Hp elitebook 840 g5 bios password
  • q2v5
    • Sep 2023
    • 7
    Re: Hp ellİtebook 840 g5 bios password
    Originally posted by hoaca388
    RC unlocker. Use rc unlocker for 16 MB chip.
    Thank you very much.
    I soldered back the 32MB chip but maybe I killed it as now I get flashing power light. Will have to try a new chip before I flash the other 16MB I think.
    • hoaca388
      Badcaps
      • Jan 2022
      • 11885
      #222
      HP EliteBook 840 G5 Notebook PC
      • q2v5
        • Sep 2023
        • 7
        Thanks, I tried this- now the keyboard/powerlights come on, then the power light flashes orange 30 times, then 7 times & it powers off.
        I haven't flashed the 16MB chip yet as I wanted to make sure I fixed this problem first, but should I flash it to work with your file?
        Thanks again
        • aldopc
          • Jul 2017
          • 465
          • Chilito
          #224
          Thanks again
          Hello, you must first solve the 32mb chip, it must turn on again, locked, leaving your original copy, if you still have no image, you must check the soldering of your chip on the board, you must also check the components that are around your chip, maybe some microcomponent came out. Upload an image of that sector to verify...
          • q2v5
            • Sep 2023
            • 7
            Thank you everyone for your help, I tried reflashing my backup & resoldering but the same problem.
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria 🇧🇬
              #226
              Become a Badcaps supporter
              Thanks to all supporters.
              • aldopc
                • Jul 2017
                • 465
                • Chilito
                #227
                Originally posted by Vesko356
                Correct, you lost 2 resistors, the one on the left is 468 kΩ and the one on the right is 0.02 kΩ
                • q2v5
                  • Sep 2023
                  • 7
                  @Vesko356 Thanks, guess it's time to buy a microscope..
                  Thanks also, will order those values & be more careful.
                  • klasg
                    • Aug 2023
                    • Sverige
                    #229
                    Do you know the values on the other 2 resistors around the chip?
                    • ashr88
                      • Mar 2023
                      • 59
                      #230
                      Hi, I have an HP Elitebook 840 G5 and I need the bios password removing. I tried the 16mb file on the RC unlocker and the password remains. Then I tried the 32MB file on the HP unlocker and it doesn't boot and only the fans spin up fully but no display. I've attached both 16 and 32mb files. Please could somebody advise or help? Thank you.
                      Serial No: 5CG9086VV9
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11885
                        #231
                        Unlocked
                        • ashr88
                          • Mar 2023
                          • 59
                          #232
                          Unlocked
                          Thank you for that. I flashed them both but the laptop is still a no boot. Fan up full, power consumption stuck at .256a. CPU is freezing. Any ideas? It was booting now I seem to have murdered it!
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 11885
                            #233
                            Replace a blank chip and flash again
                            • ashr88
                              • Mar 2023
                              • 59
                              #234
                              Do you mean blank the chip or replace the chip with a new one? Do you mean replace all chips?
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11885
                                #235
                                Yes ! Have you read article 226 yet?
                                • ashr88
                                  • Mar 2023
                                  • 59
                                  #236
                                  Thank you, I accidentally knocked this off. I've replaced it and now it's booted! Thank you.
                                  • ashr88
                                    • Mar 2023
                                    • 59
                                    #237
                                    Unlocked
                                    Hi again, I have another 840 G5 which came to me as a no boot. I found it was missing the bios chips so I flashed these bios files to doner chips and it now boots. The only issue is that it takes 40 seconds to post so I assumed I needed to clean the ME so using the Intel ME/TXE injector and injected 11.8.70.3626 and it boots but it still takes 40 seconds to post. What should I do to resolve this? Thank you.
                                    I have attached the files.
                                    HP Elitebook 840 G5
                                    Serial No: 5CG9086VV9 (May be incorrect as I got a job lot of them some didn't have bottom covers.)
                                  • ashr88
                                    • Mar 2023
                                    • 59
                                    #238
                                    HP Elitebook 840 G5
                                    Thanks, will take a look!
                                    Thanks, all sorted now!
                                    • piotrekw27
                                      • Aug 2023
                                      • 5
                                      • Polska
                                      #239
                                      Hello. Can someone help me unlock the 32MB BIOS for 840 G5?
                                      By the way, the question is how is this done? I usually use RCUnlocker but it doesn't work with 32MB files.
                                      Thank you in advance for your help. Regards
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 11885
                                      #240
                                      VVV
                                      • zenius
                                        by zenius
                                        12-08-2024, 06:13 AM
                                      • traxformania
                                        TONGFANG "GM7TG7P" Bios Password Problem?
                                        by traxformania
                                        I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                        But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                        I'm trying to reset my bios without success.
                                        I tried :
                                        -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                        11-15-2023, 07:32 AM
                                      • tlindi
                                        Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                        by tlindi
                                        Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                        >Read BIOS guides, methods, resources and tools
                                        Ack
                                        >Try the method at BIOS guides, methods, resources and tools before requesting help
                                        Ack
                                        >Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                                        python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
                                        01-30-2025, 04:26 AM
                                      • Nopslide
                                        HP Omen 15-dh0052nf power-on & bios password
                                        by Nopslide
                                        Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                        My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                        Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                        04-01-2024, 04:27 PM
                                      • BlackVisor
                                        How to Decode BIOS password for RedmiBook Pro15 2022 6800H
                                        by BlackVisor
                                        RedmiBook Pro 1542022 6800H
                                        SKU: TM2113-39463
                                        Model Number: RMA2204-AB
                                        CMIIT ID: 2022AP1835
                                        SN: 39463/22WD01355
                                        BIOS version: RMARB5B0P1010 20230628
                                        1. I bought this laptop from flea market, and the seller said that he had never set a password, however here is a password required when pressing F2 to enter BIOS.
                                        2. And after entering incorrrect password 3 times, there is no any useful information like "recovery code"
                                        3. I used universal bios backup tool, and dumped 8MB bin file, but hex code after "SystemSupervisorPw" is...
                                        01-14-2024, 06:35 AM
