Hp elitebook 840 g5 bios password
  • rddube
    Aspiring Expert
    • Jun 2013
    • 944
    Originally posted by angeleyes
    I have no idea how you came to this conclusion. I didn't even say I was running a Windows OS. I'm using Linux Mint.
    Well why in the world would you have it open all the time on the BIOS password? That's what operating systems are for, password protection. But anyhow, did you test your keyboard, i.e. plug in a known USB keyboard and try your password this way?
    • angeleyes
      • Apr 2025
      • 5
      • Nigeria
      #382
      You may be right, but I prefer such a defense-in-depth. The other night, a thief cut a hole through my window while I was sleeping, trying to steal my phones from my bedside using a long stick. But I woke up before any damage could be done.
      I initially thought as much, but didn't think that was the issue. The same password that didn't work happened to work again. I have not restarted my laptop again since then, as I always put it in sleep mode. I don't know if the problem will continue to persist or not. ​
      • ridouane
        • Mar 2019
        • 19
        • casablanca
        #383
        HP Elitebook 840 G5
        Serial Number : 5CG8524YZM
        ProID:3JX27EA#ABE
        Password Remove please
        Attaching Backup Bios
          • 21145
          Originally posted by ridouane
          HP Elitebook 840 G5
          ProID:3JX27EA#ABE
          RCUnlocker
          https://www.badcaps.net/forum/troubl...17#post3560417
          https://www.badcaps.net/forum/troubl...ls#post1622423
          • ridouane
            • Mar 2019
            • 19
            • casablanca
            #385
            Thank you very much my brother Puce SMD.
            • Zadiq
              • Mar 2020
              • 7
              • Nigeria
              #386
              840 g5 Please unlock
            • danito
              • Jun 2016
              • 986
              #387
              read the other chip aka 256
                • 21145
                RCUnlocker
                • Toha378
                  • Feb 2023
                  • ukraina
                  #389
                  HP EliteBook 840 G5 (Board ID 83B2) — need clean dump for 25Q128JVPQ (EC/SureStart)
                  I need a clean dump for the second SPI chip (EC / SureStart) on an HP EliteBook 840 G5.
                  Laptop details:
                  - Model: HP EliteBook 840 G5
                  - Board ID: 83B2
                  - System BIOS: Q78 (version 01.09.01)
                  - Main flash: W25Q256JVEQ (32 MB) — I already have a clean working dump with my serial numbers.
                  - Secondary flash: 25Q128JVPQ (16 MB, EC) — my dump is attached below.
                  Symptoms: The laptop works only with the main 32 MB chip replaced, but I suspect the EC/SureStart flash (25Q128JVPQ) is corrupted.
                  Since HP SureStart uses this chip, I need a proper clean dump to reprogram it.
                  Could someone please share a clean working EC dump for this exact board (ID 83B2)?
                  Any help would be greatly appreciated. Thanks in advance!
                  Добрый день!
                  Ищу чистый дамп для второй SPI-флешки (EC / SureStart) ноутбука HP EliteBook 840 G5.
                  Данные по ноутбуку:
                  - Модель: HP EliteBook 840 G5
                  - Board ID: 83B2
                  - System BIOS: Q78 (версия 01.09.01)
                  - Основная флешка: W25Q256JVEQ (32 МБ) — дамп уже собран, чистый с моими серийниками.
                  - Дополнительная флешка: 25Q128JVPQ (16 МБ, EC) — мой дамп прикладываю ниже.
                  Симптомы: ноут работает только после прошивки основной флешки, но подозреваю, что дамп EC (25Q128JVPQ) повреждён.
                  Так как HP SureStart использует этот чип для восстановления, нужен правильный чистый дамп, чтобы прошить его программатором.
                  Буду благодарен, если кто-то поделится рабочим чистым дампом под эту модель (Board ID 83B2).
                  Заранее спасибо!
                  • peste
                    • 12944
                    • ROMANIA
                    #390
                    post S/N, product number,post the contents of the bios chip even if it is corrupted..
                    ,etc.
                    • zenius
                      by zenius
                      12-08-2024, 06:13 AM
                    • traxformania
                      TONGFANG "GM7TG7P" Bios Password Problem?
                      by traxformania
                      I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                      But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                      I'm trying to reset my bios without success.
                      I tried :
                      -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                      11-15-2023, 07:32 AM
                    • tlindi
                      Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                      by tlindi
                      Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                      >Read BIOS guides, methods, resources and tools
                      Ack
                      >Try the method at BIOS guides, methods, resources and tools before requesting help
                      Ack
                      >Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                      python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
                      01-30-2025, 04:26 AM
                    • Nopslide
                      HP Omen 15-dh0052nf power-on & bios password
                      by Nopslide
                      Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                      My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                      Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                      04-01-2024, 04:27 PM
                    • BlackVisor
                      How to Decode BIOS password for RedmiBook Pro15 2022 6800H
                      by BlackVisor
                      RedmiBook Pro 1542022 6800H
                      SKU: TM2113-39463
                      Model Number: RMA2204-AB
                      CMIIT ID: 2022AP1835
                      SN: 39463/22WD01355
                      BIOS version: RMARB5B0P1010 20230628
                      1. I bought this laptop from flea market, and the seller said that he had never set a password, however here is a password required when pressing F2 to enter BIOS.
                      2. And after entering incorrrect password 3 times, there is no any useful information like "recovery code"
                      3. I used universal bios backup tool, and dumped 8MB bin file, but hex code after "SystemSupervisorPw" is...
                      01-14-2024, 06:35 AM
