                              I did reprogram the main chip with bin file you provided but i also de assembled and reprogrammed the chip which is located at back of board. Saved original bin then unlocked with hp unlocker. But laptop doesn’t power up now no sign of light even the charging plug on. No light on keyboard.
                              • Mykyta Khruslov
                                • Mar 2024
                                • 7
                                #296
                                Hi. Somebody help please. BIOS PASS --- Thanks a lot!
                                HP EliteBook 840 G5
                                Chip -- W25Q256JV
                                S/N -- 5CG9052CP3
                                MB -- L15516-601
                                P/N -- 2FA64AV
                                • peste
                                  • 12973
                                  • ROMANIA
                                  #297
                                  HP EliteBook 840 G5
                                  Chip -- W25Q256JV
                                  S/N -- 5CG9052CP3
                                  MB -- L15516-601
                                  P/N -- 2FA64AV
                                  try..
                                  • Mykyta Khruslov
                                    • Mar 2024
                                    • 7
                                    #298
                                    Thanks a LOT. You are SUPER HERO !!!
                                    • SCREAM76
                                      • Jan 2014
                                      • 53
                                      • istanbul
                                      #299
                                      There is the original bios password attached, can you please help me clear it. I installed another bios and it shows the first image very late
                                      840-G5
                                      P.id: 4RU26EC#AB8
                                      SN: 5CG91214GL​
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 11903
                                        #300
                                        840-G5
                                        P.id: 4RU26EC#AB8
                                        SN: 5CG91214GL​
                                        HP EliteBook 840 G5
                                        Serial_5CG8471ZB4
                                        Sku_4RU28EC#AB8
                                        Fearture byte_3X476J6S6b7B7H7M7Q7W7m7saEapaqauawbUcAdUdpdqeMfXgdhKhkjh.f
                                        Build Id_17WWCSBT602#SAB8#DAB8
                                        CT Number_6GPRF06TZBYBP7
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • traxformania
                                          TONGFANG "GM7TG7P" Bios Password Problem?
                                          by traxformania
                                          I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                          But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                          I'm trying to reset my bios without success.
                                          I tried :
                                          -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                          11-15-2023, 07:32 AM
                                        • tlindi
                                          Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                          by tlindi
                                          Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                          >Read BIOS guides, methods, resources and tools
                                          Ack
                                          >Try the method at BIOS guides, methods, resources and tools before requesting help
                                          Ack
                                          >Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                                          python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
                                          01-30-2025, 04:26 AM
                                        • Nopslide
                                          HP Omen 15-dh0052nf power-on & bios password
                                          by Nopslide
                                          Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                          My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                          Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                          04-01-2024, 04:27 PM
                                        • BlackVisor
                                          How to Decode BIOS password for RedmiBook Pro15 2022 6800H
                                          by BlackVisor
                                          RedmiBook Pro 1542022 6800H
                                          SKU: TM2113-39463
                                          Model Number: RMA2204-AB
                                          CMIIT ID: 2022AP1835
                                          SN: 39463/22WD01355
                                          BIOS version: RMARB5B0P1010 20230628
                                          1. I bought this laptop from flea market, and the seller said that he had never set a password, however here is a password required when pressing F2 to enter BIOS.
                                          2. And after entering incorrrect password 3 times, there is no any useful information like "recovery code"
                                          3. I used universal bios backup tool, and dumped 8MB bin file, but hex code after "SystemSupervisorPw" is...
                                          01-14-2024, 06:35 AM
